Shifting while accelerating
Regarding today's TdF stage, I heard a commentator speculate that AS's chain came off when he shifted under acceleration. I know that with the old derailleurs you were supposed to back off while shifting, but I thought the modern designs claim they can shift under acceleration. Can someone clarify this? What else would have caused the chain to come off?
He might have not shifted the lever all the way, may have inadvertently hit the shift lever like when gripping the hoods tightly.
Oh, you know...
Bikes: '74 Schwinn Sports Tourer (Polo), S-Works E5 Team Festina (Chorus 11), Trek 2200 Bonded Carbon (Fixed), Trek 920 (7 speed IGH), Chesini Olimpiade SL (1x7)
My assumption is that he tried to shift the FD to the big ring, which of course would have put ridiculous strain on the chain.
Chases Dogs for Sport
It looked like he tried to shift to the big ring. But why would he do that at that point on the climb? It makes no sense.
There was no mechanical failure. The chain didn't break. He missed the shift. But again . . . why? Was it pure brainlock? (If Andy had been riding Di2, it couldn't have happened.)
Riding like its 1990
Shifting under load sometimes happens. How else are you expected to get up the mountain faster if you have strength to do it. You may lighten up a half stroke or so but some big sit down moment is not needed. He had more power to give, and went for a shift.
Señor Member
Quoted: 1492 Post(s)
Liked 1,096 Times
Looks like his heel may have caught the chain.
Oh, you know...
I could not tell if he was shifting but he hit a bump in the road that knocked his chain off. My feeling is that he shifted and accelerated at the same time that he hit the bump. The combination knocked his chain off. From the TV camera it was easy to see. But from the other racers point of view it may have not been so easy to see what happened while riding with such intensity and being so focused on riding hard.
Contador was still thirty feet behind when Andy sat up and started looking down at his chain dragging on the asphalt. Menchov and Sanchez were another 30 feet back from that, not making any kind of response at all.
There is zero possibility that Contador, Sanchez, and Menchov were unaware of Schleck's issue.
Señor Member
Liked 1,096 Times
Let's see... Armstrong didn't stop, and Kloden didn't stop, Levi didn't stop, Gesink didn't stop, Hesjedal didn't stop, Rodriguez didn't stop... Seeing a pattern here?
Oh, you know...
Nobody is saying anyone should have "stopped".
All those riders you mentioned continued at a normal pace up the mountain.
Contador attacked with all his might in order to take as much advantage of the mechanical as possible.
There is a big, big difference. Hopefully you can see that.
As for Menchov and Sanchez, they would not have attacked if Contador hadn't, but once he went they had no choice but to follow.
SilentRider
Bikes: Trek Madone SLR 7, Giant TCR Advanced Pro, Trek Domane SLR, Trek Emonda SLR Project One (x2), custom Bingham Built Titanium road bike
Logic!
Sorry, carry on with the prosecution.
Either way AS has to take responsibility for what happened which I think he has. He's got SRAM Red and from the video he shifts with his right hand 2 pedal revs before it seizes. It appears as if he was shifting to an easier gear but I'm not sure. If that's true then that would have moved the chain inward which could explain the chain hopping off the small ring. I don't see where his foot hits the chain but it's a little fuzzy. I do see the bottom of his chain bouncing like crazy and his rear derailleur move forward moments before the lock up.
I've got Red, about to put it on a new frameset, so I'd kinda like to know if that's a problem (not like I'm generating the kind of power they are but one can hope). Cheers
It could have been accidental from gripping the hoods. All it takes is a finger to shift. Not the whole hand to move. Especially if the lever is only moved partially. But it could have been the heel as well. What ever it was, something happened and it was most likely caused by something Andy inadvertently did.
Check out the front shot of Andy two pedal revs before he locks up. His right index finger moves the shifter inward about 1-1.5". It's fast. Might have to have HD and go frame by frame to catch it. GL
I grabbed an unmounted SRAM Red shifter and verified that a single click, move to smaller cog, is barely visible from the front. A double-tap to shift to a larger cog is about 1-1.5" so I'm now sure he was shifting to an easier gear or two. I could guess what happened afterwards but I'd be wrong.
Cycler
I maybe be incorrect, but it appeared to me that he was already accelerating in the big ring for quite some distance. Other than that, I have no explanation other than just simple misfortune.
After he popped the chain he tried to move the front derailleur outward (driving the left shifter all the way) to get the chain back up to any ring but Bob guessed it went all the way over the big ring. Then when he fixed it the first time you can see before he got his feet in the pedals they spun backwards and popped the chain back off. Just a series of bad situations.
At this time I don't blame Red but as soon as I can get on my bike I'd like to see how many pedal revolutions it takes for the chain to switch cogs. If it's less than two then either Andy was putting on so much torque that it prevented the shifter from moving right away or something mechanical didn't work right at the worst possible time. Cheers
Lennard Zinn Analysis
Here's Lennard Zinn's analysis: https://velonews.competitor.com/2010/...ome-off_130090
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
^Sounds like if you have Red, you might want to look into the upgraded RD. Is that something available to the public yet?
You could get lost and die.
You could hit a tree and die.
Contador's mechanic modified Contador's SRAM Red rear derraileur with oversized pulleys, different cage (no loop as mentioned in the velonew article linked above); maybe Saxo'x mech should modify Andy's too:
looking at that chain, seems to be some scuffing on it, the type caused by sandpaper. Any reason they may do this? Smooth the link edges or something? Does not look to be manufactured or wear marks.
