Shimano 600 brake lever ?
Old 07-09-20, 01:56 PM
mark d
Bikes: panasonic 1987 dx-5000
Quoted: 33 Post(s)
i tried search fist but no joy
i wrongly assumed the shimano 600 brake levers on my restoration were identical. they are mirror images on the internal when looking from the handlebar side if that makes sense. i can find no indication which is left and right with the serial #'s etc
edit: woops they are clearly marked if hoods are peeled back far enough
mark d is offline
Old 07-09-20, 02:14 PM
mark d
Quoted: 33 Post(s)
never mind. they are clearly marked if you peel the hoods back far enough. if you saw my hoods you would know why i am careful with them. they are falling apart. is there an aftermarket hood that fits the shimano 600 levers ?
thks
mark d is offline
Old 07-09-20, 02:21 PM
Iride01
Iride01's Avatar
Bikes: '20 Tarmac Disc Comp '91 Schwinn Paramount '78 Raleigh Competition GS
Quoted: 1430 Post(s)
Liked 379 Times in 292 Posts
Is there a part number stamped on them somewhere? BL-6208 or BR-6208?
BR= right brake lever
BL= left brake lever
Don't know that it makes a difference if you'd rather have your levers angle the other way on the bars.
EDIT:
Oooops.... I'm wrong. Thats the reach on the calipers I think.
Iride01 is offline
Old 07-09-20, 07:07 PM
Miele Man
Quoted: 1082 Post(s)
Liked 630 Times in 437 Posts
Aero or non-aero brake levers?
Cheers
Miele Man is online now
Old 07-10-20, 04:51 AM
mark d
Quoted: 33 Post(s)
Cheers
what is the difference ?
as per a site i use for info on my bike that someone here was kind enough to pass on:
Brakes: Shimano 600, alloy side pull with aero levers
thks
mark d is offline
Old 07-10-20, 06:22 AM
Miele Man
thks
I have 600EX non-aero brake levers and the hoods are the same for the left or right levers. I have a pair of the 600 Aero levers pre-Ultegra and iirc the hoods are left or right. Non-aero brake hoods don't fit the aero brake levers.
It'd be a real help to know exactly which model of 600 aero brake lever you have.
Here is one type that might work.
​​​​​​​https://www.amazon.ca/BRAKE-VINTAGE-...K1EFPY74NKY52Z
Cheers
Old 07-10-20, 07:06 AM
mark d
Quoted: 33 Post(s)
miele man, thks for the reply and link. my levers have BL 6209 stamped on them. does that tell us anything ?
by the way, just replaced the cables and housing (jagwire) what a difference
thks
mark d is offline
Old 07-10-20, 12:01 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Bikes: Lots. Just...lots.
Quoted: 1291 Post(s)
Liked 383 Times in 206 Posts
Shimano made many similar looking but completely different brake lever bodies in the mid 80's, which is where 6209 comes from.
The only other lever body that uses that hood is a DA 7401.
I know people who buy used 6209 lever sets just for the hoods for their DA levers.
Am not aware of anyone producing aftermarket hoods for those levers or anything that comes reasonably close.
rccardr is offline
Old 07-10-20, 12:05 PM
mark d
Quoted: 33 Post(s)
hey rccardr, thks for the info. i wrapped em with white electrical tape and they look better...not great but better
mark d is offline
Old 07-10-20, 01:28 PM
Miele Man
Hi there OP.
I checked my 600 aero brake lever hoods outside and they do have a small L or R on the outside part of the hood that faces towards to opposite brake lever.
You might be able to find some NOS ones on Ebay or something else that's compatible with your brake levers.
Good luck.
Cheers
Old 07-10-20, 03:25 PM
mark d
Quoted: 33 Post(s)
thks miele man
mark d is offline
