sram force with ultegra brakes
i have the current force set up on ultegra 6700 brakes but it feels a little squishy. is that normal? i adjusted the tension so that the brake pads are close to the surface of the rim and it feels firm at first when pulling on the levers but it gets softer once the pads are against the rim.
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
Per Shimano's compatibility charts, 6700 brakes only work with newest wave of 105, Ultegra, and DA levers, and are not compatible with your Force levers. Newest rev. uses longer pull and cable travel, so new levers work with old brakes with a squishy feeling, but old levers are not supposed to work with new brakes.
People will argue with this, but there have probably been 6 threads on this same topic in the past 3 months.
Quoted: 1975 Post(s)
Liked 232 Times
6600 brakes used the old standard pull so not applicable in this case. There is definitely a difference in pull between 5500/5600 brifters and 5700 brifters. I upgraded to the 5700 with old 5500 brakes and lost a lot of modulation. Swapped out to 5700 and I got it back and it feels better overall.
Speechless
Quoted: 163 Post(s)
Liked 39 Times
As near as I can determine, the new 5700/6700/7800 (if that's newest DA) use a cam action in the shifter, so it is not only longer pull but pulls at different rates through the stroke. I would assume it is larger ratio at first to cover air gap and then smaller ratio to allow fine modulation.
If this is correct, when you pair new levers with 5600/6600/old DA brakes, you have enough travel, but end up braking in the larger ratio area which makes them feel squishy.
On this theory, old levers with new brakes means you run out of travel before you engage brakes, unless you run the pads exceptionally close to the rim.
Old levers from every company worked with old brakes from everyone else. I would guess Shimano did this change to brag about superior braking within their groupsets, in an aim to reduce the effectiveness of Tektro and other brakes with 5700/6700 levers.
Sorry I don't know the right DA part #'s, too poor to pay much attention.
L-I-V-I-N
As near as I can determine, the new 5700/6700/[strike]7800[/strike] 7900 (if that's newest DA)
If this is correct, when you pair new levers with 5600/6600/[strike]old DA brakes[/strike] 7800, you have enough travel, but end up braking in the larger ratio area which makes them feel squishy.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
