Finally figured out what fourth center hole on a cycling shoe sole is for - Look Memo
Craigslist Addict
Bikes: Zipp 2001, Specialized Roubaix, Felt FA
Quoted: 7 Post(s)
(Edit: Title is cut off, should say Look Memory Eyelet)
After nearly a decade of using Look Keo pedals, I finally figured out what the fourth hole on the sole of cycling shoes are and how to use them when changing cleats. The mysterious fourth hole between the standard 3-holes is referred to as the Look Memory Eyelet and is designed to allow cleat replacements without losing the previous cleat position. The Look Memory Tab (a small plastic tab, also referred to as Look Memory Clip) portion of the Look Keo cleat is secured onto the Look Memory Eyelet with the supplied screws with the cycling shoes.
The Look Memory Tab snaps onto the Keo cleat allowing you to remove the cleat and install a new cleat without removing the Memory Tab. Installing a new Keo cleat is as simple as snapping it in place and installing the new hardware. No sharpie or tape needed to mark the previous position!
I've seen a few forum questions but no actual photos or videos on how to use them. Here are the instructions (you can see more photos/video here):
Hopefully this helps next time you replace your Keo cleats or get new shoes. If you've lost the screws that came with your shoes, you may want to reach out to them for replacements. Mine are about 6 mm long but I don't know the threading.
LOOK Memory Eyelet & Tab
Left – Memory Tab secured to shoe, Right – Cleat installed over the Memory Tab
- Remove Look Memory Tab/Rubber Cover: Take new cleat and push down on center rubber tab to pop both the Memory Tab and the rubber cover off.
- Re-attach Memory Tab: Snap the Memory Tab back in place ensuring the smooth surface is facing downward toward the shoe.
- Position Cleat On Shoe: Find the optimal location for the cleat on the shoe.
- Adjust Look Memory Eyelet: Ensure the Memory Eyelet is visible through the center of the cleat. On a new shoe there may be some resistance to moving the eyelet, but it is designed to move along the slot.
- Secure Look Memory Tab To Look Memory Eyelet: Use the provided 5mm screw to secure the Look Memory Tab to the Look Memory Eyelet while maintaining the cleat position.
- Attach Cleat To Shoe: Using the 3x washers/bolts that came with the Look Keo cleats, secure the cleat to the shoe.
- Re-attach Cleat Rubber Cover: Slide the rubber cover back onto the center of the cleat. The rubber piece is flexible, so a little persuasion will pop it back in place. Now the next time you replace your cleat, you’ll get to reap the benefits.
Likes For sweetcyclists:
Quoted: 4806 Post(s)
Liked 3,928 Times
Did you ever ride the older Deltas? I ask because I still ride Deltas (or Wellgo copies) on my best bike and Forte Delta compatible pedals. (I rode the black, no-float, cleats and never saw a reason to pay more than for the Performance brand (Wellgo) pedals that work quite nicely for me. I've always wondered what improvements came with the KEOs but never been in a hurry to toss working pedals and cleats to find out.
They look more walk-able without KoolKovers. That 4th screw yes. (I place tape on the cleat edges to duplicate alignment.) Float differences mean zero to me.
Ben
Ben
Quoted: 18883 Post(s)
Liked 10,646 Times
I've always just used masking tape to mark the position. Obviously I didn't know either, for five (?) years now.
Likes For Seattle Forrest:
Quoted: 1104 Post(s)
Liked 1,825 Times
I may try this the next time I mount new cleats but I'm not taking any off to put that memory piece in the there. Usually, when I replace cleats from being worn out, the new one settles into the indentations of the old one in the sole of the shoe.
Craigslist Addict
Quoted: 7 Post(s)
Ben
Ben
You must be rebuilding your pedals for them to last so long. I typically start getting axle play after a few years of riding and just replace the pedals.
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Quoted: 4560 Post(s)
Liked 2,802 Times
Ben
Ben
Drawback? I found the rubbery cushions made it difficult to clip in and unclip. It always felt balky and mushy, compared with the positive click feel of Deltas. So I wax the cushions and pedals on all contact/friction surfaces. I just use leftover scented candle wax, which is soft enough to scrape up a bit on a fingernail and smear around the contact surfaces. MUCH better. Stays positively clipped in, but feels more like the Delta.
Neutral characteristic: Less float than Delta. It's enough float to keep my knees comfy. But cleat alignment is more critical. I needed to tweak the cleat angle a few times the past year to get it jusssst right.
Looking forward to trying the Keos on a new-to-me bike build.
Likes For atwl77:
Quoted: 551 Post(s)
Liked 277 Times
I've always wondered what that 4th hole was. Very nice!
Craigslist Addict
Quoted: 7 Post(s)
Thanks for feedback, I'm glad I wasn't the only one!
Also wanted to add that the FLR shoes I use in the photos/video only came with the screws and no washers. My SIDI shoes do some with washers, which I think are necessary to prevent the screw head from pushing through the thin plastic of the Look Memory Tab/Clip.
Quoted: 451 Post(s)
Liked 364 Times
I haven't ridden my new-to-me Look Keo pedals yet (gift from a friend), but the pedals and cleats are pretty similar to Shimano SPD-SL. Biggest difference between my old school Look Delta and SPD-SL is the rubber cushions. Easier to walk in, more secure when I put a foot down at stops.
Quoted: 451 Post(s)
Liked 364 Times
Liked 2,802 Times
What does the wax do for walking safety? I am an experienced Keo walker and I took a pretty good spill a few months ago. I do buy the padded/cushioned cleats, but the pad had worn off--as it sadly does--and so they were bare. Lucky I just landed on my rear and didn't injure a knee or something. I find walking, even after lots and lots of practice, to be hazardous in these cleats. Can't imagine making it slipperier. But what do I know...
A couple of weeks ago while riding with a friend I wanted to take the road through an intersection, mostly for the steep hill challenge, but he wanted to take a shortcut around the hill. The "shortcut" turned out to be wading through about 50 yards of construction site mud. He was on his gravel bike and had whatever clipless cleats and shoes are better suited to that stuff. Anyway, it didn't cause him any problems. But I had to stop and find a stick to dig out the mud and pebbles from my cleats before I could ride. And that little bit of walking rubbed off the wax so clipping/unclipping was mushy again.
I told him we're tackling that hill next time. He's less than half my age and could easily beat me to the top anyway.
And it'll clean off easily with rubbing alcohol, Goo Gone or pretty much any solvent or just soap and water.
Likes For canklecat:
Quoted: 8280 Post(s)
Liked 9,038 Times
I've been using Delta pedals (mostly) since about 1992. I've never had one apart except for the one that came apart while riding. The top surface wears down but I stop using them when the gate/latch wears down to become razor thin. I'm on my last pair, going to have to find more or switch.
