Question on new Shimano MegaRange freewheel
Hello All . I just ordered within last couple days a new Shimano MegaRange MF-TZ30-6 14/34 6 speed freewheel to replace my old Suntour Alpha 13/30. Unfortunately I didn't consider what type chain might be required. Hyperglide or something else? This is going on my '88 Schwinn Impact. I've read on a few posts Shimano "thread on" 6 speed style freewheels do work and perform/shift well as a replacement. as the cog spacing is either the same or quite close. Can anyone confirm or correct me on this info? My existing chain is a bit worn so all else will need to be replaced. Derailleur is Alpha 3040 W/Suntour index thumb shifters. Seriously appreciate the help.
Quoted: 4513 Post(s)
Liked 6,389 Times
Not sure but all Mega billboard range FW's have worked fine with all regular chains for me.
The main thing for me is to buzz the Mega Range off the fugly black cog on the bench grinder wire wheel, I usually buzz the whole cog to get the lettering and all the black off as well.
These are a good option function wise but I don't understand why they can't just make a normal wide range one like the original SunTour's.
Quoted: 3464 Post(s)
Liked 2,831 Times
Spacing between the cogs might be a problem. You are going to have to take delivery and compare. The flag of concern was index.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
I use regular Shimano 6 speed freewheels with regular Accushift- works great! It might be different with Suntour's Alpha Accushift... I haven't had any.
EDIT:
I've used the Shimano 6/7/8 chain and SRAM PC 850 and 870 chains
EDIT:
Commence to jigglin’ huh?!?!
Quoted: 62 Post(s)
Liked 256 Times
aged to perfection
Quoted: 840 Post(s)
Liked 1,263 Times
Suggest a SRAM PC-850 / 853 which will work well on anything 6-9 speed
and has a quick link !
/markp
/markp
Likes For mpetry912:
Bikes: Franklin Frames Custom, Rivendell Bombadil
Quoted: 117 Post(s)
Liked 209 Times
FWIW, The Sunrace 7sp MFM-300 FW is offered in 14/16/18/21/24/28/34. It's all black so would need work to make it silver, but at least it's a normal progression.
I don't understand why they can't just make a normal wide range one like the original SunTour's. [/QUOTE]
I totally agree ! Seems like a pretty abrupt drop going from 24T - 34. I lost out on a Suntour 14/34 Ebay find. much nicer steps.
Likes For jzr756:
feros ferio
Quoted: 1393 Post(s)
Liked 1,330 Times
Back in 1974, when my wife and I were carless starving grad students, I built her Peugeot with 52-42 / 16-18-21-24-32, so I guess I was ahead of the "megarange" trend. It shifted well with my old SunTour VGT in back and a Shimano Titlist in front.
Her sister recently gave me a Carlton that had been equipped with one of the original early 1970s SunTour 5-speed 14-18-22-27-34 freewheels I think you are referring to. If you need some cogs or an entire freewheel, I may be able to help, because I plan to go 2x6 or 2x7 when I rebuild the Carlton.
In defense of Megarange, I cant simultaneously get a wide range with reasonably small progrssion steps with only 5 cogs. Having 6 or 7 in back is a major game-changer.
6 speed freewheel cog spacing is so wide you can use practically any chain you want. I just bought 5 sets of new 6-7-8 speed chains on AliExpress including shipping for less than $45. I only buy chains that have quick links. I've got not patience for old timey drive link chains.
Another "in defense"
I went MegaRange in a 6-s to 7-speed conversion. The 14-24 6 speeds are the same, so for as much of the ride as I can pretend I'm strong, dancing on the pedals , I've got the nice close spacing.
Aaaannnnnd......BAILOUT gear.
