View Poll Results: Is BB30 better than Hollowtech & GXP?
BB30 is a huge improvement over Hollowtech & GXP.
9
16.67%
BB30 is better, but not worth the expense of a new crank. Use an adapter.
7
12.96%
BB30 is not better than Hollowtech & GXP, but works well.
24
44.44%
BB30 is having some issues, avoid it at all cost.
14
25.93%
Voters: 54. You may not vote on this poll
BB30, is it really better than Hollowtech & GXP?
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
My next bike frame will include the BB30 bottom bracket. On paper, the BB30 cranks look like a true improvement over the external BB cranks I'm using now. However, aftermarket supply of BB30 cranks is limited. I like Shimano cranks and Shimano currently does not offer a BB30 crankset. I already own a Shimano crank that I would like to use.
Should I just install an adapter on the BB30 frame and keep my existing cranks until Shimano does make a BB30 model?
Bikes: 2013 Synapse 4
Quoted: 70 Post(s)
aren't the adapters non-removable (i seem to remember reading that here somewhere)?? either way you go I would think that modifying the frame will reduce resale down the road... I'd sell your shim crank and just get something else if you are dead set on bb30, just my take...
if the adapters are not a permanent solution then why not use em...
Quoted: 910 Post(s)
Liked 288 Times
Yes, the ideal of using an adapter is not plan A. I just want to consider my options before getting a new $300 crank.
I'm not sure about how the shimmed/adapted standard BB cranks work compared to BB30 ones. But on my tri bike I have a BB30 Force crank, and on my road bike I have a GXP Force crank. No difference in feel to me. If the adapter is removable in the future, I'd go with that.
Throw the stick!!!!
Why would the adaptors be non-removable? They are pressed in the same way that the bb30 bearings are pressed in aren't they?
I may be fat but I'm slow enough to make up for it.
John Wayne Toilet Paper
Bikes: BH carbon, Ritchey steel, Kona aluminum
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Wheels Mfg makes a set of shims that go on the end of GXP spindles to take out the extra space and adapt to BB30 bearing setups. I am running them now and have installed them on many other bikes. The are just shims so there is no bonding anything like there is with the press in shell adapters. I would highly advise going this route until you feel the need to buy a BB30 crank down the road.
FWIW - I am using it to adapt myQuarq GXP SRAM S975 ti my Aerocat R505 BB30 Bottom Bracket shell.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Chases Dogs for Sport
I have seen two BB30 cranks go bad. It was a problem with the crank, not the BB. But I've never heard of a name brand English thread crank going bad. Strike 1.
Availability of cranks I want in BB30 is a problem. Strike 2.
Threaded BB's are very, very easy to install and maintain. BB30, not so. Strike 3.
BB30 is just a way of creating demand for captive-brand cranks.
Quoted: 910 Post(s)
Liked 288 Times
It is interesting that Velonews' scientific testing showed that BB30 is no stiffer. I thought that was supposed to be a major benefit!
I eat carbide.
Liked 1,306 Times
I like BB30. Less parts. Lighter. Easier connections.
If you think that creating a new standard helps you with sales....then something tells me you have never entered a well populated and crowded market and tried to convert an entire world of consumers and OEM's over to a completely new standard....'cause....you know....they did it because they want'ed to stand apart.
Also along those lines who do you believe is the company who is trying to stand apart?
BB30 has some distinct "advantages" from my point of view as a "mechanic", retailer, team owner, etc. It also has some drawbacks.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
BB30 bearings are cheap and easy to replace. the driveside crankarm has a 30mm tube on it. simple.
BB30 is arguably better technically than an external BB systems, but it's kind of a moot point at the moment as the only decent BB30 crank on the market (Hollowgram) is hideously expensive and hard to get hold of.
Bikes: Iron Horse Warrior Expert, Dahon MU P8, Bacchetta Giro 26, HP Velotechnik Grasshopper
Why settle for old technology. Here comes BB386 EVO: https://www.bikerumor.com/2011/04/01/...ard-bb386-evo/
cycling technology is evolving as quickly as computer and cell phones
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 28 Times
Is BB30 any better than the old 70mm Italian bottom bracket with square taper spindle?
I've got BB86, I think its the way Shimano can offer press fit bearings that are compatible with their cranks. Enduro make the bearings that the system runs, and I think it embodies the benefits of BB30 without the compatability issues.
Off topic, but IMHO hollowtech cranks make the bigger difference. The differance between square taper/octalink and hollowtech is huge: I can't see there being that much difference between HT2 and BB30 cranks apart from weight.
I eat carbide.
Liked 1,306 Times
There are a wide array of BB30 cranks on the market from many manufacturers that are not super expensive that can be had easily.
Tete de Couch
Bikes: Specialized Roubaix
I got BB30 on my Pedal Force QS3 over a year ago. The bearings would not stay seated. Creaky cracky noisy POS, BB30 is. I finally had the mechanic use Green Loctite to glue the bearings in. I have the carbon SLX cranks????
I'd much rather have threaded BB's.
https://fairwheelbikes.com/cycling-bl...nk-test-4.html plus Sram's BB30 crankset. Ignoring price (!?!?!) this gives a good run down of some of the benefits and what the differences are between BB30 and non BB30. Shimano and Campag are 24 - 25 mm spindles.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
No vote for my take that the external is fine but I really do not know about the BB30 as far as using one. For my take the Hollowtech is better and I already have to tools that is uses.......... not need to change.
Well, I did use the word "decent". The thread title was about BB30 being better than Hollowtech. Name me one readily available BB30 crankset (including the rings, and excluding the Hollowgram) that shifts better, flexes less and generally performs better than DA7900 on Hollowtech.
Cannondale is a big bike company with aggressive plans to expand in Asia and an owner with expectations. You're not going to do it just by getting bikes in shops...They have a nice marketing pitch that's easy...BB30 = stiff and S.A.V.E = comfort. The fact that there are options for BB30 cranks shows their market share is pretty influential.
For the record, I like Cannondale a lot and ride a BB30 bike. Couldn't tell you if BB30 is really any better or not but I am surprised there isn't more out there in support of the standard.
