Can't find the leak
Can't find the leak
Old 07-03-20, 12:01 PM
merlinrkd
Bikes: BMZ Performance Touring
Quoted: 19 Post(s)
Liked 9 Times in 6 Posts
Can't find the leak
Feeling dumb about this. Been fixing flats tires for 50+ years but this one isn't getting resolved. Recent 90's Conley MTB. Very clean. Deore components. Came with very recent Kenda tubes and Komfort tires. Am losing 2psi a day out of the rear. Pumped the wheel to 65 psi and submerged it in 6" of water in my laundry utility sink. Don't see any bubbles. Watched it for quite a while. Pulled the tube and pumped it up to about twice the tire size. Not a bubble. I'd like to pump the tube up more. Is there a general rule on how big an unconfined tube can be safely expanded?
merlinrkd is offline
Old 07-03-20, 12:09 PM
Iride01
Hits [ENTER] b4 thinking
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 2792 Post(s)
Liked 1,427 Times in 1,040 Posts
Right up until it bursts. I wouldn't worry about 2 psi a day. Although that is a little higher than what I'd consider normal. You check your tires before every ride don't you? I normally expect to put a stroke or two of floor pump in my tires every other day.
Iride01 is online now
Old 07-03-20, 12:25 PM
hrdknox1
hrdknox1's Avatar
Quoted: 66 Post(s)
Liked 42 Times in 31 Posts
Could be leaking from the valve core if you didn't submerge that.
hrdknox1 is offline
Likes For hrdknox1:
Old 07-03-20, 02:25 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2575 Post(s)
Liked 1,214 Times in 766 Posts
I'm with @Iride01; 2psi/day is not enough to get worked up about. If it really bothers you, pull the valve core and pour in some sealant.
JohnDThompson is offline
Old 07-03-20, 03:09 PM
Elvo
Quoted: 556 Post(s)
Liked 274 Times in 150 Posts
2 psi per day is negligible especially if there is a lot of temperature fluctuation in the storage area
Elvo is offline
Old 07-03-20, 03:21 PM
tyrion
tyrion's Avatar
Bikes: Breezer Radar
Quoted: 1819 Post(s)
Liked 1,170 Times in 554 Posts
Then back off a couple pumps.
tyrion is offline
Likes For tyrion:
Old 07-03-20, 03:27 PM
merlinrkd
Quoted: 19 Post(s)
The stem was completely under water in the sink. Neve saw a bubble. That was fully inflated inside the tire.
Old 07-03-20, 03:35 PM
merlinrkd
Quoted: 19 Post(s)
This is my grab and run a quick errand bike of the 4 I have. Used sporadically. My 2 road bikes have latex tubes so pumping is a daily deal. The Conley front wheel can go for a couple months. I'm just mystified with my leak detection methods and that 2 psi/day doesn't show a bubble.
Old 07-03-20, 04:21 PM
tyrion
tyrion's Avatar
At 2 psi loss per day the bubble will form very slowly, teeny tiny and pretty much invisible. The bubble will stick to the tube and when it gets large enough it will break away and go upwards.
You can put your hands in and get a death grip on the entire tube, wait for the water to settle and squeeze and you might get an idea of where the leak is. But do you really want to chase this?
tyrion is offline
Old 07-03-20, 04:32 PM
Crankycrank
Quoted: 403 Post(s)
Liked 277 Times in 213 Posts
Also try removing the tube pump it up to big sausage size and stretch a section at a time under water. This makes the hole a little bigger. Also check the base of the stem by wiggling it around under water. Sometimes tears at the base only show up when the stem is moved.
Crankycrank is offline
Old 07-05-20, 07:06 AM
Pop N Wood
Quoted: 497 Post(s)
Liked 401 Times in 260 Posts
New tubes are $5
Pop N Wood is offline
Old 07-05-20, 07:10 AM
tomtomtom123
Quoted: 325 Post(s)
Liked 108 Times in 77 Posts
Originally Posted by Pop N Wood View Post
New tubes are $5
No they're $3.
tomtomtom123 is offline
Old 07-05-20, 09:23 AM
davidad
Quoted: 519 Post(s)
Liked 125 Times in 105 Posts
Mount the tire and inflate the tire to at least 50% Above the max pressure on the side wall and submerge the tire. I have used this method and found a thin wire that acted as a plug and deflated the tube when I removed it.
davidad is offline
Old 07-05-20, 09:55 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 4121 Post(s)
Liked 1,609 Times in 983 Posts
2 psi per day is about the average for the diffusion rate of air out of a bicycle tube. You wonít see bubbles because the air is coming out at the molecular level through the bulk rubber. The diffusion isnít linear so you lose more at higher pressure than at lower pressure. But, generally, I expect to have to pump up bicycle tires on a daily basis.
Bottom line: If the tire goes flat overnight, thatís a puncture. If it only drops a little (<10 psi) overnight, thatís just diffusion and you shouldnít worry about it.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 07-05-20, 12:16 PM
mrrabbit
mrrabbit's Avatar
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 120 Post(s)
Liked 27 Times in 22 Posts
You should change your sig:
"Your Daily Dose - Common Sense Rx"
=8-)
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
mrrabbit is offline
Likes For mrrabbit:
Old 07-05-20, 05:37 PM
dscheidt
Quoted: 28 Post(s)
Liked 10 Times in 9 Posts
I wouldn't accept a tube that leaks 2 psi overnight on a mountain bike. On a road bike, with skinny tires at 100 psi, I'd exepect that. I run michelin airstop tubes, mostly, my bike with 700X50 tires loses about 2 psi a week (40 psi front, 50 rear). That's checked inside, so temperature isn't an issue. I would expect to be able to find a 2psi overnight leak with leak detection fluid, but maybe not in a sink.
dscheidt is offline
Old 07-05-20, 08:53 PM
cyccommute
cyccommute's Avatar
Thatís why I said that diffusion isnít linear. A mountain bike tire at 40 psi is going to diffuse at a lower rate than the same tire at 60 psi. And the 60 psi wide tire is going to diffuse at a slower rate than narrow road bike tire at 100 psi.
Stuart Black
Old 07-05-20, 09:35 PM
zacster
Bikes: Kuota Kredo/Chorus, Trek 7000 commuter, Trek 8000 MTB and a few others
Quoted: 22 Post(s)
Liked 243 Times in 195 Posts
2 psi is within the margin of error of most gauges. Why are you even worried about this? I'm happy with a 5psi range.
zacster is offline
Old 07-05-20, 11:30 PM
tFUnK
Quoted: 104 Post(s)
Liked 50 Times in 45 Posts
Check the valve where the stem meets the tube. Wiggle it around and check for separation.
tFUnK is offline
