Big Ring power vs. small ring power?
Old 06-28-20, 03:55 PM
rbrides
Bikes: Specialized Diverge Comp
Quoted: 35 Post(s)
How does human physiology and performance compare when pedaling in the big ring versus pedaling in the small ring, when cog selection on the cassette makes the outputs similar?
Example
Big Ring 48T + cassette in 32T cog produces
Gear Ratio 1.50
Gain Ratio 2.99
Gear Inches 40.04
Development 3.19 meters
Speed 10.1 MPH
Small Ring 32T + cassette in 21T cog produces
Gear Ratio 1.52
Gain Ratio 3.04
Gear Inches 40.67
Development 3.25 meters
Speed 10.3 MPH,
Nearly identical.
But what is the physiological effect on fatigue, endurance, power and overall performance generally? If I climb a few miles in one versus the other, will I just plain be more worn out in one versus the other?
Is there a difference in the “power” (I don’t have a power meter!)
rbrides is offline
Old 06-28-20, 04:06 PM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 12288 Post(s)
Liked 1,454 Times in 786 Posts
Should be roughly the same. Avoid big-big and small-small combos and otherwise don’t sweat it.
Addiction is all about class.
datlas is offline
Likes For datlas:
Old 06-28-20, 04:33 PM
DaveSSS
Bikes: TWO Colnago C-RS w/Chorus 12
Quoted: 416 Post(s)
Liked 155 Times in 121 Posts
The 48/32 would be cross chained and not the best selection. The 32/21 is the better choice.
Every gearing setup has a transition speed where below that speed, the little ring is the better choice.
DaveSSS is offline
Likes For DaveSSS:
Old 06-28-20, 04:35 PM
Ilbiker
Bikes: 2016 Specialized Roubaix SL4 Sport 2021 Trek Domane SL6
Quoted: 39 Post(s)
Liked 16 Times in 9 Posts
“But what is the physiological effect on fatigue, endurance, power and overall performance generally? If I climb a few miles in one versus the other, will I just plain be more worn out in one versus the other?”
I don’t know. You will have to try these scenarios and see what the results are. Only you know your physical abilities and limits. I use both chain rings. Have 22 gears, might as well use them based on the current situation.
Ilbiker is online now
Likes For Ilbiker:
Old 06-28-20, 04:47 PM
RChung
Quoted: 376 Post(s)
Liked 203 Times in 85 Posts
If the gear ratios are the same and the cadence is the same then your speed will be the same and your power will be the same.
(There are small differences in drive train efficiency so it's not *exactly* the same -- you lose a bit of efficiency with the smaller chainring -- but they're very close.)
RChung is offline
Likes For RChung:
Old 06-28-20, 05:45 PM
Robert A
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 479 Post(s)
Liked 45 Times in 34 Posts
Physiology should be exactly the same since your foot experiences the same gear ratio. But the question I'm curious about is whether there's a difference in drivetrain efficiency. My assumption is that the big ring is more efficient because the chain doesn't have to "bend" as much. But I'm curious what others think.
Robert A is offline
Likes For Robert A:
Old 06-28-20, 07:05 PM
Dean V
Quoted: 921 Post(s)
Liked 109 Times in 72 Posts
But wouldn't the greater inefficiency of the smaller sprockets quite likely be compensated for by the straighter drive line?
Dean V is offline
Likes For Dean V:
asgelle
Quoted: 569 Post(s)
Liked 111 Times in 73 Posts
It’s not a matter of opinion or something where majority rules. The physics says larger cogs will be more efficient. The question is how large is that effect and will it be negated by differences in chain line (which would not be a factor on a fixed gear).
asgelle is offline
Likes For asgelle:
Old 06-28-20, 07:07 PM
datlas
Beyond Bogus
datlas's Avatar
Of course there is a difference. But so small as to be insignificant.
datlas is offline
Likes For datlas:
Old 06-28-20, 07:08 PM
Robert A
Quoted: 479 Post(s)
Why are larger cogs more efficient -- because the chain bends less, or another reason?
Robert A is offline
Likes For Robert A:
Old 06-28-20, 07:13 PM
asgelle
Quoted: 569 Post(s)
Yes, because the chain bends less.
asgelle is offline
Likes For asgelle:
Old 06-28-20, 09:48 PM
RChung
Quoted: 376 Post(s)
For the same gear ratio and same cadence, the small chainring-small cog combo chain travels slower than a big chainring-big cog chain. For example, a 39-13 and a 54-18 are the same gear ratio, so if you're pedaling at 60 rpm you're going at the same speed and producing the same power at the crank. However, in the 54-18 the chain travels 54 teeth per revolution, so 54 teeth per second, while in the 39-13 the chain travels 39 teeth/sec. You're traveling at the same speed, so the same power is going through the drivetrain. But the chain is traveling 38% faster in 54-18 than in 39-13 so the chain tension must be 38% lower. So in the small-small combo, not only does the chain bend more, it's also under more tension. That's why the old microdrive MTB drivetrains wore out faster.
RChung is offline
Likes For RChung:
Old 06-28-20, 09:51 PM
RChung
Quoted: 376 Post(s)
We've measured differences in drive train losses. We know it wasn't chain angle because we jury-rigged a frankencassette with small cogs inboard of large cogs so the small-small combo had the same chain line as the big-big combo.
RChung is offline
Likes For RChung:
Old 06-29-20, 04:51 AM
colnago62
Quoted: 522 Post(s)
Liked 181 Times in 110 Posts
On the track riders are moving toward large chainrings and cogs. I have seen riders with 60 tooth chainrings and larger on the front.
colnago62 is offline
Likes For colnago62:
Old 06-29-20, 05:04 AM
Amt0571
Bikes: Canyon Grand Canyon AL SL 8.0, Btwin Ultra 520 AF GF, Dahon Mu P27, Triban Road 7
Quoted: 189 Post(s)
Liked 77 Times in 50 Posts
Drivetrain efficiency is noticeably better when on a big / big combination than on a small / small one. Personally, I can notice it by feel. It can vary if you're crosschaining a lot though, as crosschaining means a loss of efficiency.
If I'm in a point where both options are acceptable, I always ride the big ring unless I know I'll need to downshift to the small ring again in a few seconds.
Amt0571 is offline
Likes For Amt0571:
Old 06-29-20, 07:04 AM
rbrides
Quoted: 35 Post(s)
Many great comments. Thank you all for contributing.
rbrides is offline
