Removing 1 to 2 mm from steerer tube
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 230 Post(s)
Liked 377 Times
If you wanted to remove 1 to 2mm from a carbon fiber steerer tube how would you do it?
Would you bevel the edges down to where you wanted to end up?
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Expired Member
Quoted: 3797 Post(s)
Liked 5,795 Times
It doesn't need to be particularly true. Longer lengths are usually cut with a hacksaw, not precise.
Quoted: 4239 Post(s)
Liked 3,973 Times
Since the top of a threadless steerer doesn't need to be particularly square with the axis a simple and quick "eyeball" approach is all that's needed. One trick is to wrap a bit of masking tape around the steerer and use the upper edge as a visual guide while grinding away. Remove the tape and deburr by hand with fine emery cloth. Andy
AndrewRStewart
AndrewRStewart
Quoted: 5971 Post(s)
Liked 2,878 Times
As noted by others, it doesn't have to be perfect because nothing ever rests on the top and relies on it for squareness, nor is it ever seen.
However, if you're finicky, throw a hose clamp around it as a reference guide, and trim down with a file, or cut down with a hacksaw. While a bevel isn't necessary, I bevel all cuts out of habit.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 525 Post(s)
Liked 692 Times
We have a dedicated miter saw with a crazy fine blade and a jig to hold the fork (or seatpost) cause time is money, but a sacrificial hose clamp or old stem and a disk sander (hand held or otherwise) works well too. This is another "i gotta shoot the s***t with the mechanic for a bit" scenario, otherwise folks ***** about the rate per minute on the service. I usually tell em to get a coffee or such, and "it should be ready" when they get back...
Liked 2,878 Times
One hint for those using a hacksaw to cut CF steerers.
One of the general rules of using saws counts double with CF, namely, Let the saw do the work. People have a tendency bear down when sawing, which is fine on wood, kind of OK with steel or other metals, but a definite NoNo with CF. You want a sharp blade, and want to let it do the work. Bearing down causes it to bite too hard and tear rather than make a smooth cut.
Same with a file, light but firm pressure, not force.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Resident PIA
Quoted: 230 Post(s)
Liked 377 Times
Shad
67'er
Shad
67'er
Method to My Madness
Quoted: 2068 Post(s)
Liked 1,561 Times
I would just add a 2 mm spacer, but maybe I am too risk-adverse when it comes to non-reversible changes.
Likes For SoSmellyAir:
Quoted: 4595 Post(s)
Liked 1,749 Times
Don't grind it. That will damage the matrix. Use a diamond saw or a well worn metal hack saw.
Liked 2,878 Times
For that amount, I wouldn't bother either. However the OP asked how can I, not should I.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 3335 Post(s)
Liked 2,182 Times
Likes For Steve B.:
Liked 3,973 Times
The amount wanted to be removed (the reason and some of our opinions are unknown) is pretty much the cutting width of a common metal hack saw blade and much less than those carbide glued to a wire ones. So in this specific case I sort of suggested using a bench grinder or belt sander. The key, as I learned it by doing, is a fast cutting speed and a maximum grit count (fine cutting) stone/belt. The feed should be pretty slow and I have held the steerer's end against the grinder so the cutting force is tangential and the fibers support each other better. The usual time to do this is after cutting down the factory length to fit a bike and one does want to deliver the bike with a close to square and smooth top of steerer, so only minor removal is done. But taking off another mm or so should be no big deal if one doesn't use a hand held sawing tool. Andy
AndrewRStewart
AndrewRStewart
Quoted: 564 Post(s)
Liked 504 Times
Resident PIA
Quoted: 230 Post(s)
Liked 377 Times
Shad
67'er
Shad
67'er
