crank spider contacting chain on singlespeed
I just had my bike converted to single speed. Crank is a Shimano XT M785 and chain ring is a stainless shimano 32T. I'm running a Surly 18t in back. Love the ratio. I noticed the chain is slightly contacting the crank spider though and has worn off the finish a bit. Is this a problem? I am having no performance issues it appears to be cosmetic at this point but as the chain wears down or the teeth on the chainring could it become a problem? Can I solve this by installing chainring spacers between the spider and chainring? Or am I just making an issue out of nothing? Thanks!
Old fart
Quoted: 3556 Post(s)
Liked 3,332 Times
No, it shouldn't be a problem as long as the chain stays properly seated as it passes over the spider.
It appears to be properly seated as it goes around. No skipping issues. The spider is literally flush with the chainring. It looks like it is getting full tooth engagement when the chain passes over this area.
ot.net slave
Bikes: Salsa mtb * 3, Intense mtb * 1, Abeni SS rd * 1, Salsa road/touring * 2, Trek Damn one * 1, Vintage/projects * many
You won't have to swap the cog, just file a chamfer onto the spider where it contacts.
- Joel
- Joel
Quoted: 1438 Post(s)
Liked 1,091 Times
The chain will likely wear itself a recess on the spider. If you'd like you could take a Dremel tool with a drum-shaped tool and finish the job yourself. If your chainline permits you could also use "chainring spacers" to shim the ring away from the spider until the chain clears it.
Quoted: 907 Post(s)
Liked 1,567 Times
Old fart
Liked 3,332 Times
yea, File off the needed clearance, from the end of the crank spider .
Might want to have the crank off the bike to do a good job..
Thanks for the advice! I am going to take it by the LBS and try a set of 2mm chainring spacers between the chainring and spider and see if that gives enough clearance. I have a Surly SS kit in the rear so I can easily adjust the chain line to keep it straight afterwards. This would also benefit me by gaining a couple more MM's clearance at my chain stay for the chain as its a bit close anyways.
were it not a single- speed-on- a- Cassette hub, conversion..
Update. Went by the LBS and they installed 4mm spacers and new bolts. Worked great! Adjusted the spacers in the rear for the new chain line and all is good now! Thanks guys!!! Hope this helps someone else if they run into this issue.
