Pedal advice needed
Pedal advice needed
Old 07-04-20, 09:11 AM
benjamin163
Bikes: Hoy Shizuoka, Condor Acciaio
Quoted: 16 Post(s)
Liked 4 Times in 4 Posts
Pedal advice needed
Hello, I get my new bike in August, Fairlight Strael.
I will be doing the odd 60 mile ride with many more 20 mile rides in between.
A fun rider at best but appreciate the comfort and stability my new bike will hopefully afford.
I specced up to Mason 4 season wheels but kept everything else standard as I don't consider myself in any way up to it.
So I'm not interested in losing the odd few grammes here or there (unless it's from my ample girth!)
What are a good pair of pedals to suit my needs?
Any help gratefully received.
benjamin163 is offline
Old 07-04-20, 09:19 AM
Mulberry20
Quoted: 190 Post(s)
Liked 57 Times in 41 Posts
My total indifference to Shimano components stops at the pedals. Without a doubt Shimano makes the best and most trouble free pedals and cleats. The 105 pedals are ideal but the Ultegra pedals might be better suited for such a nice bike.
I have used Look and Time pedals as well as the horrendous Speedplay pedals and Shimanos are the best by far.
You will get a million recommendations on Speedplay but nothing sucks more than those pedals. If you get sucked into Speedplay, remember this post six months from now.
Mulberry20 is offline
Likes For Mulberry20:
Old 07-04-20, 09:34 AM
Bigbus
Bigbus's Avatar
Bikes: In Flux
Quoted: 181 Post(s)
Liked 93 Times in 73 Posts
Pedal choice is like saddle choice, personal preference goes a long way. What style of pedal are you considering? I personally prefer platforms. I just put on a new set of Rockbros 4.10 platform pedals and love them. It feels like my feet are drawn to them like magnets and you can swap out the studs for more or less aggressive ones simply by going to the hardware store. Good luck
Bigbus is offline
Likes For Bigbus:
Old 07-04-20, 09:48 AM
blakcloud
blakcloud's Avatar
Bikes: Custom Winter Cycles flat bar road bike, Trek Domane SL6, Rivendell Sam Hillborne, Brompton S/M3L (modified)
Quoted: 430 Post(s)
Liked 127 Times in 91 Posts
Is your new bike meant to compliment your other two bikes the Hoy and Condor? Or is it a replacement?
Normally I would say have at least one bike with platforms, they just make life simpler for those short jaunts to the store. Barring that, I think a Shimano SPD pedal might be something to consider.
Buying a clip-less pedal means purchasing new shoes which is an added expense.
blakcloud is offline
Old 07-04-20, 10:22 AM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 311 Post(s)
Liked 237 Times in 141 Posts
agreed - although a committed Campagnolo fan, I have Shimano Ultegra SPD-SLs on my good bike - well over 10 years old and have been faultless - i have never had an accidental pull-out- and the only time engagement has been tricky was when the cleats were gunked up with mud or slush - easily fixed. Also easy to maintain. If/when these finally wear out, another pair of SPD-SLs without question
Litespud is offline
Old 07-04-20, 10:37 AM
Mulberry20
Quoted: 190 Post(s)
I have Shimano pedals on two Campagnolo Chorus groupsets and it hurts a bit to look at them but the performance is without even the slightest criticism.
Old 07-05-20, 02:01 AM
Toespeas
Quoted: 49 Post(s)
Liked 11 Times in 11 Posts
your question is way to vaugue ,
are you doing off road or gravel ?
what kind of shoes do you wear ?
do you want clipless or flats maybe cages ?
my observations on clipless pedals is their is 3 main choices and fun minor choices , so you have shimano , look , and speed play .
shimano makes a decent pedal and has 3 cleats to give you more or less float , look are the original and offer much the same but i have found their ZERO float is true and doesnt wiggle at all as much a shimano , and i have never used speed play , but i have heard speed plays gives you the most amo8unt of adjustability , compared to any system .
i dont use time or crankborthers , but i hear things , and if you need flat peds i have no clue .
one note about shimano , is they love too trickle down their tech , so their old dura ace style is a new lower generic model .
and i wouldn't look to peds to looks grams on a bike , carbon cranks are ok but you really dont want carbon peds s they will break and get chewed up over time !
Toespeas is offline
Old 07-05-20, 03:30 AM
benjamin163
Quoted: 16 Post(s)
My son will inherit the Condor and the Hoy is just for commuting. Excuse my ignorance, what are 'platforms'?
At the moment on my Hoy I have just normal flat pedals.
On my condor I have pedals that accept three pin cleats.
Old 07-05-20, 03:36 AM
benjamin163
Quoted: 16 Post(s)
Thanks for the reply.
I will only really be riding on the road.
At the moment I wear shoes with three bolt cleats and I guess I've got used to that.
People have replied talking about 'platforms' but I don't know what they are!
You mention 'clipless'. What is that?
And are 'flats' for shoes that you can walk with?
Also what are cages?
Seems like there are more options than I thought!
Old 07-05-20, 06:08 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2173 Post(s)
Liked 538 Times in 371 Posts
This implies that you currently use cleats. What do you find deficient about your current pedals and cleats that makes you want to change them?
"Platform" pedals have a flat surface to accept cleatless shoes, e.g. "street" shoes.
Those are pedal/cleat systems that work without traditional toeclips and straps. Your three-bolt shoes are designed to work with such a system.
Yes. some pedals are available with a platform on one side for street shoes and a cleat mechanism on the other side to work with bike shoes.
"Cages" is a common misnomer referring to toeclips, which in combination with a strap and optionally a slotted cleat, secure your foot to the pedal in a manner similar to that of modern clipless cleats and pedals.
JohnDThompson is offline
Old 07-05-20, 07:43 AM
Gconan
Bikes: Norco search xr
Quoted: 182 Post(s)
Liked 123 Times in 75 Posts
With Shimano SPD's you can walk around some.
Gconan is offline
Old 07-05-20, 07:50 AM
Juan Foote
LBKA (formerly punkncat)
Juan Foote's Avatar
Quoted: 1150 Post(s)
Liked 127 Times in 95 Posts
Probably already been said a few times....
Where is comes to on bike comfort and stability for my (foot) I prefer my Shimano 105's. The ONLY thing I don't care for with them is there is almost no float. Very secure fit, nice click, and a big platform for the bottom of your foot which, according to shoe selection may or may not matter.
Where is comes to convenience and the ability to walk around while out riding, I prefer Egg Beaters. They are simple to get in, have good float, and offer (the choice of) a shoe from very stiff competitive type bottoms to sandals, according to your desire. The only aspect of them I don't like is, and particularly in respect to my prosthesis, they are not a solid enough "click in" that I feel secure standing and pedalling (just for that side). I also prefer the ease of release with them as opposed to the 105.
For my beater social ride bike I use platforms based on the DX style.
Juan Foote is offline
Old 07-05-20, 07:56 AM
roth rothar
roth rothar's Avatar
Bikes: Raleigh Technium, Cannodale SR600,Trek 520, Specialized Rock Hopper, Scott CR1 Pro
Liked 3 Times in 3 Posts
I like the Shimano M520 pedal, it is double sided which make it easier to clip in and is compatible with bike shoes that you can walk in.
roth rothar is offline
Likes For roth rothar:
Old 07-05-20, 08:05 AM
Mulberry20
Quoted: 190 Post(s)
Original poster, just buy the Shimano Ultegra pedals they come with the yellow cleats and enjoy the bike.
