Go Back  Bike Forums > Bike Forums > Framebuilders
Which clear coat over which spray paint?
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Old 03-06-19, 11:08 AM
kjaioqhbkqb
Quoted: 29 Post(s)
Liked 5 Times in 4 Posts
I'm spray painting over the original paint on a very old steel frame, mainly because I can't find the color I want except in spray paint and I don't want to pay a pro yet to take a chance on a color I'm not positive about.
Are there any suggestions for which spray paint to use? Should I add a clear coat of some kind for protection?
kjaioqhbkqb is offline
Old 03-06-19, 12:28 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 2426 Post(s)
Liked 484 Times in 374 Posts
Most bike paint is enamel. So an enamel based primer/paint/clear most likely work. Very few lacquers were used in production. Spraying a lacquer over an enamel can be problematic so if in doubt test on a "hidden" spot. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 03-06-19, 06:02 PM
kjaioqhbkqb
Quoted: 29 Post(s)
Thanks! For some reason I thought frames were usually powder coated. In any case, enamel sounds great. Thanks again.
Old 03-06-19, 06:53 PM
Andrew R Stewart
You qualified the age of the bike to what I think would be before widespread use of PC. Andy
AndrewRStewart
Old 03-06-19, 08:30 PM
kjaioqhbkqb
Quoted: 29 Post(s)
I think the frame is between 1978 and 1984.
If it were powder coated, would that change the choice of enamel?
Old 03-06-19, 08:52 PM
base2
Random Internet Person.
base2's Avatar
Bikes: 5 good ones, and the occasional project.
Quoted: 681 Post(s)
Liked 247 Times in 152 Posts
Powder coating comes in any color you can imagine. Depending on what kind and level of fancy you want it runs from $100 to $500. It's the prep work & set up you are paying for. Any reputable PC'er will chemical strip/media blast, de-rust in a phosphoric acid bath, passivate, then process in whatever color you want & be done in about 1 to 2 weeks.
You end up with an essentially new frame in any color you can dream. I favor Prismatic Powders high gloss, but it comes in a variety of gloss levels, textures, candy, chrome, transluscents, etc... Painters claim paint is better coverage & rust protection. PC'ers make the same claim. Both are more durable than spray paint from the home improvement store.
1 gallon of stripper, 15 dollars
3 cans of primer, 24 dollars
3 cans of Rustoleum Enamel 24 dollars
3 cans of clear gloss 24 dollars
sand paper, time, etc...no phosphoric acid derust/passivation dip
My money says a single color, 1 shot powder coat will be cheaper, simpler, and more durable finish than a home job.
base2 is offline
Old 03-06-19, 09:53 PM
u235
u235's Avatar
Quoted: 408 Post(s)
Liked 87 Times in 62 Posts
If it takes 3 cans of each paint, primer and clear coat to do a bike frame you have an EXTREMELY large frame. One can can do multiple coats.
If you've done painting and familar with and understand the full prep (98% of the work), you can get a decent quality job with rattle cans. No match for a proper powder coat but can still be good. You can pick up a can, wipe of dirt and paint it to. It is up to your expectations.
u235 is offline
Old 03-06-19, 10:25 PM
base2
base2's Avatar
Quoted: 681 Post(s)
A frame takes more than 1 can & multiple coats means 2 cans is pretty easy to get in to if you are patient and consistant. The 3rd is because you will run out mid job & the hardware store won't have anymore in stock. So, still, subtract a can each for the return receipt & you're still into the job $75 plus miscellaneous.
The whole "drop-off, pick up" aspect of powder makes labor considerations a no brainer. It would just cost too, too many more dollars in my time value alone to do a rattle-can job at home. Let alone the quality of the final product done by professionals would be head & shoulders above. Worth considering.
base2 is offline
Old 03-07-19, 11:47 AM
wsteve464
Quoted: 155 Post(s)
Liked 64 Times in 57 Posts
Sounds like you are going to do a temporary paint job until you figure out what color you want from a pro?
If that is the case go to the local Do it Center Home Depot Lowes whatever and get the cheapest paint you can find, $4-5 a can. Buy 2 of each primer, paint and a clear about $30 plus some 600 or so grit wet/dry sand paper. Sand the original paint wipe it down with lacquer thinner and primer it sand the primer with wet sandpaper put on a couple of coats of primer sanding in between then spray the color do the same sand wet then the final clear no sanding. It won't be the most durable finish but assuming it is only a temp finish it will be good enough.
Satisfaction of doing a job yourself --- Priceless
And to add yes I have done exactly this, I wanted to see if I wanted a mat/satin finish as opposed to a glossy finish or not.
wsteve464 is offline
Old 03-07-19, 01:20 PM
kjaioqhbkqb
Quoted: 29 Post(s)
Exactly right. Thanks for the steps.
Old 03-07-19, 01:45 PM
u235
u235's Avatar
Quoted: 408 Post(s)
I'll add one step in here.. Use a purpose made tack cloth ($2) just before any painting, not between coats but any time after sanding or away from it for a few hours. Chemically cleaned and lint free are musts and honestly each of those steps only takes a few minutes.. If sanding between coats I switch to super fine steel wool instead of sandpaper myself, I find I can do a more even and controlled sanding of pipes and round things like frames vs sandpaper..
u235 is offline
Old 03-07-19, 06:07 PM
kjaioqhbkqb
Quoted: 29 Post(s)
Good idea; I understand what you mean. One of the reasons I inquired about a clear coat is because in testing different colors on different sections of a scrap tube I noticed that I could pretty easily scrape away the paint with my thumbnail.
Old 03-08-19, 12:13 AM
u235
u235's Avatar
Quoted: 408 Post(s)
Rattle can paint takes a long time to "dry". It may be touchable in an hour but will still be soft for a while (like days/weeks). Stuff like rubbing alcohol can soften and wipe off fresh paint even days later. Thin coats and following the recoat times which are on the can and usually a few minutes to 1 hour and then not again for 24-48 hours. That will make sure all layers can dry good, example.. Example.. you don't want to put clear over paint too early, the underlying paint will never fully cure correctly. Mr personally.. I use matt/flat paint if I am putting a gloss coat on top. Using a gloss paint requires more work to scuff up before putting a gloss coat anyway. Either use gloss paint and be done with it or flat and put a gloss coat on top.
u235 is offline
Old 03-08-19, 05:36 AM
busdriver1959
Quoted: 48 Post(s)
Liked 2 Times in 1 Post
I've had great luck with Duplicolor rattlecan paint from the auto parts store. It goes on well and dries quickly. It's a laquer. I also like their self etching primer. I cover all of it with 2 part rattlecan clear from the internet. Search for 2k clearcoat. Everybody says the clear is nasty if you breathe it so use proper precautions and a good quality mask with filters. I've found the stuff to be very durable and have a nice glossy surface.
As far as interactions with other types of paint, I've only tried Duplicolor applied over powdercoat and the 2k clear over Duplicolor and also over the powdercoat. In all of those cases there were no bad interactions and the clear is nice and glossy and, so far, durable.
busdriver1959 is offline
masterofsilence
Framebuilders
13
11-14-12 11:41 AM
ramseykp
Framebuilders
22
01-24-12 02:01 AM
Fred Smith
Bicycle Mechanics
3
11-23-10 12:35 PM
BrainInAJar
Framebuilders
2
09-01-10 12:06 PM
kmcrawford111
Bicycle Mechanics
4
03-11-10 12:30 PM
