How to climb up sidewalk curve on a rigid fork?
Old 03-13-20, 07:03 AM
Adis
Quoted: 8 Post(s)
Hello there. So I never learned how to climb up sidewalk curve and I want to learn it. I have a single speed bike with a rigid fork. So should I just climb up without jumping? I never bunny hop because I can't but I can jump off the curve.
Adis is offline
Old 03-13-20, 07:17 AM
madpogue
Quoted: 1503 Post(s)
Liked 575 Times in 444 Posts
A curve is a bend in the road. A curB is something you should not try to jump or climb using a bicycle. Find a nearby curb drop or driveway, or dismount. Alternatively, you could learn to build wheels and set a side a rim replacement fund, and get accustomed to rebuilding your front wheel periodically.
madpogue is offline
Old 03-13-20, 07:26 AM
Russ Roth
Quoted: 299 Post(s)
Liked 203 Times in 153 Posts
The exact same way you would with a suspension fork. For me, set right foot to 3 o'clock, shift weight forward and as the front is about to hit the curb pull up and back using your body weight. Once the front clears the curb shift your weight forward, tilt your pedals forward and pull up until the pedals and pop the back wheel up. If you don't tilt the pedals you'll just hop off them and crash. This is a TRY AT YOUR OWN RISK
Russ Roth is offline
Old 03-13-20, 10:41 AM
RoadKill
Bikes: Specialized AWOL, Specialized Roubaix, Niner Air9, Turner Sultan
Quoted: 63 Post(s)
Liked 23 Times in 14 Posts
Definitely a good skill to have is to be able to ride up a curb. You can get learn the skills Russ Roth described just riding around and practicing them individually. Just pull up to get the front wheel up and lean forward, kick back and pull the rear up. These skills come in handy for much more than just riding up a curb, you can use them for getting over a tree branch in your path, road damage, etc. Good luck!
RoadKill is offline
Likes For RoadKill:
Old 03-13-20, 11:38 AM
Miele Man
Quoted: 1100 Post(s)
Liked 643 Times in 450 Posts
I used my skill at riding up and over curbs to ride up stairs. That's a lot of fun.
Cheers
Miele Man is offline
Old 03-13-20, 11:41 AM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 2490 Post(s)
Liked 332 Times in 194 Posts
If you don't have toe clips or cleats, you can still do this.
Practice popping your front wheel up first, before you try it on a curb. It's all about speed and timing and weight shifts
Then when you can do that, you just need to unweight the back wheel and let your momentum carry the rear end up and over.
DiabloScott is offline
Likes For DiabloScott:
Old 03-13-20, 11:55 AM
Russ Roth
Quoted: 299 Post(s)
My post assumed platforms, hence get the pedals angled forward which let's the feet pull them up. Once you get a little speed you can't just let the wheel ride up, it will pinch and possibly dent the rim.
Old 03-13-20, 04:48 PM
Leisesturm
Quoted: 1574 Post(s)
Liked 178 Times in 141 Posts
I definitely have left more biking miles behind me than I have in front. If I haven't learned to bunny hop or climb curbz by now ... ah, well ...
Leisesturm is offline
Old 03-13-20, 09:40 PM
Gresp15C
Gresp15C's Avatar
Quoted: 788 Post(s)
Liked 209 Times in 153 Posts
Just a note, doing this habitually for a few months may be why I developed shoulder pain that took even longer to go away.
Gresp15C is offline
Old 03-14-20, 07:47 AM
frankenmike
mechanically sound
frankenmike's Avatar
Bikes: Indy Fab steel deluxe, Aventon cordoba, S-works stumpy fsr, Masi vincere, 92 Hardrock commuter, Dahon mu uno, Outcast 29
Quoted: 66 Post(s)
Liked 30 Times in 24 Posts
Alternative method: pull up parallel next to the curb, put down your curbside foot, lift your front wheel onto the sidewalk. Scoot forward and the rear wheel will follow. Continue on your way. Drawback: does require you to stop briefly. Advantages: won’t scare pedestrians, won’t dump you on your face.
frankenmike is offline
Old 03-14-20, 08:45 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 3358 Post(s)
Liked 808 Times in 509 Posts
A couple of things to add: First, this will all happen quickly. It takes much, much longer to explain (even when speaking) than it does to happen. Second, the weight shift forward should be quick and downward, followed quickly by the weight shift backward. The point of the weight shift is to compress the tire and make it rebound like a ball. The point of the pull back is to ďbounceĒ the tire upward.
Third, when the rear tire is close to the curb...again, it happens very quickly...twist your hands forward on the bars. This helps lift the rear wheel. You should also move your body forward towards the bar (and over the curb) so that the rear wheel is unloaded.
Why not? Mountain bikes have been going up, over and down much worse for roughly 40 years now. For a good 15 of that 40 years, we did so without benefit of suspension and for a good 25 years of that 40, we did so without benefit of rear suspension. Broken wheels donít instantly result from dropping and climbing curbs. Broken wheels result from poor technique. Iíve been ďclimbingĒ (hopping, really) curbs for most of that 40 years without issue. Iíve hopped up curbs on mountain bikes, commuter bikes, road bikes (with 23mm tires), and touring bikes with loads all without issue. I build wheels but I donít have to build them because of damage.
Stuart Black
cyccommute is offline
Old 03-14-20, 01:40 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 1962 Post(s)
Liked 522 Times in 361 Posts
This guy is doing bunny hops on a fixie with way more than enough explaining and slow-mo to get you there
Genesis 49:16-17
Darth Lefty is offline
Old 03-14-20, 04:40 PM
madpogue
Well, this is the commuting forum. Maybe it was a mistake on my part to think that the OP was inquiring about incorporating a curb-hop into her/his daily commute.
madpogue is offline
Old 03-14-20, 06:07 PM
cyccommute
cyccommute's Avatar
It was your mistake to think that Adis doesnít want to incorporate a curb-hop into his/her daily commute. Thatís the title of the post, after all. Telling someone that they shouldnít do something they obviously want to do is the problem. Yea, there is a learning curve...itís easier to learn if you happen to mountain bike...but itís not a terribly steep one nor is it going to damage the bike.
Stuart Black
Old 03-14-20, 06:43 PM
wolfchild
wolfchild's Avatar
Quoted: 1824 Post(s)
Liked 472 Times in 257 Posts
I disagree with everything that you say...I ride up and down the curbs and jump them on my rigid fork bikes everytime I commute. I am also a mountain biker and I ride my rigid fork MTB over drops, roots and rocks which are a lot bigger then a typical curb. It's fun and it's a usefull skill to have. I have never damaged any of my wheels form curb hopping.
wolfchild is offline
