How to weigh a bike?
#51
Quoted: 1857 Post(s)
Liked 664 Times
Reset the scale if it needs it, then grab the bike. Holding it, step on the scale again.get off and write down that number.
Subtract the two numbers. The bike weight is the difference between the two. Most modern scales are good to 1/10 lb or to show lb and ounces, so for me that's enough resolution. I don't expect to get grams accurately when I'm putting nearly 100 kg on the scale.
Write down the bike weight and throw away the scraps of paper, to destroy the evidence.
#52
Liked 664 Times
#53
Non omnino gravis
Here's a thought project for you: what do you learn by knowing how much the bike weighs? In what magical ways does your life change?
I can honestly say I have no accurate idea what any of my bikes weigh. Some are over 20lbs. One is probably under 20lbs. I don't think any of them crack 30lbs.
If I had the precise numbers written down, nothing would change. Bike weights and miles ridden do seem to come out as inversely proportionate on BF, though.
Likes For DrIsotope:
#54
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
#55
Quoted: 1034 Post(s)
Liked 1,290 Times
Uhm, no, that was my original point with my first post saying to use the bathroom scale. I was just answering a post regarding using Google to figure out how how many ounces in a pound. Which is totally unnecessary considering 1. No need, and 2. It's not rocket science so I could do that calculation in my head or at the most use a calculator.
So I agree, there is no difference in my opinion between 30 and 31 pounds.
#56
Non omnino gravis
I like a bike for how it rides. Unless the weight is so high that it's noticeable (which for me seems to be in the low-30s-- I had a sluggo C-Dale hybrid that was like 34lbs dry) I don't care. Whatever one of my bikes weighs, add at least 5lbs for water (sometimes more in the summer,) then 215lbs of meat to make it move. The weight of the bike? Two categories: too much, and just fine. Luckily, everything in the stable is just fine.
#58
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
#60
You could buy a luggage scale which even has a hook to hang from and a big hook to hang a wheel on. They’re cheap.
#61
How about the scale at your local truck stop ?
#63
subtract the without from the with.. simple Math,
#64
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
It actually has an advantage. If you use a hanging scale that is not calibrated absolutely, say it weighs a couple pounds too heavy, then your result will be off by that much. if your bathroom scale is similarly off, when you weigh yourself+bike and subtract yourself, the inaccuracy cancels out. Bathroom scales do not have precise resolution though (maybe 1/2 lb at best?). But to that precision, it is an accurate measurement,
#66
Use your bathroom scale. Weigh yourself then weigh yourself holding your bike. The difference is the weight of your bike.
#67
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
I use a digital bathroom scale. First I get on it and weigh myself, writing down the result (on disposable paper so I don't have to look at the number when done!!!.
My bike is so light, I weigh less holding it.
#68
Tragically Ignorant
Liked 9,098 Times
#69
ChristopherL
Bikes: '62 Peugeot PA 10, '73 Peugeot UO8, '74 Peugeot UE8 (converted to UO8 look alike), '75 Peugeot UO8, Peugeot Ventoux PH501, '7? Sekine SHS 271, '89 Centurion Ironman Master, '86 Centurion Elite RS, '87 Centurion Ironman Master
Quoted: 13 Post(s)
Liked 7 Times
Me thinks, THE WINNER ! ! !
#70
Quoted: 252 Post(s)
Liked 67 Times
Did someone suggest Archimedes method? You measure how much water is displaced when you submerge the bike. Then you need to estimate material densities of the various components on the bike, subtract empty volume inside the frame and wheel tubes. I think it would be an interesting project for an engineering class.
#71
My bathroom scale has a display that reads out to one tenth of a pound. This would imply a level of precision that it really doesn't have. I can get on and off repeatedly and the numbers are all over the place, varying by almost a pound. I have no idea as to the accuracy. Regarding the fish scale, I've never caught a fish that weighs as much as my bike, so needless to say, my fish scale doesn't go high enough. Maybe if you live on saltwater....
