Is It Possible To Identify A Reynolds 531 Frame When There's No Stickers?
Old 05-05-11, 05:22 AM
robbied196
robbied196's Avatar
Bikes: Harry Hall, Vitus 979, Viscount Aerospace, Dawes Galaxy
Quoted: 5 Post(s)
Liked 7 Times in 1 Post
Any Tips?
robbied196 is offline
Old 05-05-11, 05:24 AM
shorthanded
you can tell something about the alloy steel is comprised of by the sparks it throws when you cut it... you can try that.. but it makes resale a little difficult.
shorthanded is offline
Old 05-05-11, 05:30 AM
robbied196
robbied196's Avatar
Quoted: 5 Post(s)
lol I'm a bit worried about damaging the paint!
Old 05-05-11, 05:36 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1692 Post(s)
Liked 154 Times in 115 Posts
Pull the fork and examine the steerer tube for any markings there. My Trek 720 has the words REYNOLDS 531 stamped there, as well as the number 720 cut in with a Dremel. On the other hand, my Fothergill --which apparently came with a 531 decal-- has an Accles & Pollock stamp on the steerer.
Other than that... well, what's the seat post size? Reynolds butted tubing typically has a 27.2 post, though there are exceptions.
rhm is offline
Old 05-05-11, 06:53 AM
John E
feros ferio
John E's Avatar
Quoted: 815 Post(s)
Liked 169 Times in 135 Posts
The relationship between seat post size and seat tube OD will distinguish butted from straight-gauge. As rhm noted, 27.2/28.6 (26.4/28.0 for French bikes) indicates butted. Straight-gauge 531 bikes are usually more like 26.4/28.6.
A given frame builder may leave additional hints. All Capo frames exported to the U.S. ca. 1960 were full Reynolds 531, but the ones w/ butted tubing had additional brazed-on ornamentation at the tops of the seat stays, on the rear dropouts, and on the fork crown, which their straight-gauge cousins lacked. (Note diagonal 531 decal on first specimen and cursed bike license sticker on second one -- why did people so frequently do this?)
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
John E is online now
Old 05-05-11, 07:29 AM
Ex Pres
Ex Pres's Avatar
Quoted: 393 Post(s)
Liked 43 Times in 31 Posts
Strip the paint, then you can see a faint "Reynolds 531 butted tubing" etched onto the tubes. It seems to be easier to find on the seat and down tubes than the top tube
I found out one of my Columbus SL decaled frames was Reynolds 531 that way
Edit: rhm commented below that he did not see any markings on his. I will tell you that the lettering is not just faint, it's extremely faint, particularly after any mechanical means of cleaning (blast, sandpaper, etc) the final remnants of paint from the tubes. And it's closer to the ends than the middle of the tubes. Even after finding them, it wasn't easy to "re-find".
72 Frejus, Holdsworth Record & special CNC / 74 Italvega NR / c80 ?French? / 82 Raleigh Intl MkII / 83 Trek 620 / 87 Centurion IM MV / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 10 Vassago Fisticuff
Ex Pres is offline
Old 05-05-11, 07:39 AM
rhm
multimodal commuter
rhm's Avatar
When I had all the paint off my Fothergill frame, I found no stampings on the tubes beyond the Accles & Pollock stamp on the steerer tube. The ghostly shadow of a 531 decal was evident, though.
rhm is offline
Old 05-05-11, 07:46 AM
RobE30
Wherever I may roam....
Bikes: A few bikes
Quoted: 8 Post(s)
On my Free Spirit, Reynolds 531 is stamped into the upper inner side of the fork blade. Also, on my Astra (French 26.4 seat post) there is the faint remnants of a French 531 decal at the top of the seat tube
RobE30 is offline
Old 05-05-11, 08:21 AM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 986 Post(s)
Liked 806 Times in 524 Posts
See if you can find out what model your frame is from matching it to others and manufacturer catalogs. Best method I've found; provided catalogs are available.
-Kurt
cudak888 is offline
Old 05-05-11, 09:20 AM
Uptown
Uptown's Avatar
Bikes: 1982 Austro-Daimler Vent Noir II; 1979 Trek 714; 1970 Peugeot PX10; 1968(?) Peugeot PX10; 1973 Raleigh International; 1970 Raleigh International; 1984 Peugeot PSN10; 1985 Davidson Discovery; 1979 Austro-Daimler Puch Force II
Flick-tap at the center of your main tubes with your index fingernail. Is the sound produced a bright, clear ring? ...or is it more of a dull thwak? I find that my butted 531 bikes make a ringing sound (almost like crystal), while my Raleigh Grand Prix and junkyard Peugeot mixte make a noticeably duller sound.
Uptown is offline
Old 05-05-11, 07:35 PM
old's'cool
curmudgineer
old's'cool's Avatar
Bikes: 2 many 2 fit here
Quoted: 227 Post(s)
Liked 30 Times in 21 Posts
Unfortunately, most non-destructive methods of material identification rely on non-deterministic discrimination. And the deterministic methods tend to be not only destructive (at least partially), but also expensive.
Geoff
"There is no Fail without Try" - Yoda Simpson
old's'cool is offline
Old 05-05-11, 07:52 PM
conspiratemus1
Used to be Conspiratemus
Quoted: 139 Post(s)
Liked 83 Times in 57 Posts
This has always confused me. The top end of a seat tube (where the seat post enters) is not butted, at least when you consult those charts that describe the gauge of the various frame tubes. So all else being equal (and it never is, that's why it's confusing) butted and non-butted tubes should take the same seatpost. Yet they don't. This implies that cheaper non-butted tubing is thicker throughout, which makes sense when you think about it.
conspiratemus1 is offline
Old 05-05-11, 08:01 PM
sailorbenjamin
26 tpi nut.
sailorbenjamin's Avatar
Location: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
Quoted: 8 Post(s)
look inside the tubes with a flashlight. If there's a seam, it's not 531
I have spoken.
sailorbenjamin is offline
Old 05-05-11, 08:04 PM
Ex Pres
Ex Pres's Avatar
Quoted: 393 Post(s)
On a seat tube, the thicker butted section is only at the bottom, so the post is inserted into the "thin" cross section of the tube.
Ex Pres is offline
Old 05-05-11, 09:30 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2169 Post(s)
Liked 534 Times in 368 Posts
The ends of most Reynolds tubes were stamped:
This is usually most evident on the steer tube, but it sometimes can be discerned on other tubes as well. N.B. on smaller frames in particular, the stamped areas of the tubes may have been lost when the tubes were trimmed.
JohnDThompson is offline
Old 05-05-11, 10:04 PM
seypat
Quoted: 1521 Post(s)
Liked 412 Times in 295 Posts
Speaking of stamping, was it common for older frames to have the angle degree of the various tube joints stamped into them? My Lejeune(not 531) has a 72 and 61 stamped on the top and down tube lugs respectively. It also has an angle # stamped on the seat tube lug as well.
seypat is online now
Old 05-05-11, 10:50 PM
cudak888
cudak888's Avatar
Quoted: 986 Post(s)
Very common - lugs continue to be stamped or casted with these markings today, though most builders fill or file them off.
-Kurt
cudak888 is offline
Old 05-06-11, 08:41 AM
CV-6
If I own it, I ride it
CV-6's Avatar
Bikes: Lejeune, Raleigh, Raysport, Jan De Reus, Gazelle, Masi, B. Carré, Springfield, Motobecane, John Howard, Greg Lemond
Quoted: 400 Post(s)
Liked 160 Times in 95 Posts
BE aware that even if the sticker says all 531, it may not be. Two of my "all 531" Lejeunes have Nervor steerers.
Lynn Travers
Photos
CV-6 is offline
Old 05-06-11, 09:48 AM
JohnDThompson
Old fart
Would you feel bad if you found one of these in your "all 531" frame?
Old 05-06-11, 11:07 AM
CV-6
CV-6's Avatar
Quoted: 400 Post(s)
I don't feel bad. It is just a statement of fact.
Lynn Travers
Photos
CV-6 is offline
Old 05-06-11, 01:46 PM
cudak888
cudak888's Avatar
Quoted: 986 Post(s)
Were those Campagnolo steerers stamped as shown in the catalog, or are they yet another unmarked Campagnolo part?
-Kurt
cudak888 is offline
Old 05-06-11, 02:59 PM
JohnDThompson
Old fart
-Kurt
They were stamped as shown.
Old 07-10-20, 08:18 AM
ViaBike
ViaBike's Avatar
Location: The state with just 1 neighbour in contiguous US
Bikes: Recycled Brands
Still debating if a 1970's Velosolex St. Tropez (< 25 lbs) that shows no seams (per salorbenjamin) and passes Uptown's ring test above has some 531 tubing.
ViaBike is offline
Old 07-10-20, 04:33 PM
non-fixie
Shifting is fun!
non-fixie's Avatar
Bikes: Yes, please.
Quoted: 1409 Post(s)
Liked 753 Times in 424 Posts
Pictures for reference. A fork I found with an early seventies Mercier frame.
Peace!
non-fixie is offline
Likes For non-fixie:
puchfinnland
Classic & Vintage
31
11-22-12 05:21 PM
zazenzach
Classic & Vintage
18
09-29-12 05:22 PM
pstock
Classic & Vintage
22
09-01-10 10:54 AM
TrekWyoming
Classic & Vintage
37
07-26-10 05:51 PM
