Nutted calipers, looking for ideas.
Death fork? Naaaah!!
The early '80s Klein build requires nutted brakes. Tektro double pivots are out. Looking for guidance in selecting something semi period correct.
Top
Top
aka: Dr. Cannondale
Quoted: 2157 Post(s)
Liked 3,427 Times
Believe early 6207’s were available nutted, as were the first couple generations of Dura Ace. Campagnolo, of course, and Galli both made some nice nutted caliper brakes.
Bunch of Dia Compe’s, too.
Bikes: old ones
Quoted: 26456 Post(s)
Liked 10,416 Times
...when it is working well, I use VeloBase to figure out what is "period correct". Although the component dating is sometimes an estimate, it's good enough for me.
BTW, if you take off the screened lettering on those Tektro dual pivots with acetone, they are pretty anonymous looking. I have done that on a couple of bikes, in pursuit of function over form.
Bikes: 1970's Piasentin Super Vitus 971, 1979 Carlton Professional, 2005 Trek 5000, 2011 Niner EMD, 2018 Argon 18 XRoad, 1990 Diamondback Master TG Centurion
Quoted: 56 Post(s)
Liked 73 Times
Look for a set of Shimano 600 BR-6200 or Golden Arrow BR-S105. Both came with nutted options.
EDIT: There's an eBay store selling NOS Dia-Compe nutted brakes for $20 a pair.
https://www.ebay.ca/itm/Vintage-Dia-...53.m1438.l2649
Dia Compe Nutted Caliper Brakes
Shifting is fun!
Bikes: Yes, please.
Quoted: 2203 Post(s)
Liked 4,650 Times
You need not limit yourself to nutted calipers. Should you find a nice period correct pair with recessed bolts, they can be used as well, no drilling required.
The front caliper goes on the rear, where it is mounted with a normal nut, ring and spacers. The rear caliper goes on the fork, using a 'coupling nut' and is tightened with a bolt. Like this:
(picture respectfully lifted from m-gineering.nl, where you'll find the instructions - use Google translate if you don't read Dutch)
Used this a couple of weeks ago on my Bovid Blues Beater, and was quite pleased with the results.
EDIT: it seems the forum software doesn't accept links to http sites. Remove the "s" manually from the url for the m-gineering website and it will work.
Likes For non-fixie:
Top
Likes For top506:
Veteran, Pacifist
Quoted: 3907 Post(s)
Liked 4,859 Times
@non-fixie - thanks for 'coupling nut'. Why am I the guy who never knows about good alternative solutions?
Thankfully, I didn't needlessly drill forks..
Question for anyone =
Where can I buy a coupling nut for my spares inventory? Maybe 2.
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
+1 Two more ideas: 1. the Gran Compe "campy clone" of the era work well, even if their quick release cam doesn't work as cleverly as the campy. 2. the DiaCompe SC self centering sidepulls - these work well despite using cheap cable stop hardware, and seem to have much stiffer/stronger arms than most other DC sidepulls of the era.
Shifting is fun!
Bikes: Yes, please.
Liked 4,650 Times
@non-fixie
Quoted: 1610 Post(s)
Liked 2,216 Times
I am surprised Suntour Superbe/Pro is not mentioned. The Pro's are excellent brakes with the right pads and levers. I have a set on the Trek760 and they stop as well as most of the DP calipers I have.
Likes For SJX426:
