non studded mtb 26 tires, what pressure for -10c?
100% Certified Beast
Quoted: 273 Post(s)
Liked 15 Times
The tires tell me to pump it from 30-80 psi but I am not sure ideal pressure. What parameters should I consider and what pressure work best? Both front and rear tires same pressure? I have a 26x2 rear and 26x2.2 front.
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
Traction will be enhanced when the tire can conform to the pavement. Lower pressures will help. Try 30. Try 40. Try 25. Experiment a bit. See what works for you. The answer depends a lot on local conditions. I often run at pressures lower than the ranges printed on my tires.
Yeah, experiment. As we all do ;-)
Going with a tip on these forums, I now lower the pressure on my front tire slightly more than my rear tire. Rear tire carries more weight (more puncture sensitive) so don’t go too low there. Lower pressure = more traction, contact surface but sometimes more puncture sensitive.
E.g. (F) 50 psi & (R) 60 psi when the weather is sweeeeeeet, and when raining I lower pressure maybe down to (F) 40 psi & (R) 50 psi.
[ 50-622 28x2.00 35–65psi ]
I think when icy you can go very low, just remember you may work-out a little more as lower pressure means less velocity too.
Quoted: 5224 Post(s)
Liked 3,581 Times
jsdavis
Bicycle Mechanics
7
07-11-14 07:47 AM
Ozonation
General Cycling Discussion
4
09-12-13 04:02 PM
