Another useless right foot left foot thread.
'09 Synapse Carbon 3
Bikes: '09 Synapse Carbon 3, R5000, R2000
This is something you should try. It is a good thing to know your limitations. On this mornings ride while thinking about some of the BF topics from yesterday, I wanted to know if I could un-clip both inside and outside with both feet. Of course we all have are strong directions mine are un-clip inside with my left foot first and then un-clip outside with my right. I am able to easily un-clip inside with my right foot but it is a struggle to un-clip outside with my left. I am right handed. I don't know if this will be useful information in the future but it is interesting...at least to me.
Bikes: 199? Trek 520
Hmmm...can't say as I've ever even considered that there was an "other" way. I'm right handed also, but un-clip outside with both feet. I usually only un-clip with the left foot unless I'm getting off the bike. Next ride out I'll have to try un-clipping inside.
Heel moves out to unclip on both sides. Right handed, always unclip the right foot for a stop. I can re-engage the cleat more naturally with my right foot (meaning I don't have to look or struggle) but do have to avoid the chainring tattoo.
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
coasting, few quotes are worthy of him, and of those, even fewer printable in a family forum......quote 3alarmer
No @coasting, you should stay 100% as you are right now, don't change a thing....quote Heathpack
Still can't climb
Quoted: 12 Post(s)
Liked 6 Times
i suspect some childhood trauma may be an influence.
Hills hurt.. Couches kill
Bikes: 1991 Specialized Sirrus Triple, 2010 Trek Madone 6.5 Project One, 2012 Cannondale Caad10, 2013 Trek Crockett
After reading this I think I've figured out why so many people fall with clipless.
You un-clip at the twelve o'clock so the only thing you will hit is your seat stay. I have been doing this for years and never had a problem. Sometimes I worry that I will wear a grove in my CF. I think I will do an inspection right now.
Administrator
Quoted: 11975 Post(s)
Liked 6,655 Times
Do this or end up like umd...all turtled on his ass.
Bikes: Specialized Tarmac SL2, Specialized Tarmac SL, Giant TCR Composite, Specialized StumpJumper Expert HT
Speedplays don't uncip in
Should Be More Popular
Quoted: 22600 Post(s)
Liked 8,928 Times
(edit: I have a different bike that I use as a commuter and for awhile was using a frame pump mounted along the seat stay...but when unclipping I kept knocking the stupid pump out with my heel! So I have relocated it.)
Has coddling tendencies.
And yes they do...especially if you have zero float.
Edit: I sport Speedplay Zeros.
I did some experimentation, and if set so that it is fully (or possibly nearly) heal out with zero float, I could release it in. BUT, if you have it set to be neutral or heel in, then the spindle will hit the plate. It's not just a matter of being hard to do, it just physically cannot rotate enough to release. I have mine centered with zero float, so mine cannot release in.
Lost
some of you definitely "think" too much about clipping in and out. after a while using clipless pedals, it became second nature to me, i dont think about it at all. - like driving a stick shift car, i dont ever think: "coming to a stoplight, dont forget to clutch, dont forget to clutch, dont forget to clutch....stall"
You are the man!
I have mine completely neutral, the spring exactly centered between the screws and 0 float. After your post I experimented with several settings, and the only way I could get it to release in was if was set extremely toe-in. It may matter which pedal model you have too, I don't think all the spindles are the same size. Since it's the spindle that is getting in the way, a narrower spindle may do the trick. I have the Ti zeros.
