Winter Studded Tires
Quoted: 5877 Post(s)
Liked 3,445 Times
Buy front and rear.
Quoted: 4227 Post(s)
Liked 2,488 Times
Front and rear will make your ride safer and easier then just having one on the front.
Bikes: FOCUS BLACK RAIDER 2.0
Quoted: 29 Post(s)
I think it really depends in what conditions you want to use it .
If the track is really icy, the ride is not fun anymore without them. However, a little snow can be handled by normal tires I would say.
Quoted: 608 Post(s)
Liked 352 Times
One is all really need and it goes on the front. You don't want the front wheel to wash under you when on ice. Winter tires with studs are for ice, not snow. To be safe I would pay a pair for front and back.
I use front and back and never regretted that decision.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1105 Post(s)
Liked 213 Times
I've been winter riding since 2009, regularly. Here's my experience:
Front studded tyre is a smart choice. As for the rear, if you don't have any hills, you might just go with a regular knobby tyre, without studs. Safer option is using both studded. If you have long winters with lots of snow and ice, I'd recommend that.
I wrote an article about types of (studded) tyres, per conditions and types of snow, might help:
Bicycle winter tyres
This topic should be in winter cycling, though.
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
Goodness gracious: NO. Buy both. Otherwise, you are essentially asking "which end of your bike would you rather slide out on you while riding on the ice?".
Hit up CL and fleabay right now while the demand is low, so you can find a good off-season deal.
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
You need two.
You'll fall with only one. I suppose you can choose how to fall - front wheel falling - face into the pavement, rear wheel - ass into the pavement. Both result in a fall, possibly in front of a car.
Work: the 8 hours that separates bike rides.
Quoted: 5219 Post(s)
Liked 3,564 Times
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Another vote for two here.
Also, don't buy "homemade" ones. Spend the $100 for the pair and never worry about ice again.
(I've tried homemade ones, they didn't work well. Production ones are 1000x better. I've also tried only one, it doesn't work. If it's icy enough to need a studded tire on the front, you're not going to have traction on the back to start from a stop.)
Buy two. Seriously. Buy two name brand ones.
Here, they're on sale at REI.
This for the back.
https://www.rei.com/product/780258/n...e-tire-26-x-19
This for the front.
https://www.rei.com/product/792642/n...-tire-700-x-40
Less than $100 for the pair.
It's what I roll with on my "bad weather" winter mountain bike.
I have schwalbe marathon winter studded tires on my "fair weather" 700c winter bike. Yes, you have two winter bikes if you live in a place that has winter 7 months of the year.
This for the back.
This for the front.
Mostly harmless ™
Liked 213 Times
However, tyre choice depends on the conditions. I ride on flat lands, with very little ice. If winter is mild, with little snow, I often combine front studded, since loosing front wheel is an instant fall, just in case I run into a frozen patch, with a knobby rear. Just take it easy on turns.
Hell, I rode in snow and ice before I knew studded tyres existed. Lower pressure, lower speed and a bit of good old common sense.
If You Chain Up the back, Then You only need the front one.
This tire: 2, is what I've Used .. Suomi-Nokian Mount and Ground W .. I know you people depend on revues.
Here you go : Nokian Mount & Ground Tire Reviews - Mtbr.com
Source: Made in Finland
Bikes: ...a few.
Quoted: 2009 Post(s)
Liked 405 Times
Schwalbe Winter Spike Road Tyre - K-Guard | Chain Reaction Cycles
https://www.chainreactioncycles.com/c...d/rp-prod80796
Even cheaper than I thought.
Two Nokian Mount and Grounds are all you need.
Lots of good answers here. I prefer two Schwalbe Marathon Winters. also check out the Winter Cycling forum for lots of good winter info. Winter Cycling - Bike Forums
Quoted: 1062 Post(s)
Liked 665 Times
I've experimented with: A single studded tire in front, and studs on both wheels.
During my winter commutes, I see plenty of people riding with plain street tires, so it really comes down to the specific climate and conditions of your ride, and how secure you want to be. My winter bike is as much of a salt bike as a snow bike. I switch to it when they start salting the roads. That's usually a few weeks before there's any real ice danger. Further into the winter, two things happen in my locale:
1. Storms can blow in during the day with no warning, turning my route into a sloppy mess.
2. Side streets are at a low priority for plowing, and can turn into a rutted, frozen obstacle course. I can't avoid some of those streets.
In those cases, it's not about slipping on ice, but being able to make any forward progress at all, and holding a reasonable line if there's any kind of traffic. The weather can go from pleasant to vicious in a matter of hours, and I don't want to be stranded at work.
I use the Nokian Mount and Grounds, I think type 160.
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
Anything with carbide studs is good in ice. Marathon Winters are good and roll well but are hopeless if there's a lot of snow; their block tread is entirely side to side, when I had them, in heavy wet snow on a crowned road, every time I applied power the rear wheel flew out from underneath me (sliding directly sideways). I now have Nokian W240s which have four rows of studs which allow me to climb out of ruts. Ruts will kill you if you aren't careful.
Jet Jockey
I did last winter in St Paul without studs. Slow and careful, and constant vigilance will get you where you're going. I didn't spill once.
This winter I'm using studs, simply so I can make better time, and put down more power. I watched my friends with studs pedal with confidence through some surfaces that were proving very treacherous for my tires.
Señior Member
Quoted: 446 Post(s)
Liked 8 Times
I could probably get away without studs if I only rode on certain days. However, there are days when the roads are covered with ice and I have hills. Even the studs are skidding on the ice, and I would have a hard time walking. I wouldn't want to try it without studs. On those days you absolutely need both front and rear, otherwise the rear would just spin and never move you.
