Resigned to just using tubes this year instead of going tubeless
#151
I gotta say fellas, this hookless thing is giving me the heebie jeebies!
I believe it's well established that I'm all for tubeless but hookless is a hard pass from me. It had massive issues before, you still need to only use approved tire and rim combinations and the pressure limits are so looow!
It's just one of those things that provides zero benefits for the rider, added risk, added complications and is basically pushed so hard, because a hookless rim is so much easier to manufacture.
I'm going to go grow my beard now. And attach mirrors to my helmet.
#152
Habitual User
Quoted: 4996 Post(s)
Liked 8,163 Times
Have not heard of it but I also don't know many guys using carbon hookless. I managed to get the somewhat-tight Specialized tires on without a lever. It is just me thinking they may be a bit fragile. I have rarely had to use a lever on the othe r 5-6bikes I have that are tubeless but the MTB ones have hookless beads that are pretty thick so I never worry about them.
Likes For Eric F:
#153
Quoted: 7016 Post(s)
Liked 11,028 Times
Yup. The hook is the most fragile part of the rim; eliminate that, and you actually get a stronger rim.
#154
With a mighty wind
Quoted: 1094 Post(s)
Liked 882 Times
Yesterday I took a tubeless tire off my gravel bike to rebuild the wheel. Even though it has been sitting for the winter, the sealant was still fresh looking. Orange seal endurance.
I managed to suck a lot of it back up and save it.
Finished with the wheel and retaped it and inflated the thing with a very average floor pump. It held air just fine with no sealant.
I got distracted and it was a few hours until I went to add some sealant. It still hadn’t lost any air.
Deflated it and removed the core, squeezed some sealant in, put the core back in and reinflated it, again with a basic floor pump.
Absolutely no issues.
Unless I break a spoke or cut the sidewall, that tire will be in place through the summer or longer and my chances of regular type flats is almost nonexistent in that time.
It takes a bit more care than putting in a tube but it sure doesn’t feel like a lot of work.
#155
Quoted: 4445 Post(s)
Liked 4,903 Times
You know what's a hassle? Having to stop in the middle of a ride, due to a punctured tube, and then having to repair the hole on the tube or change to new tube and hoping the new tube lasts for the rest of the ride. With tubeless it seals right up and you can continue riding.
I ride a lot of sportives and I'm guaranteed to see at least half a dozen riders stopped by the roadside changing tubes. That was sometimes me before I switched to tubeless.
There's a learning curve involved with tyre/rim compatibility and choice of sealant, plug kit etc. But definitely worth it for me. I've found a combination that is easy to fit and inflate without any hassle on my rims.
Likes For PeteHski:
#156
Liked 11,028 Times
This was my primary motivation to switch to tubeless. I was averaging maybe 1 or 2 flats per month on tubed road tyres. Now I average none. I have never had to remove a bike wheel at the side of the road/trail on any tubeless setup, either road or mtb. I've had to use a few Dynaplugs along the way (but only once on my road bike in over 3 years). The ability to run fast, supple road tyres without any major risk of a flat is having your cake and eating it. The ability to plug larger punctures in a few seconds without removing the wheel/tyre is the icing on the cake.
Wha...Wha...Wait...But wolfchild and Leisesturm said this isn't how it works!? I mean, they would surely know, since they're too smart to have ever even tried tubeless -- right?
