Front derailleur adapter for smaller chainrings
Old 07-09-20, 04:05 PM
Pizzaiolo Americano
Pizzaiolo Americano
Bikes: 2021 Trek Domane, Bianchi Intenso, Specialized Epic Evo, Surly Ice Cream Truck, Some other stuff
Quoted: 287 Post(s)
Liked 140 Times in 69 Posts
I have a 2021 Trek Domane that I ride on gravel and road so I just got a new crankset with 46/36 chainrings. On this bike, I cannot get the Ultegra deraileur low enough to be in the 2-3mm range because the braze on slot doesn't go low enough. Does anyone make an adaptor to lower the front deraileur 5mm or so? It shifts and rides fine as is but I want to get it within spec...
Pizzaiolo Americano is offline
Old 07-09-20, 04:23 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
You can use a braze on adapter if you want to go 5mm:
https://www.amazon.com/SHIMANO-Dura-...2N499ZPSQKGJQS
But try setting it up slightly out of the 2-3mm spec. You might not even notice the difference.
Elvo is offline
Old 07-09-20, 05:32 PM
Pizzaiolo Americano
Pizzaiolo Americano
Quoted: 287 Post(s)
I don't think that will help me?
Old 07-10-20, 11:39 AM
Atlas Shrugged
Quoted: 1248 Post(s)
Liked 1,323 Times in 674 Posts
Either remove the fitting or file the slot 5 mm lower are your two options.
Atlas Shrugged is offline
Old 07-10-20, 07:00 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
I'd contact Trek Customer Care, and see if a different mount is available.
noodle soup is offline
Likes For noodle soup:
Old 07-10-20, 10:29 PM
fourfa
Quoted: 86 Post(s)
Liked 51 Times in 35 Posts
https://wickwerks.com/products/fit-link-adapter/
fourfa is offline
Likes For fourfa:
Old 07-13-20, 08:35 AM
Atlas Shrugged
The Fit-Link lowers the FD mount 8.8mm to 15.9mm lower. Only 5mm is required.
Old 07-13-20, 08:41 AM
Atlas Shrugged
The fitting is part of the frame.
Old 07-13-20, 10:39 AM
Pizzaiolo Americano
Pizzaiolo Americano
Quoted: 287 Post(s)
I ordered the Fit-link and will see if I can get the adjustment right with it...Thanks all!
Old 07-13-20, 11:39 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
On my bike, with 48t ring, the FD cage hitting the chainstay is what prevents ideal clearance above the chainring.
woodcraft is offline
Old 07-15-20, 05:54 PM
Pizzaiolo Americano
Pizzaiolo Americano
Quoted: 287 Post(s)
I got the Fit Link installed and it works perfectly. Thanks all!
Likes For Pizzaiolo Americano:
