Shimano BR-AT50 replacement
Hello,
I just bought a Panasonic Touring deluxe, which with cantilever BR-AT50. I am very new to bike mechanics and do not know which newer cantilever I could buy to replace them.
Best regards,
Eduardo
Best regards,
Eduardo
Old fart
Quoted: 3590 Post(s)
Liked 3,400 Times
Those look to be pretty standard. I suspect almost anything could replace them. But why do they need replacement?
N.B. some Shimano cantilever and V-brakes use a plastic shroud to retain the spring. Those are to be avoided, as the plastic tends to crack and fail to hold the spring securely.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
If I were to do this- I would go for either the Shimano BR-M732 or the BR-MT62 (pretty much the same thing), then the BR-MC70, but I'd much rather get either of the other 2. If you wanted a lower profile brake- I've had luck with the Suntour XC Pro- but the housing can get kind of tight if the front posts are too close together. (I had to deflate the front tires to get the wheels out).
MC70M732MT62 by Dave The Golden Boy, on Flickr
Grail Brakes by Dave The Golden Boy, on Flickr
Commence to jigglin’ huh?!?!
Thanks a lot for the replies. Based on them I will go for a deep clean and change the Cantilever cable instead of changing it, Really appreciated your answers!
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
BTW, I’ve recently seen some pics of these, where a newer & cooler looking yoke (straddle cable hanger) really makes them look good. 😎
Quoted: 4236 Post(s)
Liked 2,949 Times
