Want to paint chrome
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
I just bought a chrome fork the other day and I might want to put some color on it and of course have some chrome accents . Krylon rattle can is my choice , there are two types I'm considering . First is the one they call Shorts Cuts , it is an enamel . Next is one they call Fusion , they say it has adhering quality's , but what type it is , enamel or ? I don't know . My main concern is prep , sand I think would be a good choice or maybe better , 3M Scotch Bright . Of course do nothing would be nice but I think wishful thinking . All thoughts are appreciated .
Thanks , Mark .
Thanks , Mark .
Quoted: 4208 Post(s)
Liked 3,874 Times
Chrome makes a poor surface to add paint to. Given that you will be best to create some "tooth" to the chrome for the primer to engage with. The time honored way is to sand the chrome. taking care to keep any left exposed chrome un sanded. Do you have a practice piece you can play with before committing to your good fork?
I assume you know of the trade off with common low cost rattle can paint formulas compared to the more expensive options. Andy
AndrewRStewart
AndrewRStewart
Bikes: 1984 Fuji Club, Suntour ARX; 2013 Lynskey Peloton, mostly 105 with Ultegra rear derailleur, Enve 2.0 fork; 2020 Masi Giramondo 700c, full Deore with TRP dual piston mech disk brakes
Quoted: 324 Post(s)
Liked 81 Times
If you are going to sand the chrome you need to wear dust mask and protective goggles. Inhaling chrome dust will damage your lungs, you'll need to go to the hospital, but the damage will be permanent; getting the dust in your eyes will irritate them like crazy, a good eye wash will be needed and maybe a trip to the doctor, your eyes will be irritated and red for days and will require constant moisturizing drops.
Likes For greatscott:
Quoted: 628 Post(s)
Liked 316 Times
Thanks , Mark .
Quoted: 628 Post(s)
Liked 316 Times
Mark .
Liked 3,874 Times
For paint durability the two part (pigment and hardener) auto industry paints have a good rep. For ease of application the Spray.Bike stuff has good reviews. My next frame will be brushed on alkyd enamel. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Quoted: 569 Post(s)
Liked 583 Times
In my experience the 80 to 120 emery worked better on larger jobs and you can clean up in really rough areas/gouges with finer 240 if needed just be sure it is dull everywhere. I have had much better life when using a two part primer having gotten good results with SprayMax 3680033, 2K Epoxy Rust-Cure Primer and would look at two part paints as recommended above rather then rattle can after all this work. I played with design with rattle can straight on the chrome which will stick long enough to see if you like it but within a few months I started getting flaking and it was sad within a year.
Likes For easyupbug:
Friendship is Magic
Bikes: old ones
Quoted: 26423 Post(s)
Liked 10,380 Times
...if you don't want to spend the money for a 2 part urethane paint like Spraymax (which is 20 bucks a can plus change, and will be too much paint for just a fork, and will be useless once mixed and it sits for 48 hours in the can that way), your best bet after the roughing step is to prime with a self etching primer (wear a mask when you spray this stuff, like all spray paints, but slightly more damaging if inhaled). Then spray a second coat (and a third if you need it) of your color enamel of choice. Try to stay within the re-coat window as described on the can.
Wet sand to eliminate the dust issue. There are new sandpapers, red in color that are available in fairly coarse grits and can be used wet. 800 is too fine.
There are trick automotive clear coat finishes which are specially formulated to be sprayed over chrome. Unfortunately they are expensive.
https://alsacorp.com/product/clear-4-chrome/
