Another Chain Waxing Thread
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 762 Post(s)
Liked 4,029 Times
After messing with various chain lubes and the mess they leave for the last year, I decided to try waxing the chain instead. It didn't hurt that my wife was getting rid of a functional Crock-Pot (with missing control knob) in favor of one of those fancy Pioneer Woman models. It's now my chain cooker.
Having noted significant differences in the various lubes I've tried, I was skeptical of waxing. But, I think I'm a convert. Just the lack of mess is reason enough. It's nice to come back from a ride without grease marks on my leg. At about 400 miles I noticed the chain starting to get noisy. I changed to a freshly waxed chain at 448 miles. I did the change without gloves and my hands weren't even really dirty.
Here's a pic of the cassette at about 250 miles. At the same mileage with lube it would have been nasty!
Conditions were dry for the entire 448 miles, so it will be interesting to see how it works out this fall. For now, I'm quite pleased.
Likes For MattTheHat:
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Tangent follows:
From a materials science standpoint, it's an interesting problem with no single solution. You could make a better chain that holds onto its lubrication better somehow, or use materials with less inherent friction in the rollers and joints. You could abandon a chain entirely and use a belt or driveshaft, since you can shield the bearings on the driveshaft better than the exposed rollers. But cheap chains operate just as efficiently as wonderchains, just with an expected shorter service life.
I wonder how NASA would design a bicycle that could operate reliably without supplies like lube...
Likes For ksryder:
Quoted: 762 Post(s)
Liked 4,029 Times
Likes For sdmc530:
Non omnino gravis
If you're a normal person, buy a bag of MSW and use it for 2+ years, when it runs out, buy another bag.
If you're not normal, you can use this:
The Doctor's Own Chain Brew
-6 to 8oz paraffin wax
1 puck of Mr Zogs Sex Wax. (Temp range doesn't seem to matter. I'm currently using cool water blend)
-2floz paraffin oil
-1floz Slick50 Recharged High Mileage Engine Treatment
I average around one month between dips, so ~500 miles per application. The additives make the chain hold on to some road contaminants a little more than straight wax, so running your fingers along the chain comes away with a sorta light-gray smudge, but it's not staining, and it just wipes away. I think it's just dust and general road grime. But far less flaking, and it can stand up to moisture significantly better than straight wax. Bonus, smells of coconuts.
I've been tinkering with the blend since I started doing hot wax (three crockpots in service) and the above-listed blend is what I've been using for the past 6-7 months without changing the recipe. As there's less flaking/dripping, I can go a long time without having to add ingredients to the pot-- one of the pots hasn't been touched in those 6-7 months.
-2floz paraffin oil
Likes For DrIsotope:
Quoted: 762 Post(s)
Liked 4,029 Times
-2floz paraffin oil
-2floz paraffin oil
Quoted: 762 Post(s)
Liked 4,029 Times
-2floz paraffin oil
-2floz paraffin oil
Jedi Master
I use the UltraFast Chain Lube recipe, which is 1lb of household paraffin wax, 5g of pure PTFE (Teflon) powder, and 1g of pure molybdenum disulfide (MoS2).
Likes For kingston:
Non omnino gravis
Paraffin oil = lamp oil. They say it's supposedly kerosene, but mine is fairly viscous. I initially tried it after seeing a waxing video on YouTube where the guy added lamp oil, presumably to soften the straight paraffin. It does make the wax softer without adding tackiness, so it stays in the mix.
This is where I started as well, but I saw absolutely no perceptible difference between the UltraFast recipe and straight paraffin. No change in shift quality, chain noise, or longevity. My biggest overall change came from softening the wax by mixing in the Mr. Zogs.
Jedi Master
Quoted: 152 Post(s)
Liked 173 Times
I used to wax but after moving I started riding again and for some reason decided to go back to conventional lubes. It didn't take long at all to remember how much I hated the black, grimy drivetrain and all that comes with it. After a couple of weeks, a new mini crockpot & a new bag of MSW I was back on the waxing train and I'm never going back. I have 3 chains so I don't have to rewax so often and run them 300 miles before swapping out for a fresh chain.
I also bought some YBN QRs11 quick links they claim you can reuse up to 5 times before discarding to cut the cost of swapping out quick links so often. Still working through my stock of KMC links so I haven't had a chance to try them yet.
Likes For August West:
I'm averaging almost 300 miles/wk on regular lube. I lube my bike twice per week, each time taking 2 minutes, that's less than 5 minutes spent lubing per week. And I don't get chain tatoos on my legs.. I must be doing something right.
Non omnino gravis
I rotate two chains on each bike. About 90 seconds, once a month. Nothing ever needs to be cleaned.
Likes For Dr.Lou:
Likes For sdmc530:
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
-2floz paraffin oil
-2floz paraffin oil
Jedi Master
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Just from the other perspective because there's no right or wrong here, only preference and riding habits. I gave up on wax the first time I rode the bike with the waxed chain in a rainstorm. I just don't want to use something that might crap out on me 75 miles into a 150 mile ride.
Quoted: 3352 Post(s)
Liked 1,056 Times
While your chain may be clean, the fact remains wax is NOT a lubricant.
Jedi Master
Likes For kingston:
Jedi Master
Tragically Ignorant
Liked 9,098 Times
There are plenty of good reasons not to run waxed chains, but I don't think crapping out in the rain is one of them. I've ridden 1,000's of km's of brevets in all kinds of weather on waxed chains. I toss a little bottle of squirt in my bag if there's rain in the forecast for a long ride, and I've only ever had to use it on a wet 600k and 1,200k. Never on a single day ride even if it's wet. I rode a dry 1,000k last month on a single waxed chain with no additional wax required for the whole ride.
I'm used to grease and don't mind it, so I think I'll just stay being the old dog. More power to you kids with your stuff that works, too.
