car alternator on a bike?
Bikes: 1981 Schwinn World Tourist, 200* redline conquest tour
I know this sounds incredibly stupid, but do you think you can use a smaller car alternator for bicycle lighting? (lets just say for the cool factor...for that chopped up cruiser bike you've been building..you know...short trips)
Spinning an average alternator by hand doesn't seem to produce much drag to me, but this is when its completely disconnected. Maybe you could run one much like a bottle dynamo.
I suppose you could vary the field coil voltage to get more power on command or less drag, depending on the time, maybe by turning a knob on your bicycle, or to have dim/bright lights. Maybe even a large 6 amp headlight!
Also also...what if you used some super-capacitors and an average 6 volt bottle/hub dynamo to run high current device for a short period of time on your bicycle?
... such as a horn. more specifically, a vintage 6 volt "ahooga" horn.
slowly charge the capacitor, watch voltage and amps go up on cool vintage guages on your bicycle, and honk the horn to scare people every few minutes!
anyway...late night ideas.
Quoted: 14 Post(s)
Liked 13 Times
As a novelty, it might work or be a fun project. I think you'll need a battery to power the field coil. It can power itself once spinning fast enough but every time you start out it will need the battery (or charged capacitors) to provide the field current. I don't know the details, but field currents can be 1/10 the rated output, so quite high if it's a sizable alternator. Providing the field current might take a fair amount of pedaling power.
Also, in auto applications they spin pretty fast. Spinning them that fast might take some gearing and a lot of effort.
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Sturmey-Archer's "Dynohub" hub-mounted alternator came on the market in the mid-1940s, Pretty sure the modern offerings from Shimano, etc. are also alternators. What advantage do you see in using an automobile alternator?
maybe a stationary bike so you can keep the lights on , like Edward G Robinson in 'Soylent Green'
Mmm Tuesday is Soylent Green day ..
they would be cheap and have a "hacker" look to it. You know, youve seen guys with car steering wheels on their bikes before.
i find it funny how most consumer food is made of soy nowadays. get it.....soy soy lent green
school food was always compressed soy bricks with plant filler and "meat" flavoring.
Quoted: 4260 Post(s)
Liked 1,364 Times
That's why it was called "soylent green" in the first place. The whole "it's people" (rather than made from soy/plants) thing being a "surprise" was the point.
Other Worldly Member
Quoted: 194 Post(s)
Liked 136 Times
Interesting idea though overkill. I mean... Unless you are running 200-300 watts+ of halogen lights (+ AC!) or have an inverter running a blender out back... Probably better wiring wise using a motorcycle AC alternator. If you want lights at a dead stop...that means a battery, voltage controller ='s weight. Find an old street legal moped & take off its lighting "system". Just looking at all the parts might tell you something.
Make ******* Grate Cheese Again
Old fart
Liked 3,401 Times
I never weighed mine; probably 2-3 pounds, I'd guess. I'm not racing when I ride that bike, so I don't really care about the weight. But how much is an automobile alternator and cobbled-up housing, reduction gearing, etc. going to weigh?
Old fart
Liked 3,401 Times
https://www.bikeforums.net/classic-vi...itch-unit.html
Liked 1,364 Times
Apparently, an automobile alternator weighs around 10 (or more) pounds or so.
How much does an alternator weigh
Quoted: 194 Post(s)
Liked 136 Times
I use rechargeable lights to avoid wiring hassle (but my cadence meter is wired...ugh) though once LEDs start dominating lighting systems..might be practical to have super light weight & low output charging systems integrated with a central battery that runs headlights, tail lights, brake lights Di type shifters, auto shift, power brakes, brake lights, etc. Bikes have a long way to go in terms of "electronic" tech.
Old fart
Liked 3,401 Times
Bikes: Bacchetta Giro, Strada
The only reason I'd want to use an automotive alternator on a bike would be if I was making a stationary bike generator of some sort.
Other than that, I'd use a generator designed for a bike.
If you do use an automotive alternator, you'll need to gear it so the alternator spins a whole lot faster than you pedal. I'm not sure how fast an automotive alternator spins in use ... but I suspect it's geared to run faster than the car engine itself, and that's around 3000 rpms at cruising speeds.
Passista
Quoted: 868 Post(s)
Liked 721 Times
I don't think it would work, because a 12V car alternator produces around 50A @6-7000RPM, that's 600W. At 50% efficiency, you'd need 1200W to spin it. Pro sprinters can output about 1500W, but only for a few seconds. A commuter probably doesn't output more than 100W.
Certainly, the alternator in your car isn't producing 600 watts all the time. 50 watts during the day seems more like the average, maybe 200 watts at night. But more if your battery is close to dead -- but most of the time it's fully charged.
An alternator probably isn't ideal, but I imagine it could be made to work for a stationary bike generator with the right gearing. But it's too big to be practical for a moving bike generator for the lights and such.
Passista
Quoted: 868 Post(s)
Liked 721 Times
^ You're right, what I meant is you never could use the alternator's potential power. Still, you'd need a lot of power to produce 50W.
Quoted: 7352 Post(s)
Liked 2,479 Times
And since you'd need a lot of extra leg power to lug the car alternator around, it would be a lot less efficient than a bike dynohub.
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
A generator has permanent magnets, there's always some resistance when turning the armature. The output isn't regulated very well, there are usually some extra windings that become energized at higher RPM to limit output voltage (the old Sanyo bb generator was one of the first to use this technique). All the hub and wheel dynos that have ever been sold are generators, Union, Sanyo, Miller, Subetiz, Shimano, SON, SA, SP, et al.
Most automotive alternators run 2:1 or 3:1.
So your cruising rpm in a car can range from 2,000 to 3,000. Multiple this range by 2 or 3 and that's how fast your alternator is spinning.
