Dura Ace 7800 cassette on regular hyperglide freehub?
Quoted: 800 Post(s)
Liked 754 Times
Went looking for an answer but came upshort. The question is short and simple, will a 7800 cassette, meant for a freehub with tall splines, work with a regular hyperglide cassette? Specific usecase is '9 of 10 on 7'.
My inclination is: 'Of course', but wanted to double check here first.
Thanks.
Thanks.
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 670 Post(s)
Liked 977 Times
Thanks.
Thanks.
Likes For georges1:
Likes For Piff:
There a few 7 speed freehub bodies that have the shortened splines for use with an 11 tooth outer sprocket, but these are uncommon.
Likes For KCT1986:
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 461 Times
I believe you need to use the spacer (that came with a new cassette) for it to work on 8 or 9 speed freehubs.
Conversely, Shimano took a brief departure with their 7800 freehub, making only 7800 cassettes suitable.
Steel is real
Quoted: 670 Post(s)
Liked 977 Times
Quoted: 656 Post(s)
Liked 469 Times
Here are some interesting articles about 10 speed cassettes compatibility on 8 speed hubs and 9 speed hubs Cassette Compatibility Chart and A guide to freehub body and cassette compatibility
This extract from the second link states "And the fourth stipulation is in regards to 6 and 7-speed HG-style cassettes and freehub bodies. Both 6 and 7-speed HG cassettes are narrower in width and therefore can be installed on any of the above HG freehub bodies with the addition of a 4.5 mm spacer behind the cassette. However, newer 8, 9, 10, 11 and 12-speed cassettes cannot be fitted to old and narrower 7-speed freehub bodies." This indicates a CS-7800 10 speed cassette does not fit on a 7400 freehub. I think OP intends to remove an inner cog make it a 9 speed so maybe it will work on a 7 speed freehub. Guessing this will come down to trial and error.
Removing 1 sprocket and spacer (if not integrated) should bring the 'stack' width down to 32-33mm, (taking into account the recessed mounting of the inner carrier). This width should fit on a 7 speed body. The thing to check is that the chosen outermost sprocket is able to engage the end of the spline. Generally, not a problem unless the freehub body is the 'C' version, which has a shortened spline for an 11 tooth outer.
