Busted Campy Nouvo Record Shifter - Pooey Stinko!
Quoted: 1372 Post(s)
Liked 1,751 Times
More than once I have seen this and today I created this. How do I prevent this from happening..?
The shifter set was used and had been installed before. You (meaning me) could see cracks in the chrome at the narrowest part of the clamp, on both sides. I was aware of this and exercised great caution spreading the clamp so as to not scratch the new paint/art on my Rabeneick "Modell Campagnolo", which is just about done...
The busted clamp brings a halt to the build. My question is - How do you guys spread the clamp, any clamp for that matter, when installing or removing clamp on components?
Quoted: 3464 Post(s)
Liked 2,829 Times
When the band is opened up to accept the tube is must be treased open uniformly. Most don't do that and allow it to bend at the narrow point. Later bands with the chrome backing plates were a bit thicker material too.
save the old shifter. long ago we drilled out the backside rivet, gathered the useful parts, added the Campagnolo braze on compression washer and employed them on frames with braze on mounts.
For a while, the complete banded shifters were less expensive than the other attachment kit.
Likes For Mr. 66:
Liked 1,751 Times
I like to wrap the tube with heavy paper maybe tape and then I don't need to be as careful.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3888 Post(s)
Liked 6,485 Times
señor miembro
Liked 6,485 Times
