FIVE cranks for ONE: Part out your Raleigh P.U.B
Old 07-12-20, 04:33 PM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 2422 Post(s)
Liked 4,395 Times in 2,092 Posts
I have this pile of assorted cranks (technically six, but one is an orphaned arm):
And I really want the square-taper, Raleigh Heron pattern crank in black that you see below. To my knowledge, such a thing was ONLY offered on the 2006/7 Raleigh P.U.B.
The way I see it, I won't be able to get anyone to trade one of these without parting out a P.U.B. in the first place - so here's a chance to gain a gazillion cranks, and what is probably a direct bolt-in replacement in that black 130bcd crank in the lot.
And if you do have one, but this trade doesn't tickle your fancy, PM me...let's talk.
-Kurt
cudak888 is offline
Old 07-12-20, 04:39 PM
WGB
WGB
WGB's Avatar
Bikes: Panasonic PT-4500
Quoted: 1800 Post(s)
Liked 2,334 Times in 1,378 Posts
Opps! Double post
WGB is offline
Old 07-12-20, 04:40 PM
WGB
WGB
WGB's Avatar
Could a standard one be painted or powder coated??
Only saying incase you can find that specific special one...
WGB is offline
Old 07-12-20, 04:51 PM
cudak888
cudak888's Avatar
Could be, but I'd assume that PC would come off the chainring teeth pretty quickly.
You wouldn't happen to have the silver variant though...would you?
-Kurt
cudak888 is offline
Old 07-12-20, 07:17 PM
WGB
WGB
WGB's Avatar
I have only the ones from Sports models which I suspect you don't want.
WGB is offline
Old 07-12-20, 08:08 PM
cudak888
cudak888's Avatar
I'm after the current square-taper adaptation of the old Heron crankset. Preferably in black, which was only offered on the P.U.B, but the 2019 US-market Raleigh Tourist (no relation to the old Tourist) and the current Raleigh (UK) Willow have them in silver:
Though I'd be open to any previous square taper adaptation, I'm not sure if such a thing existed before these.
-Kurt
cudak888 is offline
Old 07-13-20, 10:04 AM
Glennfordx4
Glennfordx4's Avatar
Quoted: 90 Post(s)
Liked 137 Times in 45 Posts
I will take a look around, I had one of the newer Choppers that had the silver crank arms like that. I junked the frame but stripped it before I did, don't remember what I did with the cranks that were on it.
Glenn
Glennfordx4 is offline
Old 07-13-20, 04:46 PM
cudak888
cudak888's Avatar
EDIT: Glenn hasn't found the cranks, and doesn't think he has them anymore. If anyone has a silver set off a Chopper, I'm listening.
Glenn, if the cranks survived, send me a PM. The Heron pattern on those Chopper cranks actually look a bit better. Not sure if my neighborhood painter could put some urethane black over the rust, but it's worth a shot.
They're 170's, right?
-Kurt
cudak888 is offline
