Sticky Di2 shifter
Sticky Di2 shifter
Old 08-22-19, 09:03 AM
MidTNBrad
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 103 Post(s)
Liked 39 Times in 26 Posts
Sticky Di2 shifter
I have 3 year old 6800 series Ultegra Di2 on my bike and when I took it out on a ride this morning I noticed that the left shifter is sticky. Itís the actuator closest to my body which shifts the chain from the small chainring to the large. It will shift but not crisply and it will return back to the home position but again not crisply. The other actuator on the same shifter is flawless as is both buttons on the right shifter. I wasnít able to look into it this morning, but it feels like there some gunk up there thatís muting the response. Can I try a few blasts of WD-40 to try to clean it out or is there something else I should use? Is it possible that thereís a spring that fell out?
MidTNBrad is offline
Old 08-25-19, 12:49 PM
TerryDi2C
Di2 fanatic
TerryDi2C's Avatar
Quoted: 15 Post(s)
Liked 12 Times in 10 Posts
Yep, each shifter contains two 'switch springs'. Have a look at the Shimano docs website (si.shimano.com) and then search by keyword: ST-6870, open the EV file (exploded view).
I would link to the file, but I can't link to files yet ;-)
(it is called EV-ST-6870-3642.pdf, look at the items labelled 5 and 6)
TerryDi2C is offline
Old 08-25-19, 07:52 PM
MidTNBrad
Quoted: 103 Post(s)
I tried some electrical contact cleaner and some WD-40 and neither helped. I'll check out the diagrams above and try to figure out my next move.
Old 09-16-19, 12:28 PM
MidTNBrad
Quoted: 103 Post(s)
Just a follow-up..... a few days after my above post, the shifter is working as expected. I guess there must have been some gunk in there that finally dissolved away from either the contact cleaner or WD-40.
Likes For MidTNBrad:
gibsen
Bicycle Mechanics
1
09-16-18 09:56 AM
SkepticalOne
Road Cycling
9
05-13-18 08:17 PM
cydewaze
Bicycle Mechanics
11
08-22-12 07:08 PM
Gerry Hull
15
02-19-11 08:23 AM
Jancouver
Road Cycling
25
04-07-10 10:41 AM
