Mixed spokes on a wheel?
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
After enjoying my new wheelset for several months, I happened to test my stainless steel spokes with a magnet on a whim. The results surprised me. On the rear wheel, (24 spokes) 7 had a very strong magnetic attraction and 17 had virtually none. On the front all 20 had very strong magnetic attraction.
I understand that stainless steel can have some light magnetic attraction, and the spoke manufacture has confirmed this. But it seems logical to me that this should be consistent within a batch, without a substantial difference like I found here.
Unless the wheel manufacture or builder used mixed spokes, it doesn’t make sense to me that they could react so widely differently to the magnet test. Wouldn't you agree?
I checked some of my other bikes with SS spokes and almost all reacted very consistently... Very little or virtually no magnetic attraction on all the spokes in the set. One set had one spoke on each wheel that had very strong reaction, while all the rest had virtually none. Strange, I thought.
Finally, if the spokes are mixed, stainless/non-stainless as I suspect, how much does it really matter for performance or longevity? The perfectionist in me says buy new spokes from a reliable source and re-build the wheels, just because I can. The pragmatist in me says just ride and forget about it.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I wouldn’t be surprised if the company used multiple suppliers of spokes and this sort of thing were more common than we realize. As long as the wheels were well built it should never be a concern. I may be OCD, but I’m not all-my-spokes-must-be-equally-magnetic OCD.
Likes For ThermionicScott:
Quoted: 1438 Post(s)
Liked 1,092 Times
Some grades/alloys of "stainless" (corrosion-resistant, technically) steel are highly magnetic, others less so to varying degrees. Heat treatment such as annealing and processes such as cold-working can change their properties as well. So your spokes are probably all "stainless", just from different manufacturers or grades as ThermionicScott suggests.
https://www.metalsupermarkets.com/is...teel-magnetic/
https://www.carpentertechnology.com/...ainless-steels
If there are different spokes in a wheel, some might behave a bit differently over time - stretch more/less, loosen more/less, thus the wheel going out of true; or the nipples could tend to seize more/less than others, making trueing difficult.
Quoted: 2026 Post(s)
Liked 1,096 Times
I checked the wheels on my bikes. Two set are built with conventional DT spokes and two sets are Shimano pre-builts with bladed spokes. None of the spokes are strongly magnetic, they very from almost no magnetic attraction to very mild.
Most stainless steel bike spokes are made from a 300-grade stainless that is only mildly magnetic at most. I don't know of any maker using strongly magnetic grades of stainless steel (400-series) so those may be plated carbon steel.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
did you buy the spokes in a manufacturer box ? "In theory" if you have a box of 100 spokes, they "should" have come out of the machine sequentially, drawn from the same batch of wire.
if you bought them from a dealer who had spokes in bins then just about anything is possible.
do the spokes have any different markings on the heads ? DTs will have a "DT", Wheelsmith will have a "W", Sapim usually a stamping above the elbow.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Sr Member on Sr bikes
Perhaps another thing to consider with mixed spokes is the weight between the various composition/material used. If there's a difference in weight-per-spoke between the two materials, but they're distributed evenly around the wheel, I suppose there wouldn't much concern/notice. But if there is a weight difference, and they're all clumped together, it might make the wheel considerably out of balance. You may not notice it at low speeds, but at higher speeds it might become apparent...a bouncing feeling...like when a car wheel is out of balance.
Dan
Dan
Liked 2,568 Times
All of that is very unlikely, especially if the wheelbuilder is competent.
Liked 941 Times
From Sapim factory:
All d-light spokes are 100% AISI304. But indeed the cold deformation process ( cold forging process) transforms the austenitic structure partly into a martensite structure. This makes the stainless steel being slightly magnetic. If you a strong magnet all spokes will react but if the magnet isn’t strong than it is possible that some spokes will react and others not.
But believe me, all spokes are AISI304.
aged to perfection
Quoted: 837 Post(s)
Liked 1,258 Times
yes, I agree with your analysis. Most likely cause is that the builder mixed and matched spokes of the same length, just pulling them randomly from the bin.
Not sure how to advise you here. Is the wheel behaving normally in use ? Maybe not worth worrying about ? I'm not saying it's ideal, but unless you want rebuild the wheel over the winter I'd let it ride until respoking / replacement was required.
Mark Petry
Mark Petry
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
Wheels were bought already built from Bicycle Wheel Warehouse. I explained my case to them and asked for replacement SS spokes, so I could re-build them myself. They asked me to contact Sapim with my concerns, and said they would rebuild the wheels for me pending Sapims response.
From Sapim factory:
...which doesn't really explain the huge discrepancy I found. (I tested with both strong and weak magnets) It seems to me the mix was likely at BWW not Sapim. I have not followed up with BWW and don't know if I'll bother.
From Sapim factory:
Never mind all that. This is not a question about metals. I hope you get some exercise and clear your head so you can think about something important. =)
Quoted: 1104 Post(s)
Liked 1,825 Times
No way in this world I'd re-build a set of wheels because some of the spokes "might possibly" be different from the others based on a magnet test. What is important is spoke tension, uniformity and performance. I have some wheels built with the very same spokes, I couldn't tell you if they're magnetic or not.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Dan
Dan
Likes For Wilfred Laurier:
Quoted: 7348 Post(s)
Liked 2,465 Times
It is odd, for sure, but I agree with the others who say leave well enough alone. I never thought to do your test, and maybe I will now. Maybe I'll get the same results.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
https://www.suspicious0bservers.org/
Likes For AnkleWork:
Quoted: 5224 Post(s)
Liked 3,581 Times
is it Friday yet? I've been tempted to buy some bladed forks for my road bike, cuz when I break them, whatever shop I wind up in, doesn't always have the same (original type) to use. so my road bike has mixed spokes
I said it because it has happened to me before. I had my rear rim crack at the spoke holes so it needed replacement. When replacing the rim, one side of the spokes were replaced with new ones (I don't know which side was the new ones, as I had LBS to do the job for me. My bet is that the former DS spokes migrated to NDS and DS had new spokes, since the new rim has slightly higher profile). The wheel kept going out of true, due to DS spokes loosening or stretching, and after a few weeks of winter riding all of DS spoke heads were seized, so I had to cut and replace all of them. Strangely enough, while the spokes most likely still are different on DS and NDS, haven't had any spoke related troubles since then. Go figure.
Liked 2,568 Times
There is no mention of competent wheelbuilder though.
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Ride'em like they are and ask the builder to give you an extended warranty.
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
Another possible explanation is that they used all new spokes but forgot to put lube on the DS threads, which they should have done even if they were reusing spokes.
SE Wis
Liked 3,390 Times
https://www.etsy.com/listing/7355516...SABEgJxSfD_BwE
