Dia-Compe 980 brake boss bolts
Old 03-20-18, 04:19 PM
kjaioqhbkqb
Quoted: 29 Post(s)
Liked 5 Times in 4 Posts
Does anyone know if Dia-Compe still makes the bolts that attach their 980 cantilever brakes to the mounting bosses on the frame? If so, do you have a part number or a resource?
kjaioqhbkqb is offline
Old 03-20-18, 08:01 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2170 Post(s)
Liked 536 Times in 369 Posts
The brake bosses are threaded 6mm x 1mm, and bolts with that thread should be readily available from a hardware store.
JohnDThompson is offline
Old 03-20-18, 08:12 PM
SkyDog75
Bikes: Bianchi San Mateo and a few others
Quoted: 633 Post(s)
Liked 4 Times in 4 Posts
I don't recall anything particularly unique about their mounting bolts. Is there a reason you can't use any standard cantilever/v-brake mounting bolt?
...or any standard M6 bolt from a hardware store, for that matter. 20mm is a common length. You could go with stainless steel for corrosion resistance.
But here are some Dia Compe bolts if you'd prefer:
https://www.niagaracycle.com/categor...attaching-bolt
It's typical to include a washer between the brake and the bolt head, too.
SkyDog75 is offline
Old 03-20-18, 10:10 PM
kjaioqhbkqb
Quoted: 29 Post(s)
Right, so M6 x 1.0. I know hardware store options exist, but I wanted to track down the originals because I like how the original head has a slight radius to it and is thinner than most hardware store options. The head I think is 10 mm with flats, not hex driven.
wesmamyke
Quoted: 172 Post(s)
Liked 24 Times in 20 Posts
Those are old enough Dia-compe almost certainly doesn't make replacements, doesn't mean you can't find them though. Did those originally come with 13 or 14mm bolts like MAFAC canti brakes?
What others said, you should have no problem using standard M6 cap or button head bolts. If you really want old style bolts with wrench flats I probably have some. I might even have a complete 980 brake around here somewhere I could steal the bolts from.
wesmamyke is offline
Old 03-20-18, 10:27 PM
kjaioqhbkqb
Quoted: 29 Post(s)
I think the bolt is 15 mm without the head and 19 mm with the head. I'd really like to find at least a pair new, but also the part number so I can try to track down NOS.
Old 03-21-18, 12:41 AM
wesmamyke
Quoted: 172 Post(s)
You might want to cross post in classic/vintage. Maybe somebody can point you to some old catalog scans or something.
Just checked the Dia-compe canti I have and it's a later model with allen bolts. I certainly have Shimano or MAFAC bolts of that style if you just want something that looks the part.
Old 03-21-18, 01:37 PM
kjaioqhbkqb
Quoted: 29 Post(s)
@wesmamyke Thank you for the suggestion and the offer. I'm going to hold off until I find something perfect You know, I may end up getting those re-issue DC980s in the meantime.
Old 03-22-18, 12:45 PM
dweenk
dweenk's Avatar
Quoted: 707 Post(s)
Liked 97 Times in 71 Posts
Try McMaster-Carr, a pretty damn good online hardware store.
https://www.mcmaster.com/#screws/=1c30knf
"The man who does not read has no advantage over the man who cannot read." –Mark Twain
dweenk is offline
Chili Cheesy
Touring
16
10-04-17 09:40 PM
floyd0117
Bicycle Mechanics
20
04-21-17 10:48 PM
gems
Classic & Vintage
3
04-30-14 11:17 AM
Mudu93
Bicycle Mechanics
3
05-18-11 02:06 AM
TurbineBlade
Bicycle Mechanics
7
08-17-10 12:34 PM
