Fans vs airconditioning in your pain cave?
Probably a stupid question, but I keep seeing mentions of fans that people use while training, especially pedestal/table mounted fans.
So, why not airconditioning and/or ceiling fans?
Just setting up a room for training, and it has both airconditioning as well as a ceiling fan. Will I get more benefit if I added some pedestal fans?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Both fan and AC.
A little box fan or table fan did not cut it for me and had to get something that pushed lots of air.
20 in. Shroud Floor Fan-SFD1-500B-3 - The Home Depot
-Tim-
-Tim-
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
Most residences in the US have "central" air. Vents are up high and it's single temp setting throughout the residence.
They rarely use the wall mounted units that are more effective for this purpose.
Same thing for ceiling fan vs a strong floor or industrial floor blower. The former has broad coverage
Quoted: 2952 Post(s)
Liked 3,106 Times
I can't speak for others but I work out in a detached garage. No AC.
Custom User Title
Bikes: Fuji Roubaix Pro & Quintana Roo Kilo
Quoted: 2863 Post(s)
Liked 31 Times
Since my indoor training is done in Minnesota during the winter I just turn the heater in the "pain cave" (bedroom) down.
Bikes: 2012 GT Transeo 3 2014 Cannondale CAAD 10 105
Quoted: 26 Post(s)
normally some sort of small fan, but hoping this winter I'll be setup in the un-insulated garage.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
My favorite is 55° and a 24" box fan about 6' away. So if you have AC, that's what to shoot for. Some people use 2 box fans. You want enough fan that you need cycling glasses. The fans are necessary to create airflow over the skin, which greatly increases the evaporation rate of perspiration, as we all should know by now. Nothing worse than a hard climb in hot weather with a tailwind.
Results matter
Results matter
Quoted: 18413 Post(s)
Liked 15,536 Times
The air flowing across your body from a fan will cool you more than something like A.C. alone.
Quoted: 6556 Post(s)
Liked 58 Times
The air needs to be cool with low humidity, and it has to be blowing right on you strongly. Any way you can figure to arrange that will work. Central AC with a big fan trained right on you is the most common and simple way to accomplish this result.
Bikes: Specialized Roubaix, 2011 and 2017
Quoted: 165 Post(s)
I use this, parked a few inches from the front wheel, blowing at about a 40° angle upwards: https://www.amazon.com/gp/product/B004IS6JBY
This is either in a room with central air, or on the deck when the weather affords.
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
I still sweat a ton on the trainer, though, as @WhyFi noted on my strava this morning.
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
I put my trainer in the bathroom with a space heater, turn the shower on hot, and wear full winter kit.
But that's because I was trying acclimatize for a hot ride. It worked.
