Peugeot Mtb should I buy it?
Uruguay
I have a reaaally tight budget, she is listed for 800 uruguayan pesos (20 dollar), seems to be in good condition and i was looking for a rare import vintage mtb, any comments on her? Ill ask the owner about transmission condition, thats the only worry i have
Is it your size? It's a small frame.
Quoted: 1372 Post(s)
Liked 1,751 Times
Size, as mentioned, is of great importance. To that add that the bike will, likely, require some work and parts to make it road worthy and safe to ride. Figure on cables and casings, new brake pads, grease for bottom bracket, head set and hub bearings and replacement bearings if the originals are worn out or damaged. To that add the cost of work if you cannot do it yourself. At the end of the day that twenty dollar bike might well set you back over a hundred if things are not up to snuff "as found".
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Its a low end bike in poor condition. Valuation is all local. Around here, I would donate that bike. But it might be a lot harder to find in your area. Generally, look for an older MTB with higher end parts: think Deore XT, DX or LX. Chances are, a bike with such better parts will also have better wheels, better frame, better everything.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Are the wheels 26" or 24"? Is it me or is the fork bent a bit?
Sugar "Kane" Kowalczyk
Edumacator
Quoted: 2436 Post(s)
Liked 3,118 Times
Quoted: 1607 Post(s)
Liked 2,579 Times
I see you've flipped a few bikes, so you should have a good idea on its condition when you see it. The newer Peugeot mtb is basically an Asian made model. So, not a whole lot different than most of the other common brands.
