Advice on 2 Bike Hitch Carrier
Trying to narrow down a decent, budget friendly 2 bike platform bike carrier for our sixthreezero EVRYJourney bikes.
Debating between the Swagman Chinook and theHollywood Sport Rider.
Any suggestions are welcome.
I had a Hollywood, you have to be careful that you have the hook over the top tube securely, and the it and the frame are clean, and the padding doesn't have a hole, and any cables that are routed on the top of the top tube are padded under the cable. Or you will scratch the frame.
Check graigslist for used racks.
Likes For leob1:
Bike Carrier
Thank you for the good advice!
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
Of the two you're considering, the Swagman seems more robust, but personally, I'd get a Kuat Transfer if I was looking to spend less than $400. (I bit the bullet and got a Kuat Sherpa and have no regrets whatsoever.)
Likes For Rolla:
Sunshine
Quoted: 10902 Post(s)
Liked 7,391 Times
I quickly googled that brand since it is not exactly one I keep up with and it looks like the bikes have fenders.
Most tray(platform) racks hook to the tire, which isnt OK with fenders.
The 2 you specifically ask about are frame connecting so thats great. The Swagman Dispatch is another option. Someone I ride with has a Dispatch and their bike hasnt fallen off yet so it clearly works.
Fender Issue
Thinking front and rear fenders on our bikes will not play well with the Thansfer v2.However, their chat fellow said it will if I stick a piece of pool noodle between thee fender and the wheel hook. Not sure that is the most wise method.
Guest
Liked 3,269 Times
Ah. Yes, fenders do add some limitations. The pool noodle idea is probably sound, but could be expensive if it isn't. For freeway or moderate off-road driving, I'd want something more foolproof.
Quoted: 258 Post(s)
Liked 291 Times
I have the older version of the Transfer 2 and my bike has SKS chromoplastic fenders. The rear fender is no issue at all, since the adjusting hook captures the front wheel. To be honest, I just push the retaining hook down on top of the fender until it's in firm contact with the tire. I know it's not advised. So far, no problem. I've driven hundreds of miles like this on interstate and two lane blacktops with no sign of imminent problems. Dunno if I'd want to do that off road, though. YMMV.
Quoted: 6882 Post(s)
Liked 10,873 Times
Anything you place above the fender is likely going to blow away at highway speeds, and then your clamp will be loose.
Quoted: 1182 Post(s)
Liked 830 Times
This is our hitch mount Thule rack. Our touring bikes have racks and fenders, which make a cross tube anchor point necessary. I purchased it from this company, and am well satisfied by the service and the rack's quality: https://www.etrailer.com/dept-pg-Hitch_Bike_Racks.aspx
The first time we used ours was on a 5,000 mile (round trip) road trip to get to the start of a 2 month tour. Unfortunately, I could not find it in recent catalogs.
Quoted: 339 Post(s)
Liked 268 Times
I have a Swagman XTC2, which isn't rated for two 40 lb bikes, but what I like about it are the loops for holding the tires. I think they are more secure than the baskets used on the Swagman Chinook. SO I'd pick the Hollywood because it has the same type of loops,
Yes, I had my bikes fall off once, but I had a bike chain/lock looped around the frames and rack, and that just happened to keep them from scraping the pavement, The tires remained lashed in the loops too, I didn't pin the center strut that hooks onto the frames, and what do you know, the J hooks got slack, and it folded flat on its own.
I just purchased a Chinook. It does the job well, doesn't move around too much and is very stable. I don't mind the frame hook, but I do put a microfiber towel around the top tube where the hook meets the frame, just to keep any wear to a minimum. I would recommend.
Swagman Chinook
Thanks; you helped me decide on this one.
Likes For frjeff:
>>I'd get a Kuat Transfer if I was looking to spend less than $400. (I bit the bullet and got a Kuat Sherpa and have no regrets whatsoever.)<<
I started out wanting the Transfer 2, but the more I look into it the more I want the Sherpa 2 instead.
