Garmin’s Varia light and radar
#51
Hear myself getting fat
Bikes: Sir Velo A Sparrow
Quoted: 335 Post(s)
Liked 265 Times
I use a Wahoo Bolt and am jealous of the watch interface. Although the beep from the Bolt is very loud
I wouldn’t hesitate to use it with a watch only.
Likes For aplcr0331:
#52
That's the way it works. Varia needs to be left in BT detect mode or whatever it's called. It doesn't draw much power and can go for days. But it is a little annoying.
#53
Quoted: 18883 Post(s)
Liked 10,646 Times
I've never used the lighting network thing. Not sure how it works with a watch? Anybody know, or do I have to read the manual? (I googled it but everything that's coming up if for Edge units not watches.)
#54
Bikes: 2017 Colnago C-RS, 2012 Colnago Ace, 2010 Giant Cypress hybrid
Quoted: 408 Post(s)
Liked 122 Times
Actually, you can press the power button for two seconds and the Varia will power off. The blinking blue light means it's in standby mode.
HCFR Cycling Team
Ride Safe ... Ride Hard ... Ride Daily
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
#55
Beer & Bikes
Bikes: '20 Specialized Roubaix Expert, '20 Specialized Shiv Elite, '13 Specialized S-Works Epic
Quoted: 38 Post(s)
Liked 80 Times
Like those who like the RTL510, I like the RTL510. It's a situational awareness multiplier for me for certain. If I've a complaint, it is the mounting system. The 1/4-turn lock seems good enough but the single band (or even doubling it) just seems undependable. It's a fair bit of money to just trust to rubber bands. Add to it the lack of solid fitting to non-round/non-aero seat posts like the Specialized Pave and I just don't have confidence in the mount.
I've found a number of saddle options based on 3D printers and a bar that mounts to a Specialized SWAT mount which I've ordered. Once installed it will place the unit as high as practical and allow adjustment to pure vertical. That comes from a GoPro like mounting option. Both of those factors will lend themselves to making the most of the claimed 140 meter range.
However, these items are coming from overseas so I expect a few weeks in transit.
In the short term I cut a channel in the seat post block of the mount and threaded two zip ties for my own peace-of-mind. Good enough until my new hardware arrives.
I like the RTL510 a lot!
Zip tie modification.
#56
#57
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
So, unless your watch allows you to download and implement the same sorts of apps, I suspect it is limited to Edge units.
Likes For Cyclist0108:
#58
Quoted: 408 Post(s)
Liked 122 Times
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
#59
Occam's Rotor
Liked 2,331 Times
My Colnago has a round seat post so when I got my Varia, I used the mount that came with it. I also have a saddlebag that takes up pretty much the entire height of the seat post. To mount mine, I had to lift my saddlebag high enough to get the radar underneath it. The problem I was having was that on bumpy roads, the saddlebag would bounce on the radar causing it to turn to the left or right of center. If the radar turned to the right, I would lose any contact with approaching cars. So my DIY solution was an old gas valve key I had lying around. The smaller O-ring that came with the Varia is used to secure the mount to saddlebag. I can easily move the Varia from bike to bike without having to have multiple mounts or remove an existing mount.
#60
What I have done that makes it work very well with a saddle bag is to get a GoPro style mount that fits between the saddle rails, use a curving GoPro extension piece which then attaches to a Garmin GoPro to qtr turn mount. This works very well and my Silca seat pack fits perfectly behind it. The Varia winds up slightly below the edge of the saddle, right in front of the seat pack and aimed appropriately for drivers to see. You can get mounts like this from Amazon that work.
#61
Occam's Rotor
Liked 2,331 Times
@JohnJ80 Thanks. I many even have all of those parts.
#62
Quoted: 408 Post(s)
Liked 122 Times
The type of T-bracket that my buddy used. Cut off any access metal that sticks out beyond the twist lock mount to make it look nicer. Painting it is optional. What I like about having it on a saddlebag is, as mentioned in my last post, that it can be moved from bike to bike without having to remove the mount or have multiple mounts. Simply slide it out of one saddlebag and slide it into another.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
Likes For John_V:
#63
out pretty clean looking and compact.
#64
Occam's Rotor
Liked 2,331 Times
Cool. I think I have all of the parts (if only I can find them).
#65
Occam's Rotor
Liked 2,331 Times
#66
Liked 10,646 Times
It is made primarily for head/tail light display and control. My Edge 130 "establishes a network" when I turn it and the radar on. However, the 130 is rather primitive; the only thing it displays is the battery level for the radar (and of course the radar signals themselves). On higher-level Edges, I think it allows control of various lights through one of the optional downloadable "apps." I was thinking of getting those little Bontrager lights so I could geek out with a light network, but then I discovered the only thing the Edge would do is tell me they were on or off.
Turns out my watch can wake the Varia from standby mode, and tell me about cars. But that's it. I can't even seem to get the battery level in the radar unit. It does run apps, I'll look through them. But I guess when you get right down to it, that's all I really need.
I forgot over the last few years what it's like to ride with one. And traffic is still light here. I'm riding out in the lane where the pavement is better (less cracked) and there isn't as much debris. The thing tells me well in advance of when I need to move over.
#67
Quoted: 6957 Post(s)
Liked 10,959 Times
I just bought a Garmin 530, and y’all have got me thinking about the Varia. Seems suited for my usual routes, which involve occasional vehicles but not the hustle and bustle of constant urban traffic.
Likes For Koyote:
#68
That said, it’s also highly useful in urban areas be cause you can see how many cars are back there (most of the time) so you have an idea of when you can take the lane or release the lane. I would note that it doesn’t replace a look a back and it is synergistic with a mirror. I use the tiny Specchio mirror on my glasses and scan it just as if I were driving a car. The Varia Radar is great to interrupt my scan since I know that there is a car approaching. Since I ride in a predominantly rural area on high speed roads, that’s the time to look back because the speed of approach. The Varia gives me about 5-6 seconds of warning and that’s enough to see if I’m going to be ok or have to evade.
I’ve been riding with the Hammerhead Karoo as of late and it’s implementation of the Varia Radar is superb and class leading, IMO. I also have the Wahoo ELEMNT and an Edge 1000. All of them work well.
#69
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
FWIW, a new RTL515 model just released. Has compatibility with apps and offers some lighting adjustments suited for group riding.
https://buy.garmin.com/en-US/US/p/69...n/010-02376-00
#70
Quoted: 408 Post(s)
Liked 122 Times
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
#71
also a light without a light. I thought that was interesting. That could be dropped into a jersey pocket for operation if you have another light or don’t use a light.
#72
Quoted: 241 Post(s)
Liked 232 Times
#73
Quoted: 408 Post(s)
Liked 122 Times
Originally Posted by RGMN
..... Today the RTL510 was on, blinking away, 4 hours after I finished my ride, even though it was off when I powered off the 130 at the end of the ride. I'm starting to think the only solution is to completely power off both the RTL510 and the Ion 200 RT after every ride.
On page 7 of the RTL510 Owners Manual (PDF) it states the following:
Up to 6 hrs in solid mode
Up to 6 hrs in night flash mode
Up to 15 hrs in day flash mode
Up to 5 mo in standby mode
I use mine exclusively in day flash mode and I don't think I've even come close to 15 hours of battery life. I think 8 to 10 hrs is pretty standard for me. The last time I had it on standby for any length of time was when I forgot to turn it off and it was in standby overnight. If I recall correctly, this was my third ride after a recharge, Next morning, I went for a ride, turned on the radar and immediately got a Low Battery warning on my Bolt. I would love to know how they calculate the battery life on these things because nothing I've used ever gets near their "up to" hours.
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
HCFR Cycling Team
2017 Colnago C-RS
2012 Colnago Ace
2010 Giant Cypress
#74
Advocatus Diaboli
Liked 1,531 Times
[b}Up to 5 mo in standby mode
#75
Bikes: Specilized Roubaix, 71 Raleigh Professional, 74 Raliegh Intl, 74 Peugot PX-10, 82 Puegoet PSN, Olmo Competition , Schwinn High Sierra & Others
Quoted: 42 Post(s)
Liked 59 Times
I added a tether loop as added protection in case the rubber band fails.
Likes For LarryBSky:
