Will most bicycle shops fix ebikes?
Old 05-18-15, 07:59 PM
ebikeottawa
Just wondering how often regular bicycle stores will fix ebikes. Looking to get some spokes replaced as well as a tube replacement + rim tape replacement on the tire with motor, and am wondering where I should take it as the ebike repair store is 30 minutes away, while there are probably a good 5 bicycle repair shops within a 5km distance from my house.
ebikeottawa is offline
Old 05-19-15, 07:35 AM
ebikeottawa
Bump
Old 05-19-15, 08:46 AM
2old
Quoted: 878 Post(s)
Liked 813 Times in 614 Posts
1) A good wheel builder should have no problem; my bike shop built me a fat tire ewheel. If they have problems finding spokes, try Dan's Comp (I know it's a BMX shop).
2) Others may disagree, but duct tape works well as rim tape and easily applied.
3) Purchase thorn proof tubes unless you're using Schwalbe Marathon or similar tires.
2old is offline
Old 05-21-15, 12:43 PM
HGR3inOK
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
Call the closer shops and ask them. Be sure to disclose that it is an ebike. FWIW, we do not work on ebikes that we did not sell. We will replace tubes/tires/rim strips if the customer brings in just the wheel. We will do wheel truing on a non-drive wheel. We might do wheel truing on a drive wheel, depending on its configuration.
-HANK RYAN-
Norman, Oklahoma USA
HGR3inOK is offline
Old 05-21-15, 03:41 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Once again Why ask Here instead of calling the Shops Yourself?
Electrical issues (Broad Generalization) if they sell them.
but tire and tube replacements are Generic, though removing and re installing a HubMotor wheel will incur a bit more time to do and may cost a couple bucks more..
fietsbob is offline
Old 05-21-15, 03:49 PM
Dan Burkhart
Senior member
Dan Burkhart's Avatar
Quoted: 942 Post(s)
Liked 656 Times in 370 Posts
One issue you may run into with some ebikes is large diameter spokes, like 12 or 11 gauge. Not many shops equipped to custom cut and thread those.
Dan Burkhart is offline
Old 05-24-15, 11:33 AM
robert20
mostly they can fix the problem but some times they dont understand where is the problem.
robert20 is offline
Old 05-25-15, 02:00 PM
bareyb
Just ask them. I was surprised to see that both of my local bike shops are willing to do general maintenance on them. Change tires, true wheels, adjust Brakes and derailleurs, etc. If they are good mechanics and are handy with tools, they should be able to disconnect a couple of cables and Torque brace. Beyond that, it's just a bike. Anything electrical and e-bike specific I'd of course take it to a dedicated e-bike store.
bareyb is offline
Old 05-26-15, 12:03 PM
dillenger
Definitely, one needs to approach the nearest e-Bike store to get it repaired without any risk & doubts in mind. You can contact those bicycle stores near to your house for analysis of faults you have in your e-Bike. It may be possible that they'll provide you better advice related to your e-Bike issues. Moreover, if you need to buy or get to change new spare parts, I can give you better suggestions on that.
dillenger is offline
Old 07-08-15, 02:59 PM
farbike
Bikes: X-treme Trail Maker XB-300li
I deal with customer support every day bcause I sell electric bikes at Farbike.com and find most customers have good experience at local bike shops. Also if in the rare case a bike shop wont deal with the electrical system, we just send a replacement part with swap instructions. Since the only difference between an electric bike is a battery, controller, motor and throttle (and brake switches to be exact) a bike shop can easily reapir anything as long as we send them the part.
farbike is offline
Old 07-10-15, 10:57 AM
speedy25
Bikes: Specialized, Trek, Diamondback, Schwinn, Peugeot
Quoted: 160 Post(s)
Liked 53 Times in 43 Posts
welcome farbike.
Yes we know these bikes arent all that complicated, but there are many shops that just wont deal with product that wast purchased at THEIR shop. Sometimes the "snobbery" is justified, and other times its silly. Just chat a shop up and see what they are like.
-SP
speedy25 is offline
Old 07-11-15, 09:06 PM
15rms
15rms's Avatar
Here is Denver we have a Bionx dealer that will not fix my Bionx bike because he did not sell it to me.
15rms is offline
Old 07-12-15, 06:49 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
That's odd. I'm guessing he won't sell you the next one either.
JonathanGennick is offline
Old 07-12-15, 10:02 AM
powell
Bikes: E+ kit, BIONX
Quoted: 58 Post(s)
Liked 10 Times in 7 Posts
15rms,
what is problem with your BIONX?
powell is offline
Old 07-15-15, 09:18 PM
15rms
15rms's Avatar
Powell The system seems to have gone totally dead. I believe the battery is good and is showing green when I push on the charge port. When I put the battery on nothing happens. My question is will the brake switch do this? The brake switch wire seems to be crimped quit a bit.
15rms is offline
Old 07-16-15, 08:47 AM
350htrr
Bikes: 27 speed ORYX with over 39,000Kms on it and another 14,000KMs with a BionX E-Assist on it
Quoted: 1024 Post(s)
Liked 57 Times in 49 Posts
The brake switch would just put the system in re-gen, sounds like a broken wire, or a connection problem with the controller...
EDIT; Oh and as far ar the bike shop not fixing your BionX because you didn't buy it there, let BionX know about it... Contact Us - e-bike, electric bicycle systems | ridebionx.come-bike, electric bicycle systems | ridebionx.com
350htrr is offline
Old 07-16-15, 12:56 PM
FBinNY
Quoted: 5767 Post(s)
Liked 2,541 Times in 1,407 Posts
Just about any shop can do the basic BIKE repairs on E-bikes, like fix flats, replace chains etc. What many cannot do is work on the electrical side.
FB
Chain-L site
FBinNY is offline
Old 07-16-15, 05:29 PM
powell
Quoted: 58 Post(s)
Just did simple tests - holding break lever/with switch/ does not affect powering up.
Sliding battery in with the same lever holding also do not affect powering up.
NOW
can I disconnect lever switch easly?
powell is offline
Old 07-16-15, 08:57 PM
15rms
15rms's Avatar
I did contact Bionx and complained. They gave me their list of dealers in the area. I found an Ebike store that now has the bike and is fixing it.
15rms is offline
lowlux
General Cycling Discussion
23
05-10-20 11:37 AM
chucky
Bicycle Mechanics
9
06-02-13 09:10 AM
Suicidecommando
Electric Bikes
4
03-08-12 01:10 PM
valvido
Bicycle Mechanics
31
02-22-12 07:30 PM
Feddas
Bicycle Mechanics
14
02-06-12 02:12 AM
