Best smart trainer to get started with Zwift
Hi everyone,
I am planning on getting a smart trainer to use with Zwift and improve my fitness over the winter. I would like to keep the price to around $400, but am willing to spend $500 if it is worth it. What is the most highly recommended smart trainer in this price range?
So far, I am currently looking at two different options: the Kinetic Rock and Roll Smart and the Tacx Vortex. I am drawn to the Kinetic due to the side to side motion it allows, but the Tacx also seems highly rated.
I currently ride a Cannondale Supersix Evo Hi Mod and weigh 165lbs. Also, are there any other equipment/accessories I will need in order to use Zwift? I have a smart phone and basic laptop. I plan on getting a floor mat and front tire riser. Would I need a USB Bluetooth adapter to run Zwift off of my laptop?
Thanks for the help!
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
Not familiar with the two trainers you mention, but I think the side-to-side motion is a pretty good feature to have.
And generally yes, you would need a USB ANT+ antenna to connect to your trainer's sensors, unless your trainer (and any additional sensors you want to use, e.g. cadence and heart rate) also supports Bluetooth -- though general advise would still be get a USB dongle (either with a built-in cable, or get an extension cable) so that you can place the antenna close to the trainer.
Quoted: 65 Post(s)
Hello,
Any money you spend on a smart-trainer/Zwift setup is well worth it, so only cry once if you can (buy good stuff). It will easily have you in the best shape of your life when others are just getting re-started for the Spring.
Display it on a HDTV if you can. As atwl77 said, you need a dongle. I wasted 36 hours trying every single thing in the world to get BT running. I bought an ANt+ dongle and I was riding in seconds.
You'll need a mat and water-resistant area, fans, 2-3x the towels you think you'll need, 2-3x as much laundry will need to be done for towels and riding clothes. Buy sweat bands to help control the sweat too.
I have learned so much about perfecting bike fit and my form while riding is now automatic. Two weeks of Zwift gave me 2+ mph averages outdoors and I was not even trying. I looked down and my speeds were that much faster.
It is a very good thing.
oops, Sorry I can't help with trainer choice. I went with a kickR myself.
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Bikes: Cannondale Synapse, Focus Izalco, Focus Mares CX, BMC GF02, Giant VT3 MTB (upgraded), Felt Brougham SS
Quoted: 56 Post(s)
Make sure you get a "smart" trainer, Zwift is not nearly as fun without one. The Wahoo Kickr Snap is a really popular cheaper trainer. It should be in the DC reviews...
Quoted: 275 Post(s)
I recently picked up a CycleOps Magnus. I was previously just using a standard fluid trainer (no Zwift) what a huge difference and the trainer worked flawlessly with Zwift, which was nice.
pluralis majestatis
Bikes: a DuhRosa
Quoted: 537 Post(s)
no problems with my tacx vortex but if i was buying again, since the prices are quite low now, i would go with a direct drive machine
Bikes: Factor O2, Caad10, Caad2
Quoted: 365 Post(s)
Liked 122 Times
To the original poster, you may need/want the USB ANT+ dongle, of which an inexpensive version is here: ANT+ USB
Bikes: 99 Klein Quantum, 2012 Cannondale CAAD10 5, Specialized Tarmac Comp, Foundry Thresher, Fuji Sportif
Quoted: 98 Post(s)
Truer words have never been typed. I too went with the Kickr and I'm a cheap ass. Got me back on the trainer after more than 15 winters off. I HATE trainers.....well I use to ;-)
Quoted: 23 Post(s)
I'm curious about this as well. I already own a Kinetic Rock and Roll which I bought before I even heard of Zwift...
But now I want to set this up, and my primary concern is that this particular trainer won't automatically adjust difficulty in Zwift based on hills, i.e. you would need to upshift to simulate the incline (the exact opposite of what you'd do when you encounter a hill in real life). I'm worried this will really ruin the immersion. Is this correct? Did I buy the wrong trainer?
Quoted: 8 Post(s)
https://support.zwift.com/hc/en-us/a...Smart_Trainers
Liked 8,925 Times
Which laptop and which program? Zwift normally doesn't work with laptop bluetooth connections, so you need the phone to make the bluetooth connection to the trainer work.
Quoted: 40 Post(s)
https://www.kurtkinetic.com/trainers...rol-power-unit
Perhaps off topic, why is there so much focus on zwift? I have been looking into a getting a trainer, but trainerroad seems much more appealing to me...
Bikes: yes
Quoted: 1281 Post(s)
Liked 643 Times
It isn't necessarily cheap, but if you have a non-smart version of a kinetic trainer, you can buy the item below to upgrade your old trainer. Though I haven't seen this done personally.
Personally I prefer Trainerroad, because I have a dumb trainer and I got a lot more benefit last winter from using the structured workouts on Trainerroad than I did with Zwift. But -- a smart trainer would be useful with Trainerroad, too.
I personally bought a Magnus 2 months ago and have been using the heck out of it. One piece of advice that no one ever told me, and I only found out after melting a tire, CALIBRATE BEFORE EVERY RIDE. None of the documentation says this, Zwift doesn't say this, but it is imperative in order to have accurate readings and a fun time. Also, I prefer trainerroad over zwift, but that's just me, especially since zwift just raised their price from $10 a month to $15 dollars a month.
Quoted: 365 Post(s)
Liked 122 Times
It must be an IOS thing then, because it is stated that one must use a phone with Bluetooth when using Zwift with Windows.
Quoted: 56 Post(s)
I'm curious about this, I use The Hammer and used to calibrate almost every ride but I didn't notice any difference so I stopped. What do you notice as an improvement by calibrating so often?
Master Sarcaster
Bikes: 2018 Allez Sprint, 2016 Trek Crockett Canti
Quoted: 190 Post(s)
Cheap rollers (or trainer if you go that way) and a Power Meter.
Yes... Zwift won't control the resistance this way, but you can use the power meter when you get back on the road in the summer. This is what I do.
Liked 8,925 Times
If you have a wheel-on trainer (like my KICKR Snap and most budget trainers), it's a good idea.
Greetings,
About 4 months ago I purchased direct from Wahoo, a factory reconditioned Wahoo Kickr SNAP, wheel on trainer. You may want to check the Wahoo website for a reconditioned model, the one I purchased was significantly less than a new trainer, and I recall there was also a sale going on when I purchased mine. So far it has worked flawlessly.
On the recommendation of a friend, I did purchase another rear wheel, cassette and trainer tire to use on the bike when on the trainer.
I use the Cyclops Magnus which is an on-wheel trainer, it makes quite a difference, I hear it is much less so with direct drive trainers like the hammer.
Bikes: 2014 CDale EVO, 2007 System Six, 2004 Litespeed Solano, 2002 Burley Duet
Quoted: 92 Post(s)
After reading all the reviews, I will hopefully have a Kickr on Wednesday. Wahoo had a 10% off cyber Monday sale.
I came close to buyingn a Kinetic trainer until I did some research. Cycleops and Wahoo both use ANT+ or BLE. Kinetic uses a proprietary BLE signal that is not supported by all the programs out there.
Every review said the Kickr had a better "road" feel than the Magnus due to the larger and heavier flywheel.
I am using an older rim and tire on my current fluid trainer. If you use your current wheel, you will definitely want to get a steel rear skewer to use on the trainer.
Quoted: 98 Post(s)
Congratulations. You'll love it.
Now be sure and study all the tips and tricks. The biggest being to use the big gear and a smaller sprocket in ERG mode....helps avoid the death spiral :-)
Enjoy!
Would I need anything else?
