PAS issues
PAS issues
Old 12-12-19, 01:16 PM
arsprod
arsprod's Avatar
Bikes: Fairdale Weekender Drop, Motobecane 29LTD, Cannondale H400, Basso Coral
Quoted: 160 Post(s)
Liked 14 Times in 11 Posts
PAS issues
I recently put an ebikeling waterproof kit on a 29'er. I've not been able to get PAS to work for more than a few seconds - it will start with pedaling then quits. ebikeling replaced the PAS and I get the same thing. I've asked them to send me another controller but they want the whole kit back to test and I'm not willing to do that. The throttle works and that's how I've been using the bike but I really want PAS to work. Any ideas would be appreciated!
I'm slow, go around
arsprod is offline
Old 12-12-19, 02:15 PM
2old
Quoted: 381 Post(s)
Liked 148 Times in 105 Posts
They seem to have good CS FME with them. Why not ask for a new controller? Probably they want the entire kit returned because they don't have the equipment and/or knowledge to test the controller in your kit
2old is offline
Old 12-12-19, 02:35 PM
arsprod
arsprod's Avatar
Quoted: 160 Post(s)
I did ask for a new controller and they are sending one. Looking for ideas if it's not the controller
I'm slow, go around
arsprod is offline
Old 12-12-19, 05:16 PM
2old
Quoted: 381 Post(s)
Sorry, should have seen that. Seems like the controller must be the culprit, but guess the display is a possibility. If DW answers, he'll be more definitive.
2old is offline
Old 12-13-19, 04:24 AM
Doc_Wui
Doc_Wui's Avatar
Quoted: 227 Post(s)
Liked 31 Times in 24 Posts
Two things can go wrong with PAS.First is magnet too far away. Yours looks OK. Other is the disk is on backwards.Sometimes when you do that, the PAS will work if the pedals spin backwards.There's often an arrow stamped on the disk, but sometimes that's not right either.
Is this the LCD or LED kit? I guess it doesn't matter, as I think they use the same controller now. If the new controller don't help, flip the disk.
Doc_Wui is offline
Old 12-13-19, 09:05 AM
arsprod
arsprod's Avatar
Quoted: 160 Post(s)
I'm 99% sure the disk is on correctly - arrows are clear and in the right direction, pedaling backwards doesn't set off the motor. Fingers crossed on the new controller - thanks!
I'm slow, go around
arsprod is offline
Old 12-13-19, 09:36 AM
2old
Quoted: 381 Post(s)
The PAS systems that I'm familiar with have a small red light on when they're "activated"; does yours have this characteristic?
2old is offline
Old 12-13-19, 09:45 AM
arsprod
arsprod's Avatar
Quoted: 160 Post(s)
Ooh that's cool - no, mine doesn't
I'm slow, go around
arsprod is offline
