TRP HY/RD brakes
Pointy Helmet Tribe
Bikes: R5, Allez Sprint, Shiv
Quoted: 519 Post(s)
Liked 627 Times
TRP HY/RD brakes
So it turns out that I have all the parts needed to put together a 10 speed DI2 system except shifters - was looking to get a pair of shifters to complete the group and then putting it on a gravel frameset. 10 speed should be ok for me for now, and i can always upgrade down the road later, if i so desire.
The frame is going to be a disc brake frameset so that i can swap wheelsets with my other bikes. As I want to minimize the spending on this bike, was thinking of getting 6770/6870 shifters to complete the build. But these are cable brake levers.
I have no desire to run mechanical disc brakes - however, the TRP HY/RD brakes could be an option, as they seem to avoid some of the issues of mechanical brakes. Are these worth getting (I realize they wont have the same modulation and braking power as hydraulics - as long as they are comparable or better than rim brake versions and not too fussy to maintain, I am happy).
Also, can the brake cable for these be routed internally, the same as hydraulic hoses?
Edit to add - last question: are there compatibility/spacing issues due to the larger size of these calipers?
TIA!
TIA!
Blazer of saddles, trails
Likes For blazin:
Quoted: 20810 Post(s)
Liked 9,456 Times
I occasionally peruse Di2 parts and I swear that I've seen 10-sp Hydro DA on the cheap more than a few times. I'm talking sub-$200 for the pair.
Likes For WhyFi:
Sunshine
Quoted: 10954 Post(s)
Liked 7,481 Times
Related option- juintech makes a cable hydraulic option that is smaller than the hy/rd. It comes in post mount(r1) and flat mount(f1) and a few different colors.
I have the f1 model on my gravel bike because I didn't want to give up my Gevenale shifters when I built up the frame. I used compressionless brake housing and the breaks work extremely well.
https://www.ebay.com/i/142986796456?...hoCNUsQAvD_BwE
https://www.ebay.com/i/132876764147?...xoC2h8QAvD_BwE
https://www.ebay.com/i/223775065066?...r=522511929860
Likes For mstateglfr:
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Well, I dont want to spend more than i have to, but at the same time, i am not going to screw up the build just to save a couple of hundred bucks... thanks for that tip, will check those out as well.
Liked 9,456 Times
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Also, for those of you using TRP HY/RD and similar brakes - how is the braking performance? It doesnt have to as good as hydraulic, but as long as it is comparable to or preferably better than rim brakes, I am good.
Quoted: 1088 Post(s)
Liked 1,022 Times
https://www.competitivecyclist.com/s...oxOjQ6cjc4NQ==
Might be 11sp but with Di2 doesn't the shifter just tell the der how far to move and it will work fine with any shimano 11sp cassette? 200 for shifters and brakes I'd rather buy a cassette and go 11sp then buy shifters for 200 plus cable actuated hydraulic for another 150.
Quoted: 630 Post(s)
Liked 369 Times
If you're gonna spend $200+ might as well go full hydro:
https://www.merlincycles.com/en-us/s...nt-103562.html
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Oh awesome - that's fantastic. I never even realized that there was a 10 speed Di2 - the model number is non-standard, so that's what threw me off..
Ordering it off Competitive Cyclist now.... thanks a lot, WhyFi Russ Roth and Elvo !!
Yup - as per my compatibility chart, this would be compatible with my old 6770 FD/RD. To go 11 speed, i will need to replace both the RD/FD as well, though, as those arent 11-speed compatible. But that's ok, can always upgrade them later - for now, this solves my problem a lot more elegantly (and cheaply) than getting 6780 shifters and paying $250+ for th e TRP brakeset.
Likes For guadzilla:
Likes For Racing Dan:
Sunshine
Liked 7,481 Times
The brakes stop me as well as v-brakes...which is a compliment because the ones I've used can make a bus skid.
I think the compressionless brake housing is a big reason i like the setup.
Installation is simple. There is a 3min YouTube video from the company and its a basic system- you can see the adjustment screw easily and its simple to adjust the pads when installing.
Earlier, I didn't mention the cable routing.
juintech f1 is smaller and lighter than trp hyrd, but the cable points upward as it enters the caliper. Hyrd has the cable point down. I dont care because I don't submerge my bike in 2' or water, but the cable routing may be an issue for others.
Pointy Helmet Tribe
Quoted: 519 Post(s)
Liked 627 Times
Update - ordered the 11 speed hydraulic Di2 shifters off CC. Old generation, but who cares....
Now to pick a frame. Aspero, Open UP or Chapter2 AO - or even a Giant Revolt if i wait till Oct/Nov for the 2021 MY.
Liked 9,456 Times
Likes For WhyFi:
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
in terms of power and modulation, I'd put put them about evenly between cable actuated disks and hydraulic. Better than cable, not as good as full hydraulic, but overall not bad.
You could get lost and die.
You could hit a tree and die.
Likes For merlinextraligh:
