How much grease...
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
How much grease...
...is too much grease?
On my '87 Ironman Master, I'm swapping the original 6-speed 13-21 freewheel to a 13-26...figuring it will give me a little more "low end". My age, 66, pretty much demands this!
Anyway, re-greasing the axle was due, so it led me to wonder just how much grease to use in this fairly well-sealed system.
I squirt the Phil Wood grease onto a toothpick and lay it into the cups, several 1/4" long strips, filled almost all the way around, and spread out a bit with the toothpick. I then put a lesser amount onto the cones, and assemble.
Does excess grease work its way past the sealed guards, or does it migrate into the hub along the axle?
Are the grease amounts pictured about right, or too much? I doubt it is too little...
Before putting in the ball bearings...
A little bit on the cones...
This is after some spinning, and spreading the grease around...
This notched, press-fit grease guard fits like a glove, and actually spins around freely - to avoid a greasy build-up?
The non-drive side grease guard is also a perfect fit. I'm impressed with these 33 year old hubs!
Likes For 67tony:
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
That looks fine. Any excess will work itself out.
If you take it apart in a few hundred miles I think you will find that while the bearing still have grease on them, most of the grease is still there and pushed away from the bearings. I overhaul 20-30 hubs and BB with ball bearings a year, and most of them have excess grease pushed away from the bearings. It isn't really a big deal except when it pushes out to where it becomes a dirt magnet.
That's just my experience though.
"Grease 2" was too much Grease.
Likes For jetboy:
Half way there
Quoted: 986 Post(s)
Liked 880 Times
I would have used a bit less, but you're good. I have a pair of those hubs too. Still nice after decades of use.
Quoted: 569 Post(s)
Liked 584 Times
I am not a bike mechanic but my years in heavy industry maintenance management I can tell you the rule of thumb (normal circumstances) grease in a bearing is 1/3 to 1/2 the possible quantity to fill. That said, over greasing is a minor concern with your hub as it will work its way out rather than the churning grease causing energy loss and rising temperatures which leads to wear. At the speeds I ride rising temps would never be a problem in my hubs.
Bikes: 2011 Handsome/ Twin Six Speedy Devil, 2006 Soma Groove, 1991 Haro Impulse Comp, 1987 KHS Montana Pro, 1986 Ross Mount Hood, 1986 Mongoose ATB, 1985 Shogun Prairie Breaker I, 1973 World Voyageur, 1941 Schwinn DX "Klunker"
Quoted: 83 Post(s)
Liked 96 Times
I think the question of this thread has been answered so i felt ok with the detour.
