Damping Fork Vibrations
Was sitting around thinking about bikes and had this thought that a rubber plug stuffed in the steerer tube might absorb some high rate frequencies. Any thoughts on this?
Quoted: 4212 Post(s)
Liked 3,883 Times
Try it out then report back. Andy
AndrewRStewart
AndrewRStewart
Fill the fork legs with lead shot...
[Sorry, the day job has my snark on high output today.]
I am potato.
Quoted: 1790 Post(s)
Liked 1,631 Times
Only from added mass. I don't think that a rubber plug in isolation would do much as it is not an intermediary between 2 different structures of differing rates..
As long as we are fantasizing: Between the drop outs & the axle would have an effect.
But in reality land: So would between the rim & the road, between the headset & the stem or the stem and the handlebars.
Or as added mass on the bar ends. Effectivly minimizing the distance x force moves the lever.
Randomhead
Liked 3,701 Times
I don't think people find the small amplitude vibrations that could be damped out to be objectionable. You need more compliance to reduce the shock of hitting bumps. Don't see how this would make the fork more compliant.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I think one of the reasons people like the ride of carbon is because it damps out high frequency vibs, but I think compliance in a fork does more for overall comfort.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Wider tires are lower air pressure.
Redshift Stopshock stem.
Randomhead
Liked 3,701 Times
It's a very complex subject and I know too much about it to make any statements about it without seeing some decent literature or experimental data. So this is conjecture. I suspect the damping properties of carbon relative to comfort are mostly marketing. Note that Spesh used to have elastomer elements in their carbon frames and have moved towards suspension without ever admitting the old way was mostly just marketing. This suggests to me that the thing people find bothersome is hitting bumps, including small ones like chip seal that are experienced at high frequency.
Liked 425 Times
I don't know about the "mostly" part, but maybe "some" part. What I do know is that there is a distinct reduction in impact harshness when using a carbon golf shaft compared to a similar stiffness steel shaft. Guys with hand/elbow/shoulder pain issues almost to a man report some relief when switching from steel shafts to graphite. Chuck this one in the "for what it's worth" file and disposition as appropriate...
Front load .. Panniers with stuff in them..
build a 4 tube fork? 2 per blade?
2 can run to the top of the headtube over the headset back to the fork steerer, ..
more triangulation .. https://www.jonesbikes.com/fork-truss-steel-black/
Randomhead
Liked 3,701 Times
Seems like most people put the damping in the head of the club
This is basically the idea behind the Specialized Zertz that you saw on pre-future shock Roubaix and Diverges. Not sure it was all that successful since they dropped them completely.
Randomhead
Liked 3,701 Times
those zertz were not fully constrained though. Rubber is incompressible so it needs room to squish.
And most rubber compounds don't offer much damping.
Quoted: 18382 Post(s)
Liked 4,515 Times
I could imagine the rubber plug damping vibrations on something like a guitar string.
Although, perhaps one would be better off filling the space between the head tube and steer tube with something like synthetic quilt batting.
But, I have to agree with @unterhausen that the high frequency low amplitude vibrations carried through the tubes likely isn't a big problem.
It is quite possible that material selection would also affect those high frequency vibrations with higher strength steels carrying the vibrations, and softer metals simply dissipating the vibrations.
A couple of summers ago I got to ride my bike on a road that had been ground for repaving. Whew, the whole thing wiggled and jiggled. I had no idea I had so much frame flex!!!
Quoted: 103 Post(s)
Liked 144 Times
In practice (sample=1), I remember my Trek Madone from like 2006 or so came with these little rubber bar plugs that suspended a small (maybe 5/16 dia x 3/4" length?) rod in rubber webbing. I was using 44cm alum bars and 23mm tubulars on that bike and I couldn't tell a difference with them in or out. They were Bontrager branded and looked pretty cool so, I guess that's something.
https://www.flickr.com/photos/54319503@N05/
https://www.draper-cycles.com
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I remember the short lived Bontrager "Buzzkill" bar plugs. Emphasis short lived, least I thought they stopped making them.
https://www.ebay.com/sch/i.html?LH_CAds=&_ex_kw=&_fpos=&_fspt=1&_mPrRngCbx=1&_nkw=NEW+BONTRAGER+BUZZ+KILL+BUZZKILL+BAR+END+PL UGS+DAMPER&_sacat=&_sadis=&_sop=12&_udhi=&_udlo=&_fosrp=1
Randomhead
Liked 3,701 Times
I've heard that expanding foam will cause rust. It's also really weak, I don't think anyone uses it for damping. There are sprays that work to reduce vibration on sheet metal, but they are heavy.
Quoted: 103 Post(s)
Liked 144 Times
[QUOTE=Marcus_Ti;20893006]I remember the short lived Bontrager "Buzzkill" bar plugs. Emphasis short lived, least I thought they stopped making them.
Yep, those are the ones I was talking about.
This weekend I rammed a rubber plug into the steerer tube opening under the crown and went for a spin. Noticed no change in vibration damping. Gel under the bar tape will be more effective, or lower pressure in the tire.
Use Thicker tube wall fork blades .. (yes Heavier) ....
(drum brake hubs?)
vibrating as sub audible brake squealing?
(drum brake hubs?)
