Huret Multito drive-band size?
Quoted: 1106 Post(s)
Liked 1,328 Times
These are the mechanical odometers that are driven by a rubber belt, pretty much an O-ring.
Which I haven't got one of (the band that is).
Does any know/can anyone measure the size for me?
Quoted: 235 Post(s)
Liked 349 Times
The exact size I use is: #89. Dimensions are 2-3/16 x 2 x 3/32 inches which is thicker than the original Huret belt and thus more durable; you can get thinner ones if you like also. The other info on the package, in case you want to get them direct from the manufacturer or otherwise, is: Stock Number 35705B, UPC# 0-37155-35705-5, Danco Company, Concordville PA 19331, Made in Taiwan.
maybe use the BF search function?
Hope this helps
Quoted: 3811 Post(s)
Liked 3,338 Times
