ID help Columbus Fork/Suntour Pro
Old 02-24-20, 10:42 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
Liked 41 Times in 30 Posts
Looking for ID help with this Columbus fork. Looks like full chrome under paint, inside lug has a heart cutout and Suntour Pro fork ends.
r0ckh0und is offline
Old 02-24-20, 10:56 AM
francophile
PM me your cotters
francophile's Avatar
Quoted: 807 Post(s)
Liked 231 Times in 177 Posts
Do I notice rifling inside the crown opening?
I almost always associate hearts with Derosa or Benotto. But not familiar enough with either to know if they ever built anything with Suntour ends & DOs
EDIT: Almost forgot about J.P. Weigle.
francophile is offline
Old 02-24-20, 11:07 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
Rifling........yes
Old 02-25-20, 12:10 AM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 533 Post(s)
Liked 171 Times in 139 Posts
But, what sort of "rifling"? 'Cause I could think this might just as well be a Japanese fork as Italian, despite the Columbus decal. The forkcrown looks fairly "Tange" and a good bet the paint is not original. Not many Italian builders ever used SunTour forkends (AFAIK)!
unworthy1 is offline
Likes For unworthy1:
Old 02-25-20, 08:12 AM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 481 Post(s)
Liked 158 Times in 109 Posts
Sure looks an awful lot like the chrome Tange #1 fork I've got. This one has Tange dropouts, I believe. Very lightweight (1.54 lbs.). What does your steerer say? I've never seen a Tange fork that didn't have Tange stamped on the steerer.
Hudson308 is offline
Old 02-25-20, 09:13 AM
T-Mar
Quoted: 3299 Post(s)
Liked 718 Times in 553 Posts
Agreed, it could be an aftermarket decal. The number of ridges and style (straight or helical) would allow us to identify the steerer manufacturer but since it's a loose fork it's easier to just check the outside of the steerer tube for the manufacturer's name or logo. A Columbus steer will have their dove logo. Tange or Ishiwata will have their name or logo and also an alpha numeric date code.
Pending that evidence, when I see a reported Columbus fork, with SunTour dropouts and that colour, my immediate thoughts go to the high end Lotus models manufactured by Tsunoda in the early 1980s. Some did use that crown and sometimes they weren't embossed, though I can't say that I've seen any with the heart cutout in the blade reinforcing tang or that style of blade end treatment. Assuming the the Columbus decal is OEM, it could be a USA brand.
T-Mar is offline
Old 02-25-20, 09:56 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
Thank you all for the responses thus far.
I did not see anything on the steerer except 4J. Upon closer inspection I now see the Columbus dove logo as well as TANGE MADE IN JAPAN. I also see 5 helical ridges inside the fork crown.
Old 02-25-20, 10:18 AM
T-Mar
I've never seen a steerer tube with both the Columbus dove logo and 'Tange Made in Japan'. The 4J indicates October 1984 for Tange and would have me leaning towards Tange but you say there are only five ridges inside the bottom end of the steerer tube. That would indicate Columbus, as Tange used six ridges. This is definitely conflicting evidence and I'd appreciate pictures.
T-Mar is offline
Likes For T-Mar:
Old 02-25-20, 10:40 AM
repechage
Quoted: 1383 Post(s)
Liked 349 Times in 275 Posts
A Japan built Allez? I know tossing darts.
repechage is offline
Old 02-25-20, 10:56 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2170 Post(s)
Liked 537 Times in 370 Posts
Tange's pre-fab operation (forks and rear triangles) was separate from their tubing mill. The pre-fab facility would build to order, using whatever tubing and components the customer specified. So it's entirely possible for a Columbus (or Reynolds, or Ishiwata) tube fork to have a Tange pre-fab stamp on the steer tube.
N.B. Tange steer tubes, from their tubing mill, were not stamped at all unless they were brazed at the pre-fab facility.
JohnDThompson is online now
Likes For JohnDThompson:
Old 02-25-20, 11:07 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
Difficult to capture these markings as they are faint. Capturing the ridges even more so.
Old 02-25-20, 11:18 AM
T-Mar
I'm leaning towards a 1985 Schwinn Peloton.
Edit: It's definitely Tange built with a Columbus steerer which would be correct for a Peloton. The date code is October 1984 which would be a 1985 model and the Peloton was spec'd with Superbe Pro that year, which would explain the dropouts (the 1985 Schwinn catalogue states SunTour dropouts but not the model). The colour is correct, as is the blade end treatment, dropout chroming, fork crown style and absence of crown embossing. The only thing I'm not sure about is the heart cutout in the blade reinforcing tang.
T-Mar is offline
Likes For T-Mar:
Old 02-25-20, 11:25 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
Old 02-25-20, 11:29 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
That appears to be spot on........thank you kind sirs
Old 02-25-20, 11:34 AM
Hudson308
Mr. Anachronism
Hudson308's Avatar
Quoted: 481 Post(s)
Wow... great detective work, and an interesting fork!
Old 02-25-20, 11:41 AM
r0ckh0und
r0ckh0und's Avatar
Quoted: 69 Post(s)
Here's another pic that shows the heart cutout detail
Old 02-25-20, 03:30 PM
unworthy1
unworthy1's Avatar
Quoted: 533 Post(s)
That WAS some impressive deduction thanks be to T-Mar! So there is such a thing as a Tange-built Columbus fork with SunTour ends...what a hybrid!
