I Need Tooth Ache Remedies
Old 02-14-20, 10:21 PM
Hondo Gravel
Basically Psychotic
Hondo Gravel's Avatar
Bikes: Too many Motobecanes
Quoted: 1925 Post(s)
Liked 1,986 Times in 1,270 Posts
Dang painful tooth an upper rear molar. I need suggestions to relieve this pain before I can get to a dentist. Feels like I have an ice pick shoved into my right eye. I have taken ibuprofen and rinsed with warm salt water and I have some Anbesol. So I got a start but any suggestion are welcomed. Like grandma’s magic toothache potions or something. HELP
Hondo Gravel is offline
Old 02-14-20, 10:29 PM
wgscott
Quoted: 2366 Post(s)
Liked 2,229 Times in 1,110 Posts
wgscott is offline
Old 02-14-20, 10:31 PM
wgscott
Seriously, it is probably an infection. Get some antibiotics from a quack. They won't do a root canal until they first treat the infection, so you might as well get a head start.
wgscott is offline
Likes For wgscott:
Old 02-14-20, 10:34 PM
Hondo Gravel
Basically Psychotic
yes I have thought of that
Old 02-14-20, 10:39 PM
Hondo Gravel
Basically Psychotic
I just finished 10 day Bactrim regimen for an infection in my finger were the pins were. But yes I could go to the local quack to get some antibiotics.
Old 02-14-20, 10:42 PM
rseeker
rseeker's Avatar
Quoted: 317 Post(s)
Liked 147 Times in 103 Posts
Try to reduce inflammation? Brush and rinse well to make sure the general environment isn't causing any more inflammation. (Don't know if flossing advisable or not in this case.) If you have Mobic laying around, consider that. Try to reduce pressure on the nerve.
(I don't really know. You need a dentist, obviously. But I feel your pain.)
rseeker is offline
Old 02-14-20, 10:49 PM
StanSeven
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 859 Post(s)
Liked 757 Times in 550 Posts
Oraljel may help. Keep ice on the tooth as well. An ice cube right on the tooth numbs the nerve.
StanSeven is online now
Old 02-14-20, 11:17 PM
clemsongirl
Quoted: 417 Post(s)
Liked 1,674 Times in 534 Posts
+1...if you can, use antibiotics of the penicillin class for the infection, get to a dentist as soon as you can and more importantly take better care of your teeth!!
clemsongirl is offline
Likes For clemsongirl:
Old 02-14-20, 11:24 PM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 14272 Post(s)
Liked 5,309 Times in 3,021 Posts
Some dentists and endodontists have a 24 hour emergency number. All they'll do is give you opiates, but it's not like that can make it worse. See if yours does.
Seattle Forrest is offline
Old 02-14-20, 11:37 PM
wgscott
Then sell them on the black market and buy a bike. That will help take your mind off of the tooth-ache.
wgscott is offline
Old 02-15-20, 01:57 AM
canklecat
canklecat's Avatar
Quoted: 4079 Post(s)
Liked 1,928 Times in 1,244 Posts
Rinse with a strong mouthwash like Listerine or generic with eucalyptol, menthol and methyl salicylate to help with inflammation and pain. Then follow up with hydrogen peroxide. I get 'em at Dollartree for a buck each.
If there's a cavity, sometimes plugging it up with a temporary filling helps. Those often contain a topical analgesic to help ease the insertion.
canklecat is offline
Likes For canklecat:
Old 02-15-20, 07:03 AM
Stadjer
Stadjer's Avatar
Quoted: 3693 Post(s)
Liked 392 Times in 296 Posts
Put a clove in your cheek near the aching tooth is a classic. But I've no experience with it myself.
Stadjer is offline
Old 02-15-20, 07:37 AM
bobwysiwyg
bobwysiwyg's Avatar
Quoted: 941 Post(s)
Liked 318 Times in 188 Posts
Sounds just like an abscessed tooth. Had one years ago. Had to address the infection first, as others have said. Once the infection was taken care of.. a root canal.
bobwysiwyg is offline
Old 02-15-20, 08:02 AM
Hondo Gravel
Basically Psychotic
Thanks all for the tips. 2020 I got dental insurance but as always they have to be in the network Rinsing with salt helped and it feels much better this morning. The molar is worn down and parts have fallen out. Age and wear I guess. Walmart trip to get all the stuff suggested. Then find a in network dentist.
Old 02-15-20, 12:50 PM
'02 nrs
royaloaker
'02 nrs's Avatar
Bikes: 1938 claud butler,1983 Basso,teledyne titan,teocali super,nrs,1993 stumpjumper fsr,Paramountain,Paramount Buell,4 banger,Zaskar LE,Colnago Master Ibex MTB,1987ish,.etc....
Quoted: 157 Post(s)
Liked 189 Times in 113 Posts
endodontists/
1 teaspoon of salt per cup of water? all I received & wasn't prepared for pain after numbing wore off.salt water worked ok. just had a root canal redo by endodontists.reg. dentist only opened 1 1/2 roots of 3;wasted $1k+ so be sure to see an endodontists.all they do is root canals.also it could be a cracked tooth,prepare for the worst-extraction.good luck!
'02 nrs is offline
Old 02-15-20, 01:18 PM
Hondo Gravel
Basically Psychotic
Going to make appointment on Monday. Not expecting good news and goodbye to my summer fun money. Health first I guess. I haven’t been to a dentist in 39 years so I’ve been lucky until now.
Old 02-15-20, 01:26 PM
skijor
on by
skijor's Avatar
Quoted: 830 Post(s)
Liked 454 Times in 279 Posts
39 years?!
Did you have a bad experience? Or are you 39?
I once woke out of a dead sleep at 2am with one helluva toothache. I could visibly see that one of my small lower front teeth was pushing out/forward. In desperation, I drove to a local 24-hour grocery store and picked up some Anbesol. Didn't know any better. This was ~20 years ago. Yes, it was abscessed. But the Anbesol had the desired placebo effect. Somehow I got back to sleep for a couple hours, and saw the dentist first thing when he opened...root canal. He drilled a tiny hole which relieved the pressure...like flipping a switch. Ahhh!
How about a nice glass or three of bourbon?
skijor is online now
Old 02-15-20, 01:31 PM
Hondo Gravel
Basically Psychotic
Nope 52 so 1981 was my last visit. I have been lucky and chronically tooth brushed. Twice a day if not more. Just time on my teeth I guess. Some bourbon sounds good. The pain is mild today but it comes on goes. Saying go to the dentist.
Last edited by Hondo Gravel; 02-15-20 at 01:33 PM. Reason: My tooth aches that’s why
Old 02-15-20, 03:01 PM
ahsposo
Rock Hard Member
ahsposo's Avatar
Quoted: 5279 Post(s)
Liked 2,419 Times in 1,457 Posts
Is this all Texans have to do? Whine about stuff? My hand hurts, I'm going deaf, my teeth are falling out...
ahsposo is offline
Likes For ahsposo:
Old 02-15-20, 03:50 PM
Hondo Gravel
Basically Psychotic
And drink beer
Old 02-15-20, 04:13 PM
ahsposo
Rock Hard Member
ahsposo's Avatar
By the way; I just had a conversation with my pharmacist about mixing Tylenol and Motrin ( or Acetaminophen and Ibuprofen) as a pain medicine. She seemed fairly stoked by the idea (I'm pretty sure she doesn't get to actually talk to a handsome guy like me very often so she was, well, excited) and explained that they work on different parts of the pain and the body metabolizes them differently. Thought that 325mg of the Tylenol and 400mg of the Motrin was a pretty good cocktail. WARNING for beer drinkers: The Tylenol can mess wit yo' liver.
This is not medical advice. It is interwebz BS and on Foo at that. Treat this advice accordingly.
ahsposo is offline
Old 02-15-20, 04:30 PM
cranky old road
Let your bike be the tool
cranky old road's Avatar
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 203 Post(s)
Liked 131 Times in 88 Posts
My father used to soak a cotton ball in bourbon and keep it on the tooth.
Never try to teach a pig to sing...
cranky old road is offline
Old 02-15-20, 04:40 PM
clemsongirl
Quoted: 417 Post(s)
Old 02-15-20, 05:28 PM
Digger Goreman
Quidam Bike Super Hero
Digger Goreman's Avatar
Quoted: 272 Post(s)
Liked 304 Times in 212 Posts
BC powder, dry, poured between tooth and gum. Worked for me....
Digger Goreman is offline
Old 02-15-20, 05:48 PM
wgscott
You need to be more pro-active. It isn't just about your teeth. There is a very clearly defined link between dental infections and heart problems, for example.
wgscott is offline
Likes For wgscott:
