Allez Sprint Di2 conversion
Old 05-07-20, 08:11 AM
kevinabbot
Quoted: 44 Post(s)
Liked 4 Times in 4 Posts
Hey so I am going to be upgrading from 105 to Di2 ultegra for my Allez Sprint. It does not have a spot for the battery. Also how difficult will it be to route all the wires for di2 through my bike and what should I do with with the location of my battery.
kevinabbot is offline
Old 05-07-20, 08:34 AM
Steve B.
Quoted: 1627 Post(s)
Liked 334 Times in 236 Posts
One of the install options is battery inside the seatpost. They sell shims for this mounting. As you have to plan for the E-Tube cables to get from the h-bar area to the derailers, you typically use the B Junction box, which sits somewhere in the lower downtube or bottom of the seat tube. You then use 3 cables out of B Junction for F derailleur, R derailer and battery, then a 4th up the downtube for the A Junction at the stem or H-Bar for the shifter connections.
But really the first question gets answered is do you have a method to route cables internally ? And related, can your b-bracket easily get removed so you can route those cables as well as install a B Junction box ?.
This site has a lot of useful info,
https://di2center.com/hardware-road-and-mtb/
Steve B. is offline
Likes For Steve B.:
