Anyway to get this derailleur and this frame to play nice together
Anyway to get this derailleur and this frame to play nice together?
The hole for the bolt for the rear derailleur is obviously much to small for this derailleur's bolt. Is there any solution for this?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Your frame does not have a hanger tab to attach the derailluer.
That little hole is for a rack or fenders.
Your frame was intended to be used with a derailluer that has a "claw".
There are some adapters that will clamp on a separate hanger using the quick release lever, then you can attach the derailleur. Or get another claw derailleur.
Super Moderator
Liked 927 Times
Not sure if the claw adapter will work on the Dura-Ace model.
You may need the hanger add-on (or whatever it's called).
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
I love this post...
Today, I believe my jurisdiction ends here...
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
Looks like the remnants of the original hanger broken off at the bottom.
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
Weird post-who would attach a Dura-Ace derailleur onto a claw-adapter frame? It's like putting a Ferrari motor into a Chevette.....
I'll post pictures when I'm done!
Quoted: 1324 Post(s)
Liked 927 Times
Various Manufacturers Rear Derailleur Adaptor Claw - Harris Cyclery bicycle shop - West Newton, Massachusetts
If there's a bicycle Co-op near him he can probably get one there or a bike shop might give him one from their used parts bin.
Cheers
Someone who had both a Dura Ace derailler and a frame to use it on. All the OOP needs is the Claw Adapter like this.
Cheers
Cheers
Liked 927 Times
Cheers
Quoted: 608 Post(s)
Liked 352 Times
It looks like you are changing a long cage derailleur for a short cage derailleur so you might have some chain wrap problems. Can that Dura Ace handle your largest cog?
Super Moderator
Liked 927 Times
I don't know if that claw will work with the Dura-Ace derailleur. You may need the claw Miele Man linked to in post 9.
IMHO, You could seek out a different frame for a derailleur drivetrain with the hanger Built in,
and use an IGH on that one instead.
The horizontal axle slot has advantages in a single loop chain around 1 cog and 1 chainring.
Or The Lower end Rear mech will work fine , just doesn't have the prestige Bling of the Dura Ache.
Liked 927 Times
Like i said, i'm just curious because i've seen expensive "Buy this $ item... Buy a new bike" many times in response to a question where there's a simple fix with the on hand items the poster has.
Cheers
The other RD complete, new , is costing Little more than just the hanger alone would and wil have a larger gear range capacity
Race Bike parts are for strong riders that don't need Low Gears.
@BlackCloud The dura-ace is moving over with my wheel and hub. It's a 10-speed derailleur and a 10-speed cassette. The wheel fits snugly into the dropouts.
@meileman and @Homebrew01 , thanks for help and feedback so far. I'm really just trying to learn about bicycle mechanics, so I definitely appreciate the solutions that utilize what I have on hand. Once I get that torx bolt removed, I'll report back if everything fits.
Thanks, everybody!
Thanks, everybody!
Super Moderator
Liked 927 Times
@BlackCloud Once I get that torx bolt removed, I'll report back if everything fits.
Thanks, everybody!
Thanks, everybody!
Quoted: 263 Post(s)
Liked 9 Times
If you are intending to have indexing then you should buy the proper claw. SIS compatible claws are marked and might save problems later. Your LBS will have them for a couple of dollars.
You may have travel/limit issues when you go to set this up.
Super Moderator
Liked 927 Times
I saw a claw similar to post # 9, but it had an offset to put the derailleur mount in a more "correct" position under the dropout as it should be.
I've gone ahead and ordered the adapter as in post 9. I've got everything transferred over from the Fuji except I'm now realizing the brakes won't reach the rims of a 700c tire. I may have to create a little extender to get them the rest of the way if something like that isn't made already.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
No, get new brakes with longer reach. Something like the Tektro R539 Long Reach for $50. Or hunt around and find some used long reach brakes.
Making drop brackets (that's what you are calling extenders) will be time consuming - and risky. By risky, I mean if the bracket fails or comes loose in a couple years, your friend could suffer a brake failure and get hurt. I would not give a bike with a homemade drop bracket to someone else. (I have a bike with such a bracket, but it stays in my household.) Brakes are critical, not something to take risks with. At least wait until you are more experienced with bikes, before you start making drop brackets.
Liked 927 Times
An image of your brakes showing where the pads currently rest would be very helpful in determiig is that was doable.
Cheers
If the needed drop for the brake pads to contact the rim is not too great you MIGHT be able to do it by carefully filing/grinding the bottoms of the brake pad slots so they are longer.
Cheers
Cheers
I really can't thank everyone enough for all the help and support. You guys are awesome.
