Bike Rack For A BMW Wagon
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I'm not sure if this is the best place for this, but...
I have a 2001 BMW 525i wagon and have hit a fair amount of difficulty in finding a bike rack to work with this car.
I'd really like to have a a rear mounted rack, rather than get the bike mounted to the roof of the vehicle. I currently have a Saris Bones rack which works great on my wife's van and on my old Outback. However, the fitting of the back gate is too tight to allow the 'fingers' of the Saris straps, and the side of the gate is glass. My preferred option was going to be a hitch mounted rack- but it seems even adding a hitch to this vehicle is a pretty big obstacle.
If anyone has any experience or great ideas- I'd love to know!
Thanks!
Thanks!
Commence to jigglin’ huh?!?!
Bikes: Crossrip Elite, Bikesdirect tarck bike custom build
I don't have anything to add, but why are you against the roof rack? Roof racks may be spendy, but trunk racks are super janky. It wouldn't be impossible to add a hitch reciever, but after all is said and done it may end up costing about the same as a decent roof rack.
Get a Receiver mounted on the underside of the car.. step 1.
My last car had Rain Gutters..
I don't expect you to drive as slow, as I, and the fuel consumption
is increased at speed with a rack of stuff on the roof.
U-Haul can do it, near as I can determine the closest U-Haul hitch installation center to you is U-Haul Moving and Storage of West Allis WI. Their address is 924 S 108th St and their phone number is 414-258-3692. The model of hitch you need is 249374 and it costs $169.95. With wiring and all standard accessories installation comes to $381.74, which includes the price of the hitch. You can make a reservation online via U-Haul's website to have the hitch ordered and installed.
Once you have the hitch you can add a receiver mounted bicycle rack.
Hope this helps.
Hope this helps.
Liked 1,699 Times
Pretty much the only reason I don't want a roof rack is that I don't want to have to lift the bike onto my vehicle, and the all too likely possibility of scratching/denting the car or bike or possibly slipping off and breaking the moon roof glass.
Liked 1,699 Times
Hope this helps.
Hope this helps.
Thank you very much for the info!
Live to ride ride to live
Bikes: Calfee Tetra Pro
Do you have the factory bars on the roof? I have a 95 BMW wagon (E34). I think it should be easy using the factory bars.
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
Quoted: 10 Post(s)
Hope this helps.
Hope this helps.
U-Haul hitches are great. I've had them on about 14 different cars or trucks over the years. The only problems I've had were 2 or 3 cases of bad wiring. That's just installer inexperience, which happens. U-Haul is where I go first for a hitch and is where I recommend others go for a hitch. The installation is so cheap I have them do it to my cars or trucks, also their selection is unbeatable.
Starting over
Quoted: 10 Post(s)
Thanks for the feedback, I appreciate it.
Quoted: 14 Post(s)
Liked 13 Times
I had UHaul install a hitch and they screwed up the wiring. The vehicle had a pigtail and connector for trailer wiring. UHaul didn't have the mating connector so they cut the pigtail, threw away the vehicles connector, and wired into the pigtail. In chopping the connector off the pigtail, they shorted the wiring and blew a fuse, so when they were done wiring it up, it didn't work. They then went in and hooked up the wiring using quick splices behind the vehicles light assemblies, which often becomes problematic over time. Totally bogus. I undid the taps, wired correctly into the pigtail, and replaced the blown fuse. Since then I've installed hitches myself. It costs less than half what I'd have to pay UHaul, and it's done right.
Of course, if you're not pulling a trailer with the hitch, you don't need any wiring.
It's usually pretty easy as they often just bolt right in, but Curt's installation instructions for your vehicle does require some drilling: https://www.curtmfg.com/masterlibrar...111790_INS.PDF
FWIW, at the time the UHaul hitches were rebranded Draw-Tite hitches.
One thing I've found is that if the shop has to schedule you for a install it means they're busy. Busy is good, the shops where I had wiring issues were walk in shops that didn't require appointments. Double check their ground connection before you leave, make sure it's a clean ground.
