Schraeder "valve creep"
Quoted: 765 Post(s)
Liked 660 Times
All of my bikes have presta valves, in many cases with those tubular aluminum adapters that allow the presta stem to fit snugly in a rim drilled for schraeder stems.
I'm now building up a touring bike for a friend. It has those indestructible Araya rims that came on so many Japanese bikes from the 80s. They're drilled for schraeder stems, and I'm thinking that I might just install schraeder tubes, since I have a bunch of them that I ordered by mistake a year ago.
Here's the question, though: How does one prevent schrader tubes from creeping around the rim so that after a few months the valve stem is pointed off at a crazy angle, rather than right at the hub? That's one of the things that bothers me about schraeder valves (another is that the stems get packed full of mud if you lose the valve cap). Is there a simple solution to that issue (preventing valve creep, not keeping mud out of the valve stem)?
EDIT: Note that this is not a general question about the relative advantages and disadvantages of presta and schraeder valves. That dead horse has been well beaten. Just looking for a solution to the valve-creep problem. And yes, I know that it's a bigger problem at low pressures.
www.redclovercomponents.com
--Ogden Nash
--Ogden Nash
Quoted: 765 Post(s)
Liked 660 Times
Ha! I tried to fend you off with my edit, but you were too quick for me!
The rims in question have straight walls, so tire pressure is limited to about 75psi. Which happens to be the tire pressure I prefer even with hook-beaded rims.
--Ogden Nash
--Ogden Nash
Quoted: 3464 Post(s)
Liked 2,829 Times
Obviously you have ample torque.
Quoted: 765 Post(s)
Liked 660 Times
?Wait, wasn't Ample Torque the drummer for The Monkees?
Or was he the bass player? Yeah, pretty sure he played bass.
--Ogden Nash
--Ogden Nash
Likes For jonwvara:
Quoted: 5224 Post(s)
Liked 3,582 Times
if valve creep is from under inflation you’ll have to address that somehow. if the bike isn’t for you then maybe you can move past your personal preference for 75 psi & let the owner go up to 80 or 90 psi. also doesn’t it depend on compliance &maintenance? meaning check pressure regularly & not waiting for it to “look” low. when I was a kid i never used a gauge just squeezed them & filled them when they looked low. Then tilted valves were common. We use shrader valves on all 6 family bikes & never have tube creek or tilted valves & my Wife & Daughter both prefer less pressure than Son & I. the bikes only get ridden after the psi have been checked
Liked 3,582 Times
Quoted: 765 Post(s)
Liked 660 Times
That would work! But riding higher-pressure tires isn't a solution to my existing problem--it's a new problem
--Ogden Nash
--Ogden Nash
Liked 3,582 Times
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Nowadays, I wont use any Schrader-valved tubes that do not have a threaded stem. Conti and Schwalbe are my go-to's. I also use metal caps, and if there is any doubt about them coming off, I coat the stem threads with beeswax. FWIW, its a rarity (now) that I use anything but Presta... and this is not a debate over Presta vs Schrader - just a personal preference.
Liked 2,829 Times
3M black weatherstrip adhesive.
hooked rims increase the contact area besides
providing a mechanical hook.
i have not looked for tires for straight sided rims for decades - I do have one bike with them, will be switching it to hooked rims soon just to have more tire choice
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Not lost wanderer.
Quoted: 886 Post(s)
Liked 998 Times
I only have valves creep when I run super low pressures.
Quoted: 765 Post(s)
Liked 660 Times
Do others find that valve creep is a non-issue even at moderately low pressures?
--Ogden Nash
--Ogden Nash
Likes For FBOATSB:
Quoted: 2363 Post(s)
Liked 1,749 Times
In all likelihood, they started out that way, installed and inflated by Target/Walmart or high-volume LBS employess who don't care, or just don't know.
Liked 2,568 Times
Maybe I'm trying to solve a nonexistent problem. I have seen plenty of schraeder wheels with crazily-angled valve stems but since I haven never used said wheels myself, I have no idea how they got that way. Maybe it only happens if wheels are run while nearly flat? If they can be run at 30-40psi without problems, I guess I have been wasting everyone's time. If I'd thought this through I'd have realized that lots of mountain bikes use schraeder valves and are run at pretty low pressures, but I don't hear a lot of mountain bikers complaining about their valve stems?
I'm probably a little more OCD than most, in that I'll tug the uninflated tire one way or the other to get that valve straight again, and will unmount everything and start again if that's what it takes.
Tire creep *does* happen, but like you say, it takes really super-low pressures that we shouldn't be running on the road and when touring. Just begging for a pinch flat at that point.
Liked 3,582 Times
21 psi front / 25 psi rear no valve creep ...
Liked 3,582 Times
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
This matches what I think is the likely cause. If installed correctly and they remain straight after inflation, they'll stay that way. If they start off a bit crooked, a small amount of movement (due to riding or inflation) will result in significant stem angles as the stem presses the edge of the hole in the rim.
It might be some tires are more prone to this than others. Try a different brand maybe?
A slight aside... You don't necessarily need hook edge rims to run 90 psi, though it is safer. Bikes were pumped up to 90 as more or less standard pressure during the 27 x 1 1/4" era, often with straight wall Weinmann concaves or Super Champion Mod 58's. Pretty much all tires had wire beads though, until the 'Turbo' came out. But that was then and this is now. I mention this only for historical value. I think most modern tires are made assuming they will go on a hooked rim, so a fair amount of caution should be used if pumping to higher pressures. Likely some tires will hold fine, and others will pop off with a loud bang...
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
My rear Schrader valves creep a little. I usually run 35 to 45 lbs. Its no biggie to me.
Quoted: 83 Post(s)
Liked 96 Times
Quoted: 4722 Post(s)
Liked 3,036 Times
Inner tubes will often attach to the tyre inner case from heat build-up or patch glue. If the tyre creeps, so too will the inner tube and valve. This can be mitigated by applying talc to the tube before installation. If you soap the tyre and/or rim to facilitate installation, it is more likely to creep, especially if ridden immediately, before the soap can dry out.
Rims and tyres have varying susceptibility to creep. Hooked edge aluminum rims are the least prone, while steel is the most likely to creep. Tyre design in area bead seat area can affect creep, which also increases with older, harder tyres.
I've seen a few cases where misaligned rim tape was the root cause of valve stem canting.
However, as stated the biggest factor is proper alignment prior to inflation. If it's not straight, you can't just straighten the stem. You have to rotate the tyre slightly to realign the tube and straighten the stem.
Likes For T-Mar:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I think that repechage and Salamandrine have somewhat keyed in on the actual problem, which I have known to occur at proper road bike air pressures.
I'll first get out of the way the possibility that the Araya rims may be relatively slippery along their extruded and anodized tire-gripping surfaces.
But what I have concluded without any doubt is that certain tires, usually those having aged/dry/dirty rim-contact surfaces, are mightily prone to slipping along the rim!
And even blowing off the rim in the case of the narrow old Araya double-walled rims.
I have applied rim cement along certain old tire's bead-seating area to mitigate this, but I can't really recommend this. It did help though.
Don't get me started on tubular valve stem creep, I have too many stories...
