Stationary Trainer for Cargo Bike
I am looking for a stationary trainer that would fit the rear wheel of my cargo bike - which has an internal hub and an axle approximately 21 cm or 8.3 inches wide. From what I have been able to learn online, most trainers will not open wide enough to hold the wheel and my bicycle is too long to fit on a set of rollers.
The Kinetic Road Machine looks like it might fit - but it has been hard to get the exact measurements from the manufacturer. If anyone has one of these and could measure the opening it would be appreciated!
For the past five Junes I have done a 600 km charity ride on the bike with my son and while the actual physical ride won't be possible this year, I'd like to keep the streak alive and show we don't give up in the face of adversity - we adapt. The bike is a symbol of the ride, so I'd like to use this if possible.
Any and all suggestions would be welcomed.
Thanks in advance!
Thanks in advance!
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2135 Post(s)
Liked 1,647 Times
Great topic. I have been wanting a stationary trainer for my unicycle. I'll bet the one you get will work for me.
Randomhead
Liked 3,699 Times
21cm is end-to-end distance?
I have an old Tacx that I bought for my daughter to use. It looks like it should take up to almost 200mm axle, including the quick release. Newer trainers should probably be designed to fit super boost mountain bikes, so they may be wide enough to fit your bike.
Bikes: yes, i have one
Quoted: 1138 Post(s)
Liked 1,182 Times
to the OP: if i had that trainer i would measure it out for you. good luck with the trainer and hope you can complete the "ride." you can always ride locally? no?
Likes For MaxsBigRide:
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 190 Times
Wahoo Kickr Snap would work - there's lots of slack on my son's bike with 135mm rear axles - but is probably FAR overkill for what you're looking for.
Sr Member on Sr bikes
https://www.etrailer.com/Bike-Traine...s/SA1020T.html
Dan
I'm using my old CycleOps wind trainer, like the one at the link provided (I think CycleOps became Saris). I just measured the extreme rear wheel clamp width and it will adjust out to just a bit over 9 inches. If you want something more sofisticated than a simple wind trainer (i.e. magnetic, fluid, remotely adjustable, etc)...looking at other models...it looks like most of the stands are the same as the one I have.
Dan
Dan
Bikes: Yes please
Quoted: 536 Post(s)
Liked 308 Times
I have a quite old (9+ years at the very least) Kurt kinetic road machine and it looks like the widest it goes is a smidge under 9” (22.8 cm).
Mine has the old cups, that the cup on the non drive does not have a notch for the quick release though. Newer models may have that issue resolved. Depending on your setup, you should be able to secure the hub and will have room to tighten the cups.
