Bigger tires for Trek FX 3
I just got my FX 3 Disc and it's great, but I want to upgrade the tires and go a little bigger. The bike came with Bontrager H2 Hard-Case Lite 700x32c. I'm hoping to go up to 700x38c, does anyone have experience doing this? If I did get the new tires, would they fit on the stock rims (Bontrager Tubeless Ready Disc, 32-hole, presta valve)?
Anyone do anything similar to this? How do you like it?
38c tires will work on an FX. My wife’s FX3 has 38c tires on it with no rubbing issues.
Mr Chrome
Sounds similar to my FX carbon 4 - I'm putting on tubelss 35's, shouldn't be an issue if the frame allows it..........I think your wheels are the same as mine - I haven't measured the interior rim width but I called Trek and the customer service rep said it was 21 mm so it should take up to 40 or more......
I put on Bontrager H5 ultimate 700x38 on new fx 3 about three weeks ago and made a significant difference for me in terms of stability and performance on hard packed/light gravel trails, as well as roads with loose asphalt/debris.
